RPi.GPIO for Python 3
Thomas Grzesitza
New Member Posts: 4 ✭
i have install RPi.GPIO with.
and get this massage now.
Is there a other version for the UP Board or what can i do in this reason ?
apt-get install python3-pip pip3 install RPi.GPIO
[�[1;32mINFO�[0m ] [Logger ] Record log in /root/.kivy/logs/kivy_16-09-15_13.txt
[�[1;32mINFO�[0m ] [Kivy ] v1.9.2-dev0
[�[1;32mINFO�[0m ] [Python ] v3.4.2 (default, Oct 8 2014, 10:45:20)
[GCC 4.9.1]
[�[1;32mINFO�[0m ] [Factory ] 193 symbols loaded
[�[1;32mINFO�[0m ] [Image ] Providers: img_tex, img_dds, img_gif, img_pygame (img_pil, img_ffpyplayer ignored)
[�[1;32mINFO�[0m ] [Text ] Provider: pygame
File "/home/fischer/main.py", line 13, in <module>
import RPi.GPIO as GPIO
File "/usr/local/lib/python3.4/dist-packages/RPi/GPIO/__init__.py", line 23, in <module>
from RPi._GPIO import *
RuntimeError: This module can only be run on a Raspberry Pi!
If you're running ubilinux, we have included a modified version of RPi.GPIO for UP. It's pre-installed.
We don't have plans to package this for other distros at this time.
What distro are you currently using on UP?
You might be able to take the ubilinux package manually from here and install it on your distro:
http://ubilinux.org/ubilinux/pool/main/r/rpi-gpio/ -
hey dan , I'm trying to install the gpio package manually but I ran into a few problems.
Could you please help me to find the way to install it.
I tried to install the gpio python library from the link post befort, here wat I got:
Python 2.7.9 (default, Aug 13 2016, 16:41:35)
[GCC 4.9.2] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import RPi.GPIO
File "<stdin>", line 1, in <module>
Thanks in advance.
