Ubilinux/ Ubuntu booting problem with 10.1" LCD Touch Panel + UP Board
Atul Vaze
Atul Vaze New Member Posts: 5 ✭
Recently I have purchased 10.1" LCD Touch Panel and UP Board with 2GB Memory /16GB eMMC storage.
My order ref is ZSDUQOGVJ
Following the instructions from "KIT-101JDHX30BP1U1 Assembly Guide Rev01.pdf" I have assembled the LCD Touch Screen with UP Board.
I connected the HDMI monitor and after power on -> BIOS Settings->Chipset->North Bridge-> Panel ->Enabled.
Selected the resolution as 1280x800
Saved the settings and then LCD started working.
I have downloaded the Ubilinux Ubuntu ISO Image and tried to install on UP Board.
( I have downloaded the image for UP Board community-downloads "ubilinux-3.0.iso"
After the installation was complete and system was re-started it was booting and was stuck as shown in the images attached.
After this I disconnected the LCD Touch Panel from UP Board.
I connected the HDMI monitor.
Then I again entered the BIOS settings and disabled Panel mode.
The system was booted properly without any issue.
This shows there is a issue when Panel is enabled and LCD Touch Panel is connected
Can you help me to resolve this issue?
Do you need any other information?
Atul Vaze
Akshay Microprocessors Pvt Ltd
Pune,INDIA
