[SOLVED] UART as /dev/ttyS4 not available - Please help!
On Ubuntu 16.04 , Here's what I get
sudo setserial -g /dev/ttyS[0123456789]
/dev/ttyS0, UART: unknown, Port: 0x03f8, IRQ: 4
/dev/ttyS1, UART: unknown, Port: 0x02f8, IRQ: 3
/dev/ttyS2, UART: unknown, Port: 0x03e8, IRQ: 4
/dev/ttyS3, UART: unknown, Port: 0x02e8, IRQ: 3 ---- S4 & S5 missing
/dev/ttyS6, UART: unknown, Port: 0x0000, IRQ: 0
/dev/ttyS7, UART: unknown, Port: 0x0000, IRQ: 0
/dev/ttyS8, UART: unknown, Port: 0x0000, IRQ: 0
/dev/ttyS9, UART: unknown, Port: 0x0000, IRQ: 0
kahren@kahren-UP-APL01:~/kampr-face-access-control$ dmesg | grep tty
[ 0.000000] console [tty0] enabled
[ 5.261289] dw-apb-uart.8: ttyS4 at MMIO 0x91524000 (irq = 4, base_baud = 115200) is a 16550A
[ 5.261475] serial serial0: tty port ttyS4 registered
[ 5.280603] dw-apb-uart.9: ttyS5 at MMIO 0x91522000 (irq = 5, base_baud = 115200) is a 16550A
[ 5.280833] serial serial1: tty port ttyS5 registered
yet when I do
import serial
ComPort = serial.Serial('/dev/ttyS4')
ComPort.baudrate = 115200
ComPort.bytesize = 8
ComPort.parity = 'N'
ComPort.stopbits = 1
data = ComPort.readline()
print("data : {}".format(data) )
ComPort.close()
I get --- FileNotFoundError: [Errno 2] No such file or directory: '/dev/ttyS4'
I really would appreciate guidance here! One thing to note, when I installed ubuntu 16.04.6 the instructions indicated to replace generic kernel but the listed command failed ... is the kernel the issue here?
Kahren
the issue was with the kernel .. fixed it and now /dev /ttyS4 is visible... at this point I don't get any data with CTS pulled to GND and the following code running on the UpBoard,, Note from my laptop I write bytearray(b'X') to USB to RS485 ... on the UpBoard side there is RS485 <--> TTL adapter that has TxD and RxD on the TTL side to UpBoard ... No other signals like RTS, CTS ... I see the TxD LED come on on the laptop side's adapter, I see the RxD LED on the UpBoard side adapter BUT my program below is waiting for dataAvailable... I am using pin 8 Tx and pin 10 Rx, pin 1 or 2 for Vcc and pin 6 GND .... any help would be appreciated!!!
import mraa
import sys
import timeclass RS485(object) :
TODO
#define UART parameters
BAUD_RATE = 9600 #115200
BYTE_SIZE = 8
PARITY = 'N'
STOP_BITS = 1
RTSCTS = False #True
XONXOFF = False
BREAK_DURATION = 30 # Check OSDP specdef __init__(self): """ TODO """ print("mraa version : {}".format(mraa.getVersion()) ) mraa.init() print("In UART init") # initialise UART self.uart = mraa.Uart("/dev/ttyS4") print ("/dev/ttyS4 Uart initialized") device_path = self.uart.getDevicePath() print("device path is : {}".format(device_path) ) # Set UART parameters self.uart.setBaudRate(RS485.BAUD_RATE) print("baudrate set") self.uart.setMode(RS485.BYTE_SIZE, mraa.UART_PARITY_NONE, RS485.STOP_BITS) print("setmode complete") self.uart.setFlowcontrol(RS485.XONXOFF, RS485.RTSCTS) print("setFlowControl complete") print("done with UART class instantiation")
def main():
Entry point of program
rs485 = RS485()
print("returned from init")# Start a neverending loop waiting for data to arrive. # Press Ctrl+C to get out of it. while True: data_ready = rs485.uart.dataAvailable() print ("data_ready = {}".format(data_ready) ) if data_ready: # We are doing 1-byte reads here data_byte = rs485.uart.readStr(1) print(data_byte) # Just a two-way half-duplex communication example, "X" is a flag if data_byte == "X": rs485.uart.writeStr("Yes, master!")
# else:
# rs485.uart.writeStr("Hi!")time.sleep(0.5)
if name == "main":
sys.exit(main()) -
Taking the idea from another thread, I isolated everything except the UART, connected UART_tx and UART-Rx pins 6 & 8 and ran sudo echo "hello world" /dev/ttyS4 and from another terminal ran sudo cat -v /dev/ttyS4 and nothing is received ... Does this mean my UART is bad?
Hi @KahrenA ,
Could you please confirm the BIOS version and the kernel version?
1. uname -a
2. cat /etc/*release
3. dmesg | grep BIOS -
thank you for your quick response... below are what you asked for ...
uname -a
Linux kahren-UP-APL01 4.15.0-37-generic #40~upboard03-Ubuntu SMP Wed Dec 12 16:21:24 UTC 2018 x86_64 x86_64 x86_64 GNU/Linuxcat /etc/*release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=16.04
DISTRIB_CODENAME=xenial
DISTRIB_DESCRIPTION="Ubuntu 16.04.6 LTS"
NAME="Ubuntu"
VERSION="16.04.6 LTS (Xenial Xerus)"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Ubuntu 16.04.6 LTS"
VERSION_ID="16.04"
HOME_URL="http://www.ubuntu.com/"
SUPPORT_URL="http://help.ubuntu.com/"
BUG_REPORT_URL="http://bugs.launchpad.net/ubuntu/"
VERSION_CODENAME=xenial
UBUNTU_CODENAME=xenialdmesg | grep BIOS
[ 0.000000] e820: BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000003efff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000003f000-0x000000000003ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000040000-0x000000000009dfff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009e000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000000fffffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000010000000-0x0000000012150fff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000012151000-0x0000000077b38fff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000077b39000-0x0000000079c56fff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000079c57000-0x0000000079c6bfff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x0000000079c6c000-0x0000000079ccbfff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x0000000079ccc000-0x000000007a024fff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000007a025000-0x000000007a070fff] type 20
[ 0.000000] BIOS-e820: [mem 0x000000007a071000-0x000000007a3defff] usable
[ 0.000000] BIOS-e820: [mem 0x000000007a3df000-0x000000007a3dffff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000007a3e0000-0x000000007a409fff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000007a40a000-0x000000007a964fff] usable
[ 0.000000] BIOS-e820: [mem 0x000000007a965000-0x000000007a966fff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000007a967000-0x000000007affffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000007b000000-0x000000007fffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000d0000000-0x00000000d0ffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fe042000-0x00000000fe044fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fe900000-0x00000000fe902fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed01000-0x00000000fed01fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000017fffffff] usable
[ 0.000000] efi: ACPI=0x79c5e000 ACPI 2.0=0x79c5e000 SMBIOS=0x79edd000 SMBIOS 3.0=0x79edc000
[ 0.000000] SMBIOS 3.0.0 present.
[ 0.000000] DMI: AAEON UP-APL01/UP-APL01, BIOS UPA1AM21 09/01/2017
[ 0.000000] Calgary: detecting Calgary via BIOS EBDA area
[ 2.504180] intel_idle: Please enable MWAIT in BIOS SETUP
[ 2.600392] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
kahren@kahren-UP-APL01:~$ -
any obvious issue? should i upgrade my bios? if so to 4.0 or 4.6?
SOLVED!! turns out to be a silly thing.. I need to use ttyS5 and not ttyS4 ... the wiki community pint out page says otherwise... WHY?
http://wiki.up-community.org/Pinout#UART_Example_.231 -
Hi @KahrenA ,
Thank you for the contribution.
We will check it and redefine the UP Wiki example.
