DirectX issue with lower resolution
Korneliusz
New Member Posts: 24 ✭
I found some issue with DirectX applications on Windows 10.
When application set in lower resolution than 1920x1080 (eg. 1280x720 / fullscreen mode), graphics driver reset screen resolution to 1920x1080 and display application in centered position.
Setting the resolution to 1280x720 for desktop does not help, running application still reset resolution to 1920x1080
Tested on stock drivers 20.19.15.3201 and newest 20.19.15.444 from Intel
I can confirm that behavior : I have the exact same problem.
Any informations?
Hi Santyago,
I think 1920*1080 should be the game's lowest suggestion resolution, so it will switch back even if you has set 1920*1080 resolution in graphic driver. You can try to adjust some possible scaling setting under "Intel HD graphic control panel" from "Application settings" to "Driver settings" to see if change setting works.
Or might be the compatibility issue between the game and DirectX 12, you can test if the game can run 1280*720 resolution under Windows 10 with DirectX 12 on other platform. -
Hi Santyago,
I have the same problem too. Doesn't seems to be a solution about this.
