failed to install Ubuntu 16.04 for Up Core Plus
I tried to install Ubuntu 16.04 for Up Core Plus (Atom® x5-E3930), but failed even to load install. Though I watched install menu, when loading installer, the following message shows up and returns back to boot.
Regarding "TPM error", by disabling secure boot in BIOS it doesn't show up anymore.
I tried to search the error "Couldn't get size: ...", and it seems to be related with secure boot,
but I cannot find any solution.
Giving me any advices are really helpful.
Best regrads,
Hide
Hi @hgemini ,
Could you please tell which BIOS version and which Ubuntu version exactly are you using?
Official instructions for Ubuntu and kernel installation here: https://wiki.up-community.org/Ubuntu#Ubuntu_16.04_installation_and_configuration
Thanks @ccalde,
I did the same way as in you pointed URL and
Ubuntu version :16.04.6 (using ubuntu-16.04.6-desktop-amd64.iso)
BIOS version:
UPC-PLUS R1.0 (UPCPSM10)(02/19/2019)
I updated BIOS by reading the following URL
https://downloads.up-community.org/download/up-core-plus-uefi-bios-upcpsm10/Many Thanks !
Hi @hgemini
There isn't TPM on UP Core Plus, only fTPM and it is not used by default nor secure boot.
Please make sure the BIOS settings are the default ones, you can reset them either unplugging the RTC battery and re-plug after a minute, or within the BIOS itself, select reset to default.
Can you install the system then?
Hi @DCleri
Thanks for detail advice.
I have restored BIOS options, unplugged RTC battery and waited for a few minutes.
Then I found nothing changed.When booting Ubuntu installer with USB memory, there comes the same messages I attached before
and rebooting. Before rebooting Ubuntu seems to be loaded (watched start up LOGO for a minute).I checked out BIOS menu and found the message "TPM20 Device Found".
I attached its screen.Could please check and any other options to try ?
Best regards.
Hi @hgemini ,
Thank you for sharing the setup information.
We will try to replicate the issue here to understand why it's failing from your side. -
Hi @ccalde
Thanks for supporting us.
We have just ordered HS carrier board and AI Core X and
are looking forward to trying them with UP Core Plus soon. -
Do you have any possibilities to solve this issue ?
I am wondering whether I will raise RMA request or not.Many thanks.
Hello @hgemini
We have tried the same settings and same BIOS (by default it looks exactly like yours ) and we can install Ubuntu 16.04 and Ubuntu 18.04 without issues: https://wiki.up-community.org/Ubuntu
Do you have any other device connected to the UP Core Plus?
Can you please describe me your hardware setup (cables, connections, peripherals)?
Hello @DCleri
I unplugged RTC battery and tried to install Ubuntu, however, after selecting "Install Ubuntu", there came 2 errors followed by Ubuntu loading screen, went back to install menu.
Here is my environment:
- DP - HDMI adapter (active one by UGREEN brand)
- HDMI monitor (1080p)
- USB keyboard and wireless mouse via USB3.0 HUB
- AC adaptor
- 16GB USB Memory (ADATA)
and I found some sorts of glue at the edge of the board (see attached picture. you can find it at the direction of black arrow)
If you have nothing wrong with my environment, I would apply for RMA.
I would like to try Up Core Plus as soon as possible. -
please apply for RMA
@DCleri
I've got returned UPCore+ few days ago and tried to install Ubuntu.
However, the situation seems to be the same as for older one.Could you please your success procedure for installing Ubuntu exactly ?
- do you write Ubuntu image via Windows or Mac ?
- how do you connect display ?
- how do you connect USB memory, keyboard, mouse.
- what kind of USB hub do you use ?
- and more things ...
Best regards
As you can see from the picture, the board you sent back is working properly, the only difference that I can see is the fact you are using a HDMI to DP adapter, while I am using a DP cable.
The USB Stick used is a Sandisk, but also others should work. We flash the Ubuntu image (Ubuntu 16.04.6 Desktop) using the tool Etcher as described in our wiki: https://wiki.up-community.org/Ubuntu#Install_Ubuntu_for_UP.2C_UP2.2C_UP_Core_and_UP_Core_Plus
The PSU is a 12v5A, which is available from our shop. -
Hello @DCleri
It must be a matter of power supply or noise due to DP-HDMI adapter ...
I would try to connect with the monitor via DP.
I have to find the one. -
Hello @DCleri
We tried with DP direct connection, but the situation doesn't change.
We would finally buy 12V5A AC adaptor and try to install with it. -
hi @hgemini
Do you have a different USB stick to try for the installation?
Have you downloaded the Ubuntu image directly from the official website?
http://releases.ubuntu.com/16.04/ubuntu-16.04.6-desktop-amd64.isoAlso when creating the bootable image for the installation, have you tried using the software suggested in our wiki, balena Etcher?
https://www.balena.io/etcher/ -
Hello @DCleri
I did to try to use different USB stick (SanDisk Extreme Pro) and also failed to install.Today I tried to change AC adaptor to change bigger one and did to install Ubuntu successfully.
As in https://wiki.up-community.org/Hardware_Specification_UP2
- Power Supply Specifications
However it seems to be 12V6A for UP Core Plus only with display (without any other devices).
Hi @hgemini
UP Squared is one board and it requires a 5V PSU, another board is UP Core Plus which requires a 12V PSU.
https://wiki.up-community.org/Hardware_Specification_UP_Core_Plus
Power 12V@5A DC in 5.5/2.1mm jackThe PSU we have in our shop for UP Core Plus is 12V5A and it is plenty to run the board with any kind of expansion connected.
If you have a 12V6A PSU, probably the voltage is not stable enough and it drops below 12V under load, causing the system to not behave properly.
Hi @DCleri
I should read the following ...
https://wiki.up-community.org/Hardware_Specification_UP_Core_PlusI was convinced UPCorePlus requires the same AC adaptor as for UP2 because it is small.
Thanks for supporting up.Could you please let us know one more thing ?
After installing, I found that no network card is recognized.
How can I recognize WiFi adaptor ?
Could you please point out the url or so ?Thanks in advance
In order to properly setup the UP Core Plus, you must install the specific Kernel and WiFi drivers.
All the information are available in our wiki: https://wiki.up-community.org/Ubuntu#Install_Ubuntu_for_UP.2C_UP2.2C_UP_Core_and_UP_Core_PlusFor UP Core Plus, as you don't have a USB to ethernet adapter, the best way is to follow the instructions on how to install it locally:
Kernel: https://wiki.up-community.org/Ubuntu#Install_Ubuntu_kernel_4.15.0_for_UP_locally_from_debian_packages_on_Ubuntu_16.04
WiFi and BT: https://wiki.up-community.org/Ubuntu#Install_the_Ampak_firmware_for_WiFi_and_Bluetooth_locally_from_debian_package_on_Ubuntu_16.04 -
Hello @DCleri
I finally installed and executed our prototype with OpenVINO in the same way as with UP and UP2.
I had to say that the biggest issue was my misunderstanding due to thinking about UP and UP2.I will proceed to evaluate UPCorePlus.
Many thanks to your support
