[SOLVED] Intel Wireless Cards are not recognizede by UP2
Hi !
I am using some Intel Wireless Cards on the up2 m.2 pci-ex port, running ubuntu server 18.04.
I tried three kinds of Intel wireless cards.
1) Intel AC3165ngw
I tried AC3165 many times.
When I tried, UP2 recognize this card every time and there is no problem!!
2) Intel AC8265ngw
UP2 recognize AC8265, but it has a problem.
After we use "reboot command", up2 can't recognize this card...
We have to do "Hardware reset" so that recognize this card again.
Is there a some problem in "Software reset"?
3) Intel AC9260ngw
UP2 don't recognize AC9260...
I tried a lot of methods but the up2 don't recognize this card.
I moved BIOS menu and changed Trusted Computing from Enable to Disable, but their problems about wireless weren't improved.
Is there a problem in initialization of mini pci-ex port?
Thank you ![]()
Hi @takochan ,
As you can see in the UP Shop site for UP2 board the only two official WiFi cards are:
https://up-shop.org/up-peripherals/280-ups-wifi-kit.html
https://up-shop.org/up-peripherals/239-m2-2230-wifi-kit-2t2r-for-up-squared-metal-chassis.htmlOne of them already tested for you sucessfully.
Other WiFi cards are not supported officially.
Hi @emutex ,
Thank you for teaching me about WiFi cards supported officially
!!Will many WiFi cards be supported officiallly or not in the near future??
I hope we will be able to use many WiFi cards♪ -
Hi @takochan ,
Unfortunately, There is not any plan in the near future for more WiFi card support.
