Pygame?
I got my Up Board up and running with no problems - wow, this thing is FAST. I own a very large number of other Linux based SBC's and this one is amazing so far.
I installed the latest ubilinux image and I am having some problems with Pygame. I have run apt-get update and apt-get dist-upgrade. I installed pygame with "sudo apt-get install python-pygame". However, when running a simple script that plots Sierpinski's triangle the screen simply goes blank. I know this script works as I have run it on a lot of different computers. In fact, it is one of the scripts I use to get my students interested in Python programming.
The script appears below. Any help would be appreciated.
#Simple Python 2 script by David Culp (dwculp@gmail.com) that uses a chaos algorithm to plot Sierpinski's triangle
import pygame, random, sys
#change these to suit your screen
SCREEN_WIDTH = 800
SCREEN_HEIGHT = 600
num_iterations = int(raw_input("How many iterations do you want? "))
pygame.init()
screen = pygame.display.set_mode((SCREEN_WIDTH, SCREEN_HEIGHT))
screen.fill( (0,0,0) )
ax = 0
ay = SCREEN_HEIGHT
bx = SCREEN_WIDTH
by = SCREEN_HEIGHT
cx = SCREEN_WIDTH/2
cy = 0
px = ax
py = ay
print "Calculating, please wait......\n\n"
for n in range(1, num_iterations+1):
    vx = random.randrange(0,3)
    if vx == 0:
        px = (px + ax) / 2
        py = (py + ay) / 2
        red = 255
        green = 0
        blue = 0
    elif vx == 1:
        px = (px + bx) / 2
        py = (py + by) / 2
        red = 0
        green = 0
        blue = 255
    else:
        px = (px + cx) / 2
        py = (py + cy) / 2
        red = 0
        green = 255
        blue = 0
    screen.set_at( (px, py), (red,green,blue) )
    if n%10000 == 0: sys.stdout.write('.')
    if n%100000 == 0: print '|'+str(n)+'\n'
pygame.display.update()
print "\nDone!"
while True:
    for event in pygame.event.get():
        if event.type == pygame.QUIT:
            pygame.quit()
            sys.exit()
        if event.type == pygame.KEYDOWN:
            if event.key == pygame.K_ESCAPE:
                pygame.quit()
                sys.exit()
  • Hi daveculp,
    Thanks for you feedback about your experience with the UP Board.
    About the pygame, could you try to change the resolution to 1920x1080 on the following section?
    SCREEN_WIDTH = 800
    SCREEN_HEIGHT = 600
  • It doesn't work, the screen still blanks. The actual problem is in the call to pygame.init() which doesn't set a screen resolution, it only initializes pygame.
    I will see if I can compile pygame from source this weekend instead of installing it from the repo and see if that fixes it.
  • I compiled Pygame from source and installed and I get the same thing - a black screen.
    Anyone willing to give pygame a try? Install pygame with:
    Then fire up python and try the following at the python prompt:
    >>>import pygame
    >>>pygame.init()
    See if the screen blanks.
  • i get this.
    :~$ python
    Python 2.7.9 (default, Mar  1 2015, 12:57:24)
    [GCC 4.9.2] on linux2
    Type "help", "copyright", "credits" or "license" for more information.
    >>> import pygame
    >>> pygame.init()
    (6, 0)
    hope it helps
  • Thanks. So no screen blanking then?
    I actually get the same output except my screen goes blank and the monitor loses signal. I can then press ESC and blindly type "quit()" into the python command prompt. I get my monitor signal back and the exact same output you have. The return of "(6, 0)" indicates that pygame was able to init 6 subsystems and failed on 0. Although now that I think about it, I wonder if my output was (0,6).
    My next steps to figure this out are:
    1. Swap in a different monitor. I didn't think pygame.init() actually did anything at all with switching resolution and I know pygame works with some other Linux systems I have with this monitor but you never know.
    2. Reinstall Ubilinux.
    3. Try Ubuntu
  • Solved.
    It was the monitor. I swapped out with a newer model and it works great.
