Hung in splash screen "UP bridge the gap"
The splash screen comes up.. but it hangs there. F2, F7, F10 have no effect.
I've tried disconnecting the battery as well.
Suggestions?
poke!
Anyone know how to get back "into" bios setup to I can recovery my boards? -
Hi BJBeare,
Can you give me some information on your board and the steps you tried before getting stuck on the BIOS Splash screen?
Daniele -
I loaded our kernelflinger.efi program and started fastboot.
The problem occurred when I flashed the gpt table with fastboot. Likely something is messed up with the GPT and it is causing bios to hang.
I've ordered a serial cable (I don't have one of those flat connectors around) to see if I can get some additional debug from the board. -
BJBeare wrote:poke!
I had a similar situation and I could recover by disconnecting the backup battery and waiting 15 minutes before rebooting... hope it helps -
Something along those lines seems to work...
I'm not entirely certain of the procedure, but the following got the board back:
1. disconnect power and battery
2. wait an hour
3. reconnect battery then power
4. system still appears hung.... BUT after a long time (at least :30 minutes), the boot to the bios prompt completed
5. after flashing a good .gpt on the emmc... the hang issue disappeared. -
I am glad that you sorted the issue with the suggestions from MarcFinns.
We will add these notes in the FAQs sections we are creating on the UP Wiki.
thanks! -
Resurrecting this old topic.
We also had this problem. The Up behaved as follows:
With a HDMI + keyboard connected, the Up booted into the logo screen, but the normal "SETUP" text at the top right corner didn't appear. The Up was stuck in this state for a good while before rebooting again, but this time the SETUP text appeared. The Up then got stuck again.
Removing CMOS battery did nothing, nor did using a battery from a working Up.
I inserted a BIOS update USB stick and did the whole thing again, pressing F7 a few times and waited for the 10-15 mins the Up took to get past the logo screen. The boot menu appeared, I chose the USB stick, the Up booted back to the logo screen, but this time the "SETUP" text appeared. I repeated the procedure and successfully booted to the USB stick's EFI shell.
I updated the BIOS from UPC1BMOS to UPC1DM11. The same hang happened.
Then I copied the BIOS settings over from another Upboard using AfuEfix64.efi. This didn't fix the issue, although the new BIOS settings clearly were loaded as the LEDs turned on.
I booted to a Clonezilla live system from USB. The boot into Clonezilla took about as long as the boot through the BIOS logo screen. There I made the following observations:
- Kernel logs show:
mmcblk0: error -110 sending stop command, original cmd response 0x2000900, card status 0x2400900among other errors. See kern.log lsblk -blists the eMMC, but shows its size as 8192 bytesfdisk -ltakes a very long time to complete and does not list the eMMCwipefs /dev/mmcblk0takes a few seconds to run, but completes without erroraparted /dev/mmcblk0 mklabel gpttakes a long time to run and returns with: "error: Device too small for GPT"
My guess is: Broken eMMC, RMA it?
Delicode Ltd - https://www.delicode.com/
- Kernel logs show:
Hi Jesse,
Yes I think you should proceed for RMA
I have the same problem
Should i proceed for RMA too ? I have serial cable but no information during boot... -
Have you tried all the options described in this topic, including the suggestions in our wiki?
https://wiki.up-community.org/FAQs#Not_Booting_or_Powering_up
If you did and the board does not work, you should apply for RMA
i did it, the board sn C19418996 does not work. My reseller send me free ( very good reseller ) another board with sn C19418995, very closed sn number. From this reseller i have bought three other board sn C19419001, sn C19419062, and another without serial number and with BIOS UPC1BM0S 06/04/2016 . I install ubuntu 16.04.6 on last board sn C19418995, starting ok. Reboot same problem no way now its blackscreen no logo screen, may be a component serial bug ? I do the same work with other boards 9001, 9062 and nosn, no problem they work perfectly. I don't understand. -
