What are the maximum/minimum feeding voltage for UpSquared?
My board is UpSquared. My operating system is Ubuntu 16.04. I am using mini usb wifi
adapter, mini usb wifi adapter, SATA for a disk, and some gpio pins and 5v pins also.
In datasheet, power supply voltage is written 5 volt DC. My question is that what is the maximum and minimum limits? For example can I give 6 Volt,4 Volt,7volt? I tried to give 5.5, 5.3 Volt and there is no problem. What are the limits and what are the warnings if I give more than 5V?
Welcome!
Welcome!
