4g lte compatibility
andy67
andy67 Posts: 5
Is the Up board / core / squared compatible with sixfab 4g shields ?
https://sixfab.com/product/raspberry-pi-base-hat-3g-4g-lte-minipcie-cards/
This shield is designed for Raspberry Pi 4, 3, 2, B+, A+, Zero
Compatible Mini PCIe Modules
Quectel:
EC25 Mini PCIe 4G IoT Module
EC21 Mini PCIe 4G IoT Module
EC20 Mini PCIe 4G IoT Module
UC20 Mini PCIe 3G IoT Module
Quectel*
LTE-EP06
Sierra*
AirPrime MC Series
Telit*
LM960, LE910V2, HE910, LE910Cx, and more
Huawei*
ME909s-120, ME909s-821, and more
Simcom*
SIM7100, SIM7230, and more
ZTE*
ZM8620, and more
U-Blox*
MPCI-L2 Series
Thales mini PCIe modules*
PLS62W, mPLS8, mPLAS9
    DCleri Posts: 1,213 admin
    It should be, but it wasn't tested so you would need to try.
    It's using an external USB cable to communicate with the modem, while if you get our 3G hat (from up-shop.org) you can find a solution with a smaller connector that use the internal USB interface available onboard
  • andy67
    andy67 Posts: 5
    i really need 4g, do you have any 4g hats ?
