Low resolution
7h0n
New Member Posts: 1 ✭
I would like to know if I can use the UP Board with the Lakka OS in low resolution, such as 240p, using a CRT TV, and using the appropriate peripherals on the board
@7h0n
Firstly, the Lakka OS is not fully compatible with UP, and secondly, HDMI to 240p isn't very common on the UP.
I think you probably need a HDMI to VGA converter, or other
See the reference below, maybe that is what you want.
https://reddit.com/r/crtgaming/comments/awqolc/get_high_quality_240p_from_your_pc_to_your_tv/
