Steps to make an UP² Grove IoT Development Kit from UP2 board (N3350) and Grove interface board ?
Hi everybody,
I am a newcomer to UP2. I bought a new UP2 board (using N3350, without OS installed). I now want to use this board with the GrovePi + board to work as an UP² Grove IoT Development Kit. So what steps do I have to take and where do I get the installation files? Looking forward to all the helpers.
Thanks so much !
If you install Ubuntu, with our Kernel and the LibMRAA libraries via PPA you can use the GrooveKit directly: https://wiki.up-community.org/Ubuntu
If you want to use the Arduino create IDE to write sketches, then you should install the Arduino Connector and then add your system as an UP Squared:
https://create.arduino.cc/getting-started/up2/welcome
https://github.com/arduino/arduino-connector -
Hello DCleri,
Thanks for your quick feedback.
Can you specify further:
(1). For hardware, we are using:- UP Squared (N3350): https://up-shop.org/home/270-up-squared.html
- GrovePi+: https://www.seeedstudio.com/GrovePi-p-2241.html
- WIFI Kit: https://up-shop.org/up-peripherals/345-new-m2-2230-wifi-kit-for-up-xtreme.html
- GROVE Sensor board
(2). For installation,
We tested UP2 okay with http://releases.ubuntu.com/16.04/ubuntu-16.04.6-desktop-amd64.iso .
We want to know: We need to install: http://releases.ubuntu.com/16.04/ubuntu-16.04.6-desktop-amd64.iso or http://releases.ubuntu.com/16.04/ubuntu-16.04.6-server-amd64.iso ? We need use UP2 with Arduino Create.
(3). Will we must implement all steps as follow ?
1 Ubuntu 16.04 installation and configuration_
1.1 Install Ubuntu for UP, UP2, UP Core and UP Core Plus
1.1.1 Prerequisites
1.1.2 Installation
1.2 Install Ubuntu kernel 4.15.0 for UP from PPA on Ubuntu 16.04
1.3 Install Ubuntu kernel 4.15.0 for UP locally from debian packages on Ubuntu 16.04
1.4 Install the Ampak firmware for WiFi and Bluetooth
1.4.1 WiFi
1.4.2 Bluetooth
1.5 Install the Ampak firmware for WiFi and Bluetooth locally from debian package on Ubuntu 16.04
1.5.1 WiFi
1.5.2 Bluetooth
1.6 Install the Realtek firmware to enable WiFi with the 5M02.B module on Ubuntu 16.04
1.7 Fixing HDMI Audio not working on UP Board and UP Core on Ubuntu 16.04
1.8 Enable the HAT functionality from userspace~~~~(4) Which kernel ?
Which kernel we will use ?
(5) Where will we get LibMrAA libraries ?Thanks for your support !
4) 1.2 Install Ubuntu kernel 4.15.0 for UP from PPA on Ubuntu 16.04
