[SOLVED] Unable to install Ubuntu
We're following the Wiki instructions to install Ubuntu-16.04.1 and able to reach the boot menu and select "Install Ubuntu". However, a few seconds later we get these messages:
efi: requested map not found.
esrt: ESRT header is not in the memory map.
i8042: Can't read CTR while initializing i8042
And a little bit after the above messages appear, we get a blank green screen and the installation never completes. We tried with multiple different brand new USB sticks and used rufus to make them uefi bootable. We also tried with Ubuntu-14.04.4, but we got the same failure result.
Interestingly enough I was unable to install the ubilinux from the files here, it fails on detect network, from a working network cable in the board, then of course everything network related fails after that. I was keen to try out the rpi.gpio install as I seem to be going nowhere fast with the windows api. ..
Notice that the above it's just a temporary workaround to allow you to complete the Ubuntu installation. Once Ubuntu is installed, then you need to set the 'nomodeset' permanently by adding this option to the /etc/default/grub file. Otherwise, you will get the blank screen again.
Immediately after the UP splash screen appears during boot, press and hold the ESC key. In the Password dialog, don't type anything; just press Enter. Then press ESC again, select Yes, and quickly press and release the ESC key. That will bring you the GRUB menu. Select the 'Advanced options for Ubuntu' and select the (recovery mode) option. Then just resume the boot up; which will allow you to reach the Ubuntu desktop. Open the Terminal and do the following:
sudo nano /etc/default/grub
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash nomodeset"
then save it
sudo update-grub
Reboot
After rebooting, execute these final steps.
I hope this helps others trying to install Ubuntu on the UP-board. Please post here if you know a different workaround.
Look at my post here where I am facing the same problems but I was not able to solve them.
I purchased an UpBoard 2/32 with the recommended 10.1" screen connected via MIPI-DSI.
To make it run you have to enable it from the BIOS under the "Northern Bridge" menu.
Then I tested the UpBoard using a HDMI cable on a standard PC Monitor and...
BE AWARE IF YOU CONNECT YOUR UpBoard USING THE HDMI CABLE TO AN EXTERNAL SCREEN MAKE SURE YOU DISABLE THE MIPI-DSI OUTPUT!
The side effect if that Ubilinux and Ubuntu will become unstable close to unusable!
Manufacturers should take this tip into account to notify the user or either fix the issue.
The version 16 seems to be more stable. The MIPI-DSI is disabled but I cannot install the distribution. When I get to the last menu entry and I click INSTALL, the hdmi sends crap and I can't see nothing anymore.
