Any guesses what this is about
Chris Botha
New Member Posts: 48
yet another failure to add to the list
Wont Boot without first resetting bios
Screen underpowered and browns out
windows has half baked api
Now. Linux built specifically for the board, wont boot.. after appearing to install completely (bar the well documented issue detecting networks)
is it possible that someone can please tell me what this fresh hell is with this board?
https://goo.gl/photos/n1k1aUfsiSE2RbYK7
(it wont even boot into linux recovery mode....)
I seriously think you guys should pull the current KickStarter and instead launch one to find coders that can finish all the half finished work you started...
Hi CeeBee,
Thanks for providing useful information for the debugging of your issue.
The network issue happens if you try to install the system with both the wifi and the ethernet connected. Also the WiFi dongle may not work reliably with some WiFi network as it requires a firmware update.
If that happens my suggestion is to install the system without network, then plug either the ethernet or the WiFi to download and install an updated WiFi firmware as described in our wiki: https://up-community.org/wiki/Wireless
Linux is not booting as you are using the MIPI LCD which is currently not supported on Linux.
We are working on an eDP version which instead is fully supported on all OSes.
You can try to install ubilinux or ubuntu with a standard TV or HDMI monitor or via serial after setting up the system as described in the wiki: https://up-community.org/wiki/Serial_console#10-pin_connector_CN7_.28UART0.29
- 105 Announcements & News
- 185 Welcome Developers!
- 49 Tech Updates
- 693 UP Products
- 11 UP 7000
- 10 UP Xtreme i12
- 11 UP Squared Pro 7000
- 19 UP Squared V2
- 59 UP 4000
- 35 UP Squared 6000
- 60 UP Squared Pro
- 143 UP Xtreme
- 837 UP Squared
- 222 UP Core
