Cases
Kenneth Coley
Posts: 37 ✭
in Chassis
Does the current case on the website fit the board with the new bottom heat spreader? Are there cad files for the current case design.
The RPI cases do not work for obvious reasons of different connector placement.
Yes. For current design, there is a bottom plate working as a heat spreader. You may not be able to use RPi case. We will release 3D drawing with UP board+ heatsink soon.
Any update on case options for UP? I have my 3D printer ready to go once I can find an STL file.
You can find it here: https://up-community.org/forum/general-discussion/313-print-your-up-board-chassis
Anyone else looking for a case? I found a high quality 3D printing house who can make them for $100 each, I just need at least two other people to start the order since they have a $250 minimum order.
