File system error / Switch to RO
Aimache
I've installed my up-board for a week, using the very last available release of Ubilinux from the Up website.
The system is up-to-date.
For 2 days, I encounter filesystem issues, leading to / beeing mounted as read only.
I cannot find the root cause.
Here are the logs from dmesg :
[code]
[ 3468.354858] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[ 4317.009160] perf interrupt took too long (2516 > 2500), lowering kernel.perf_event_max_sample_rate to 50000
[ 7224.234018] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[ 7498.431114] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[ 8722.950111] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[ 8732.966896] mmc0: Timeout waiting for hardware interrupt.
[ 8732.974947]
[ cut here ]
[ 8732.974985] WARNING: CPU: 0 PID: 0 at /tmp/buildd/linux-ubilinux-4.4.13/drivers/mmc/host/sdhci.c:1017 sdhci_send_command+0x770/0xc30 [sdhci]()
[ 8732.974994] Modules linked in: nfsd auth_rpcgss oid_registry nfs_acl nfs lockd grace fscache sunrpc sg sd_mod sr_mod cdrom intel_rapl intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul nls_utf8 nls_cp437 vfat fat jitterentropy_rng hdmi_audio cdc_acm sha256_ssse3 sha256_generic hmac drbg ansi_cprng iTCO_wdt dwc3 iTCO_vendor_support udc_core spidev evdev aesni_intel aes_x86_64 lrw gf128mul glue_helper ablk_helper cryptd i915 efi_pstore option usb_wwan efivars snd_pcm usb_storage snd_timer snd scsi_mod ftdi_sio usbserial soundcore ti_adc081c drm_kms_helper iosf_mbi drm lpc_ich dwc3_pci shpchp mfd_core 8250_fintek i2c_algo_bit video industrialio battery spi_pxa2xx_platform tpm_crb pwm_lpss_platform pwm_lpss int3400_thermal tpm_tis int3403_thermal tpm acpi_thermal_rel int340x_thermal_zone
[ 8732.975263] ac acpi_pad button processor i2c_dev fuse parport_pc ppdev lp parport autofs4 ext4 crc16 mbcache jbd2 hid_generic usbhid hid mmc_block crc32c_intel xhci_pci xhci_hcd r8169 mii usbcore usb_common thermal fjes sdhci_acpi sdhci mmc_core
[ 8732.975372] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.4.0-ubi3-amd64 #1 Debian 4.4.13-1
[ 8732.975382] Hardware name: AAEON UP-CHT01/UP-CHT01, BIOS UPC1BM0S 06/04/2016
[ 8732.975393] 0000000000000086 cb11619bc5cd881a ffffffff81306017 0000000000000000
[ 8732.975413] ffffffffa0096460 ffffffff8107d143 ffff88005a808540 ffff880036d32ad8
[ 8732.975431] 000000000000003d 0000000000000001 ffff88005a808540 ffffffffa0093820
[ 8732.975448] Call Trace:
[ 8732.975458] <IRQ> [<ffffffff81306017>] ? dump_stack+0x5c/0x85
[ 8732.975499] [<ffffffff8107d143>] ? warn_slowpath_common+0x83/0xc0
[ 8732.975524] [<ffffffffa0093820>] ? sdhci_send_command+0x770/0xc30 [sdhci]
[ 8732.975547] [<ffffffffa0090b65>] ? sdhci_reset+0x55/0xc0 [sdhci]
[ 8732.975568] [<ffffffffa0094594>] ? sdhci_finish_data+0xf4/0x340 [sdhci]
[ 8732.975590] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[ 8732.975612] [<ffffffffa009485a>] ? sdhci_timeout_timer+0x7a/0xb0 [sdhci]
[ 8732.975630] [<ffffffff810e3a20>] ? call_timer_fn+0x30/0x130
[ 8732.975652] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[ 8732.975668] [<ffffffff810e5736>] ? run_timer_softirq+0x176/0x2d0
[ 8732.975686] [<ffffffff81081d1a>] ? __do_softirq+0x11a/0x2c0
[ 8732.975702] [<ffffffff81082008>] ? irq_exit+0x88/0x90
[ 8732.975719] [<ffffffff815dbaee>] ? smp_apic_timer_interrupt+0x3e/0x50
[ 8732.975737] [<ffffffff815d9de2>] ? apic_timer_interrupt+0x82/0x90
[ 8732.975745] <EOI> [<ffffffff814972ec>] ? cpuidle_enter_state+0x13c/0x2b0
[ 8732.975776] [<ffffffff810bf0c6>] ? cpu_startup_entry+0x346/0x3b0
[ 8732.975797] [<ffffffff81b3af9a>] ? start_kernel+0x487/0x4a8
[ 8732.975814] [<ffffffff81b3a120>] ? early_idt_handler_array+0x120/0x120
[ 8732.975829] [<ffffffff81b3a611>] ? x86_64_start_kernel+0x156/0x17b
[ 8732.975840] ---[ end trace 35a2ee1a4f956540 ]---
[ 8732.978353] mmcblk0: error -110 sending stop command, original cmd response 0x0, card status 0x400900
[ 8732.978439] mmcblk0: error -110 transferring data, sector 6084608, nr 1024, cmd response 0x0, card status 0x0
[ 8732.989713] blk_update_request: I/O error, dev mmcblk0, sector 6084608
[ 8732.997089] blk_update_request: I/O error, dev mmcblk0, sector 6084616
[ 8733.004448] blk_update_request: I/O error, dev mmcblk0, sector 6084624
[ 8733.011788] blk_update_request: I/O error, dev mmcblk0, sector 6084632
[ 8733.019128] blk_update_request: I/O error, dev mmcblk0, sector 6084640
[ 8733.026463] blk_update_request: I/O error, dev mmcblk0, sector 6084648
[ 8733.033801] blk_update_request: I/O error, dev mmcblk0, sector 6084656
[ 8733.041144] blk_update_request: I/O error, dev mmcblk0, sector 6084664
[ 8733.048482] blk_update_request: I/O error, dev mmcblk0, sector 6084672
[ 8733.055818] blk_update_request: I/O error, dev mmcblk0, sector 6084680
[ 8733.071549] EXT4-fs warning (device mmcblk0p3): ext4_end_bio:329: I/O error -5 writing to inode 928423 (offset 0 size 0 starting block 760832)
[ 8733.071561] Buffer I/O error on device mmcblk0p3, logical block 747776
[ 8733.078917] Buffer I/O error on device mmcblk0p3, logical block 747777
[ 8733.086244] Buffer I/O error on device mmcblk0p3, logical block 747778
[ 8733.093582] Buffer I/O error on device mmcblk0p3, logical block 747779
[ 8733.100907] Buffer I/O error on device mmcblk0p3, logical block 747780
[ 8733.108241] Buffer I/O error on device mmcblk0p3, logical block 747781
[ 8733.115559] Buffer I/O error on device mmcblk0p3, logical block 747782
[ 8733.122898] Buffer I/O error on device mmcblk0p3, logical block 747783
[ 8733.130224] Buffer I/O error on device mmcblk0p3, logical block 747784
[ 8733.137551] Buffer I/O error on device mmcblk0p3, logical block 747785
[10536.536969] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[10546.549679] mmc0: Timeout waiting for hardware interrupt.
[10546.557973]
[ cut here ]
[10546.558019] WARNING: CPU: 0 PID: 0 at /tmp/buildd/linux-ubilinux-4.4.13/drivers/mmc/host/sdhci.c:1017 sdhci_send_command+0x770/0xc30 [sdhci]()
[10546.558029] Modules linked in: nfsd auth_rpcgss oid_registry nfs_acl nfs lockd grace fscache sunrpc sg sd_mod sr_mod cdrom intel_rapl intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul nls_utf8 nls_cp437 vfat fat jitterentropy_rng hdmi_audio cdc_acm sha256_ssse3 sha256_generic hmac drbg ansi_cprng iTCO_wdt dwc3 iTCO_vendor_support udc_core spidev evdev aesni_intel aes_x86_64 lrw gf128mul glue_helper ablk_helper cryptd i915 efi_pstore option usb_wwan efivars snd_pcm usb_storage snd_timer snd scsi_mod ftdi_sio usbserial soundcore ti_adc081c drm_kms_helper iosf_mbi drm lpc_ich dwc3_pci shpchp mfd_core 8250_fintek i2c_algo_bit video industrialio battery spi_pxa2xx_platform tpm_crb pwm_lpss_platform pwm_lpss int3400_thermal tpm_tis int3403_thermal tpm acpi_thermal_rel int340x_thermal_zone
[10546.558407] ac acpi_pad button processor i2c_dev fuse parport_pc ppdev lp parport autofs4 ext4 crc16 mbcache jbd2 hid_generic usbhid hid mmc_block crc32c_intel xhci_pci xhci_hcd r8169 mii usbcore usb_common thermal fjes sdhci_acpi sdhci mmc_core
[10546.558562] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G W 4.4.0-ubi3-amd64 #1 Debian 4.4.13-1
[10546.558573] Hardware name: AAEON UP-CHT01/UP-CHT01, BIOS UPC1BM0S 06/04/2016
[10546.558585] 0000000000000086 cb11619bc5cd881a ffffffff81306017 0000000000000000
[10546.558607] ffffffffa0096460 ffffffff8107d143 ffff88005a808540 ffff880036d32ad8
[10546.558625] 000000000000003d 0000000000000001 ffff88005a808540 ffffffffa0093820
[10546.558644] Call Trace:
[10546.558655] <IRQ> [<ffffffff81306017>] ? dump_stack+0x5c/0x85
[10546.558700] [<ffffffff8107d143>] ? warn_slowpath_common+0x83/0xc0
[10546.558725] [<ffffffffa0093820>] ? sdhci_send_command+0x770/0xc30 [sdhci]
[10546.558747] [<ffffffffa0090b65>] ? sdhci_reset+0x55/0xc0 [sdhci]
[10546.558769] [<ffffffffa0094594>] ? sdhci_finish_data+0xf4/0x340 [sdhci]
[10546.558791] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[10546.558813] [<ffffffffa009485a>] ? sdhci_timeout_timer+0x7a/0xb0 [sdhci]
[10546.558833] [<ffffffff810e3a20>] ? call_timer_fn+0x30/0x130
[10546.558854] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[10546.558874] [<ffffffff810e5736>] ? run_timer_softirq+0x176/0x2d0
[10546.558892] [<ffffffff81081d1a>] ? __do_softirq+0x11a/0x2c0
[10546.558908] [<ffffffff81082008>] ? irq_exit+0x88/0x90
[10546.558927] [<ffffffff815dbaee>] ? smp_apic_timer_interrupt+0x3e/0x50
[10546.558946] [<ffffffff815d9de2>] ? apic_timer_interrupt+0x82/0x90
[10546.558955] <EOI> [<ffffffff814972ec>] ? cpuidle_enter_state+0x13c/0x2b0
[10546.558990] [<ffffffff810bf0c6>] ? cpu_startup_entry+0x346/0x3b0
[10546.559012] [<ffffffff81b3af9a>] ? start_kernel+0x487/0x4a8
[10546.559030] [<ffffffff81b3a120>] ? early_idt_handler_array+0x120/0x120
[10546.559045] [<ffffffff81b3a611>] ? x86_64_start_kernel+0x156/0x17b
[10546.559058] ---[ end trace 35a2ee1a4f956541 ]---
[10546.561488] mmcblk0: error -110 sending stop command, original cmd response 0x0, card status 0x400900
[10546.561589] mmcblk0: error -110 transferring data, sector 6084608, nr 1024, cmd response 0x0, card status 0x0
[10546.573012] blk_update_request: 118 callbacks suppressed
[10546.573020] blk_update_request: I/O error, dev mmcblk0, sector 6084608
[10546.580491] blk_update_request: I/O error, dev mmcblk0, sector 6084616
[10546.587961] blk_update_request: I/O error, dev mmcblk0, sector 6084624
[10546.595417] blk_update_request: I/O error, dev mmcblk0, sector 6084632
[10546.602808] blk_update_request: I/O error, dev mmcblk0, sector 6084640
[10546.610199] blk_update_request: I/O error, dev mmcblk0, sector 6084648
[10546.617589] blk_update_request: I/O error, dev mmcblk0, sector 6084656
[10546.624977] blk_update_request: I/O error, dev mmcblk0, sector 6084664
[10546.632373] blk_update_request: I/O error, dev mmcblk0, sector 6084672
[10546.639766] blk_update_request: I/O error, dev mmcblk0, sector 6084680
[10546.650972] EXT4-fs warning (device mmcblk0p3): ext4_end_bio:329: I/O error -5 writing to inode 928423 (offset 0 size 0 starting block 760732)
[10546.650992] buffer_io_error: 246 callbacks suppressed
[10546.651008] Buffer I/O error on device mmcblk0p3, logical block 747776
[10546.658582] Buffer I/O error on device mmcblk0p3, logical block 747777
[10546.665973] Buffer I/O error on device mmcblk0p3, logical block 747778
[10546.673362] Buffer I/O error on device mmcblk0p3, logical block 747779
[10546.680755] Buffer I/O error on device mmcblk0p3, logical block 747780
[10546.688147] Buffer I/O error on device mmcblk0p3, logical block 747781
[10546.695536] Buffer I/O error on device mmcblk0p3, logical block 747782
[10546.702926] Buffer I/O error on device mmcblk0p3, logical block 747783
[10546.710315] Buffer I/O error on device mmcblk0p3, logical block 747784
[10546.717706] Buffer I/O error on device mmcblk0p3, logical block 747785
[11081.584787] perf interrupt took too long (5014 > 5000), lowering kernel.perf_event_max_sample_rate to 25000
[11097.216489] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[11158.065247] tun: Universal TUN/TAP device driver, 1.6
[11158.065266] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[13333.364185] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[19257.268132] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[19995.357814] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[20005.370527] mmc0: Timeout waiting for hardware interrupt.
[20005.378635]
[ cut here ]
[20005.378653] WARNING: CPU: 1 PID: 0 at /tmp/buildd/linux-ubilinux-4.4.13/drivers/mmc/host/sdhci.c:1017 sdhci_send_command+0x770/0xc30 [sdhci]()
[20005.378656] Modules linked in: tun nfsd auth_rpcgss oid_registry nfs_acl nfs lockd grace fscache sunrpc sg sd_mod sr_mod cdrom intel_rapl intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul nls_utf8 nls_cp437 vfat fat jitterentropy_rng hdmi_audio cdc_acm sha256_ssse3 sha256_generic hmac drbg ansi_cprng iTCO_wdt dwc3 iTCO_vendor_support udc_core spidev evdev aesni_intel aes_x86_64 lrw gf128mul glue_helper ablk_helper cryptd i915 efi_pstore option usb_wwan efivars snd_pcm usb_storage snd_timer snd scsi_mod ftdi_sio usbserial soundcore ti_adc081c drm_kms_helper iosf_mbi drm lpc_ich dwc3_pci shpchp mfd_core 8250_fintek i2c_algo_bit video industrialio battery spi_pxa2xx_platform tpm_crb pwm_lpss_platform pwm_lpss int3400_thermal tpm_tis int3403_thermal tpm acpi_thermal_rel
[20005.378746] int340x_thermal_zone ac acpi_pad button processor i2c_dev fuse parport_pc ppdev lp parport autofs4 ext4 crc16 mbcache jbd2 hid_generic usbhid hid mmc_block crc32c_intel xhci_pci xhci_hcd r8169 mii usbcore usb_common thermal fjes sdhci_acpi sdhci mmc_core
[20005.378784] CPU: 1 PID: 0 Comm: swapper/1 Tainted: G W 4.4.0-ubi3-amd64 #1 Debian 4.4.13-1
[20005.378787] Hardware name: AAEON UP-CHT01/UP-CHT01, BIOS UPC1BM0S 06/04/2016
[20005.378791] 0000000000000086 cfc76b7e00b2bb9b ffffffff81306017 0000000000000000
[20005.378797] ffffffffa0096460 ffffffff8107d143 ffff88005a808540 ffff880036d32ad8
[20005.378802] 0000000000000001 0000000000000001 ffff88005a808540 ffffffffa0093820
[20005.378807] Call Trace:
[20005.378811] <IRQ> [<ffffffff81306017>] ? dump_stack+0x5c/0x85
[20005.378826] [<ffffffff8107d143>] ? warn_slowpath_common+0x83/0xc0
[20005.378833] [<ffffffffa0093820>] ? sdhci_send_command+0x770/0xc30 [sdhci]
[20005.378839] [<ffffffffa0090b65>] ? sdhci_reset+0x55/0xc0 [sdhci]
[20005.378846] [<ffffffffa0094594>] ? sdhci_finish_data+0xf4/0x340 [sdhci]
[20005.378852] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[20005.378858] [<ffffffffa009485a>] ? sdhci_timeout_timer+0x7a/0xb0 [sdhci]
[20005.378864] [<ffffffff810e3a20>] ? call_timer_fn+0x30/0x130
[20005.378870] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[20005.378875] [<ffffffff810e5736>] ? run_timer_softirq+0x176/0x2d0
[20005.378880] [<ffffffff81081d1a>] ? __do_softirq+0x11a/0x2c0
[20005.378885] [<ffffffff81082008>] ? irq_exit+0x88/0x90
[20005.378891] [<ffffffff815dbaee>] ? smp_apic_timer_interrupt+0x3e/0x50
[20005.378896] [<ffffffff815d9de2>] ? apic_timer_interrupt+0x82/0x90
[20005.378899] <EOI> [<ffffffff814972ec>] ? cpuidle_enter_state+0x13c/0x2b0
[20005.378908] [<ffffffff814972c7>] ? cpuidle_enter_state+0x117/0x2b0
[20005.378914] [<ffffffff810bf0c6>] ? cpu_startup_entry+0x346/0x3b0
[20005.378918] [<ffffffff810f39ab>] ? tick_check_new_device+0xcb/0xf0
[20005.378924] [<ffffffff81050602>] ? start_secondary+0x152/0x190
[20005.378928] ---[ end trace 35a2ee1a4f956542 ]---
[20005.382068] mmcblk0: error -110 sending stop command, original cmd response 0x0, card status 0x400900
[20005.382105] mmcblk0: error -110 transferring data, sector 34228416, nr 8, cmd response 0x0, card status 0x0
[20005.393181] blk_update_request: 118 callbacks suppressed
[20005.393201] blk_update_request: I/O error, dev mmcblk0, sector 34228416
[20005.400723] EXT4-fs warning (device mmcblk0p3): ext4_end_bio:329: I/O error -5 writing to inode 787964 (offset 0 size 0 starting block 4278553)
[20005.400730] buffer_io_error: 146 callbacks suppressed
[20005.400735] Buffer I/O error on device mmcblk0p3, logical block 4265752
[28529.362318] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[28530.362408] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[28540.371155] mmc0: Timeout waiting for hardware interrupt.
[28540.379435]
[ cut here ]
[28540.379479] WARNING: CPU: 1 PID: 0 at /tmp/buildd/linux-ubilinux-4.4.13/drivers/mmc/host/sdhci.c:1017 sdhci_send_command+0x770/0xc30 [sdhci]()
[28540.379489] Modules linked in: tun nfsd auth_rpcgss oid_registry nfs_acl nfs lockd grace fscache sunrpc sg sd_mod sr_mod cdrom intel_rapl intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul nls_utf8 nls_cp437 vfat fat jitterentropy_rng hdmi_audio cdc_acm sha256_ssse3 sha256_generic hmac drbg ansi_cprng iTCO_wdt dwc3 iTCO_vendor_support udc_core spidev evdev aesni_intel aes_x86_64 lrw gf128mul glue_helper ablk_helper cryptd i915 efi_pstore option usb_wwan efivars snd_pcm usb_storage snd_timer snd scsi_mod ftdi_sio usbserial soundcore ti_adc081c drm_kms_helper iosf_mbi drm lpc_ich dwc3_pci shpchp mfd_core 8250_fintek i2c_algo_bit video industrialio battery spi_pxa2xx_platform tpm_crb pwm_lpss_platform pwm_lpss int3400_thermal tpm_tis int3403_thermal tpm acpi_thermal_rel
[28540.379867] int340x_thermal_zone ac acpi_pad button processor i2c_dev fuse parport_pc ppdev lp parport autofs4 ext4 crc16 mbcache jbd2 hid_generic usbhid hid mmc_block crc32c_intel xhci_pci xhci_hcd r8169 mii usbcore usb_common thermal fjes sdhci_acpi sdhci mmc_core
[28540.380026] CPU: 1 PID: 0 Comm: swapper/1 Tainted: G W 4.4.0-ubi3-amd64 #1 Debian 4.4.13-1
[28540.380037] Hardware name: AAEON UP-CHT01/UP-CHT01, BIOS UPC1BM0S 06/04/2016
[28540.380048] 0000000000000086 cfc76b7e00b2bb9b ffffffff81306017 0000000000000000
[28540.380069] ffffffffa0096460 ffffffff8107d143 ffff88005a808540 ffff880036d32930
[28540.380087] 0000000000000004 0000000000000001 ffff88005a808540 ffffffffa0093820
[28540.380106] Call Trace:
[28540.380117] <IRQ> [<ffffffff81306017>] ? dump_stack+0x5c/0x85
[28540.380163] [<ffffffff8107d143>] ? warn_slowpath_common+0x83/0xc0
[28540.380189] [<ffffffffa0093820>] ? sdhci_send_command+0x770/0xc30 [sdhci]
[28540.380211] [<ffffffffa0090b65>] ? sdhci_reset+0x55/0xc0 [sdhci]
[28540.380234] [<ffffffffa0094594>] ? sdhci_finish_data+0xf4/0x340 [sdhci]
[28540.380255] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[28540.380277] [<ffffffffa009485a>] ? sdhci_timeout_timer+0x7a/0xb0 [sdhci]
[28540.380297] [<ffffffff810e3a20>] ? call_timer_fn+0x30/0x130
[28540.380319] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[28540.380339] [<ffffffff810e5736>] ? run_timer_softirq+0x176/0x2d0
[28540.380357] [<ffffffff81081d1a>] ? __do_softirq+0x11a/0x2c0
[28540.380373] [<ffffffff81082008>] ? irq_exit+0x88/0x90
[28540.380392] [<ffffffff815dbaee>] ? smp_apic_timer_interrupt+0x3e/0x50
[28540.380411] [<ffffffff815d9de2>] ? apic_timer_interrupt+0x82/0x90
[28540.380419] <EOI> [<ffffffff814972ec>] ? cpuidle_enter_state+0x13c/0x2b0
[28540.380449] [<ffffffff814972c7>] ? cpuidle_enter_state+0x117/0x2b0
[28540.380468] [<ffffffff810bf0c6>] ? cpu_startup_entry+0x346/0x3b0
[28540.380485] [<ffffffff810f39ab>] ? tick_check_new_device+0xcb/0xf0
[28540.380502] [<ffffffff81050602>] ? start_secondary+0x152/0x190
[28540.380517] ---[ end trace 35a2ee1a4f956543 ]---
[28540.382700] mmcblk0: error -110 sending stop command, original cmd response 0x0, card status 0x400900
[28540.382769] mmcblk0: error -110 transferring data, sector 6084608, nr 320, cmd response 0x0, card status 0x0
[28540.394267] blk_update_request: I/O error, dev mmcblk0, sector 6084608
[28540.401784] blk_update_request: I/O error, dev mmcblk0, sector 6084616
[28540.409253] blk_update_request: I/O error, dev mmcblk0, sector 6084624
[28540.416702] blk_update_request: I/O error, dev mmcblk0, sector 6084632
[28540.424102] blk_update_request: I/O error, dev mmcblk0, sector 6084640
[28540.431496] blk_update_request: I/O error, dev mmcblk0, sector 6084648
[28540.438885] blk_update_request: I/O error, dev mmcblk0, sector 6084656
[28540.446271] blk_update_request: I/O error, dev mmcblk0, sector 6084664
[28540.453660] blk_update_request: I/O error, dev mmcblk0, sector 6084672
[28540.461070] EXT4-fs warning (device mmcblk0p3): ext4_end_bio:329: I/O error -5 writing to inode 928423 (offset 0 size 0 starting block 760616)
[28540.461078] Buffer I/O error on device mmcblk0p3, logical block 747776
[28540.468473] Buffer I/O error on device mmcblk0p3, logical block 747777
[28540.475862] Buffer I/O error on device mmcblk0p3, logical block 747778
[28540.483254] Buffer I/O error on device mmcblk0p3, logical block 747779
[28540.490642] Buffer I/O error on device mmcblk0p3, logical block 747780
[28540.498043] Buffer I/O error on device mmcblk0p3, logical block 747781
[28540.505443] Buffer I/O error on device mmcblk0p3, logical block 747782
[28540.512848] Buffer I/O error on device mmcblk0p3, logical block 747783
[28540.520236] Buffer I/O error on device mmcblk0p3, logical block 747784
[31222.229442] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[31232.262190] mmc0: Timeout waiting for hardware interrupt.
[31232.270387]
[ cut here ]
[31232.270427] WARNING: CPU: 0 PID: 0 at /tmp/buildd/linux-ubilinux-4.4.13/drivers/mmc/host/sdhci.c:1017 sdhci_send_command+0x770/0xc30 [sdhci]()
[31232.270432] Modules linked in: tun nfsd auth_rpcgss oid_registry nfs_acl nfs lockd grace fscache sunrpc sg sd_mod sr_mod cdrom intel_rapl intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul nls_utf8 nls_cp437 vfat fat jitterentropy_rng hdmi_audio cdc_acm sha256_ssse3 sha256_generic hmac drbg ansi_cprng iTCO_wdt dwc3 iTCO_vendor_support udc_core spidev evdev aesni_intel aes_x86_64 lrw gf128mul glue_helper ablk_helper cryptd i915 efi_pstore option usb_wwan efivars snd_pcm usb_storage snd_timer snd scsi_mod ftdi_sio usbserial soundcore ti_adc081c drm_kms_helper iosf_mbi drm lpc_ich dwc3_pci shpchp mfd_core 8250_fintek i2c_algo_bit video industrialio battery spi_pxa2xx_platform tpm_crb pwm_lpss_platform pwm_lpss int3400_thermal tpm_tis int3403_thermal tpm acpi_thermal_rel
[31232.270750] int340x_thermal_zone ac acpi_pad button processor i2c_dev fuse parport_pc ppdev lp parport autofs4 ext4 crc16 mbcache jbd2 hid_generic usbhid hid mmc_block crc32c_intel xhci_pci xhci_hcd r8169 mii usbcore usb_common thermal fjes sdhci_acpi sdhci mmc_core
[31232.270908] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G W 4.4.0-ubi3-amd64 #1 Debian 4.4.13-1
[31232.270920] Hardware name: AAEON UP-CHT01/UP-CHT01, BIOS UPC1BM0S 06/04/2016
[31232.270931] 0000000000000086 cb11619bc5cd881a ffffffff81306017 0000000000000000
[31232.270952] ffffffffa0096460 ffffffff8107d143 ffff88005a808540 ffff880036d32ad8
[31232.270970] 0000000000000001 0000000000000001 ffff88005a808540 ffffffffa0093820
[31232.270987] Call Trace:
[31232.271000] <IRQ> [<ffffffff81306017>] ? dump_stack+0x5c/0x85
[31232.271046] [<ffffffff8107d143>] ? warn_slowpath_common+0x83/0xc0
[31232.271070] [<ffffffffa0093820>] ? sdhci_send_command+0x770/0xc30 [sdhci]
[31232.271093] [<ffffffffa0090b65>] ? sdhci_reset+0x55/0xc0 [sdhci]
[31232.271115] [<ffffffffa0094594>] ? sdhci_finish_data+0xf4/0x340 [sdhci]
[31232.271137] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[31232.271158] [<ffffffffa009485a>] ? sdhci_timeout_timer+0x7a/0xb0 [sdhci]
[31232.271178] [<ffffffff810e3a20>] ? call_timer_fn+0x30/0x130
[31232.271199] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[31232.271218] [<ffffffff810e5736>] ? run_timer_softirq+0x176/0x2d0
[31232.271237] [<ffffffff81081d1a>] ? __do_softirq+0x11a/0x2c0
[31232.271253] [<ffffffff81082008>] ? irq_exit+0x88/0x90
[31232.271271] [<ffffffff815dbaee>] ? smp_apic_timer_interrupt+0x3e/0x50
[31232.271291] [<ffffffff815d9de2>] ? apic_timer_interrupt+0x82/0x90
[31232.271299] <EOI> [<ffffffff814972ec>] ? cpuidle_enter_state+0x13c/0x2b0
[31232.271335] [<ffffffff810bf0c6>] ? cpu_startup_entry+0x346/0x3b0
[31232.271357] [<ffffffff81b3af9a>] ? start_kernel+0x487/0x4a8
[31232.271375] [<ffffffff81b3a120>] ? early_idt_handler_array+0x120/0x120
[31232.271390] [<ffffffff81b3a611>] ? x86_64_start_kernel+0x156/0x17b
[31232.271403] ---[ end trace 35a2ee1a4f956544 ]---
[31232.274089] mmcblk0: error -110 sending stop command, original cmd response 0x0, card status 0x400900
[31232.274146] mmcblk0: error -110 transferring data, sector 6126952, nr 8, cmd response 0x0, card status 0x0
[31232.287376] blk_update_request: 31 callbacks suppressed
[31232.287381] blk_update_request: I/O error, dev mmcblk0, sector 6126952
[31232.296147] EXT4-fs warning (device mmcblk0p3): ext4_end_bio:329: I/O error -5 writing to inode 928425 (offset 0 size 0 starting block 765870)
[31232.296164] buffer_io_error: 31 callbacks suppressed
[31232.296168] Buffer I/O error on device mmcblk0p3, logical block 753069
[32570.323363] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[35822.583918] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[35832.592499] mmc0: Timeout waiting for hardware interrupt.
[35832.605505]
[ cut here ]
[35832.605550] WARNING: CPU: 3 PID: 0 at /tmp/buildd/linux-ubilinux-4.4.13/drivers/mmc/host/sdhci.c:1017 sdhci_send_command+0x770/0xc30 [sdhci]()
[35832.605560] Modules linked in: tun nfsd auth_rpcgss oid_registry nfs_acl nfs lockd grace fscache sunrpc sg sd_mod sr_mod cdrom intel_rapl intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul nls_utf8 nls_cp437 vfat fat jitterentropy_rng hdmi_audio cdc_acm sha256_ssse3 sha256_generic hmac drbg ansi_cprng iTCO_wdt dwc3 iTCO_vendor_support udc_core spidev evdev aesni_intel aes_x86_64 lrw gf128mul glue_helper ablk_helper cryptd i915 efi_pstore option usb_wwan efivars snd_pcm usb_storage snd_timer snd scsi_mod ftdi_sio usbserial soundcore ti_adc081c drm_kms_helper iosf_mbi drm lpc_ich dwc3_pci shpchp mfd_core 8250_fintek i2c_algo_bit video industrialio battery spi_pxa2xx_platform tpm_crb pwm_lpss_platform pwm_lpss int3400_thermal tpm_tis int3403_thermal tpm acpi_thermal_rel
[35832.605934] int340x_thermal_zone ac acpi_pad button processor i2c_dev fuse parport_pc ppdev lp parport autofs4 ext4 crc16 mbcache jbd2 hid_generic usbhid hid mmc_block crc32c_intel xhci_pci xhci_hcd r8169 mii usbcore usb_common thermal fjes sdhci_acpi sdhci mmc_core
[35832.606093] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G W 4.4.0-ubi3-amd64 #1 Debian 4.4.13-1
[35832.606104] Hardware name: AAEON UP-CHT01/UP-CHT01, BIOS UPC1BM0S 06/04/2016
[35832.606115] 0000000000000086 4868efd746ab5c51 ffffffff81306017 0000000000000000
[35832.606137] ffffffffa0096460 ffffffff8107d143 ffff88005a808540 ffff880036d32930
[35832.606155] 0000000000000001 0000000000000001 ffff88005a808540 ffffffffa0093820
[35832.606172] Call Trace:
[35832.606184] <IRQ> [<ffffffff81306017>] ? dump_stack+0x5c/0x85
[35832.606229] [<ffffffff8107d143>] ? warn_slowpath_common+0x83/0xc0
[35832.606254] [<ffffffffa0093820>] ? sdhci_send_command+0x770/0xc30 [sdhci]
[35832.606276] [<ffffffffa0090b65>] ? sdhci_reset+0x55/0xc0 [sdhci]
[35832.606298] [<ffffffffa0094594>] ? sdhci_finish_data+0xf4/0x340 [sdhci]
[35832.606320] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[35832.606342] [<ffffffffa009485a>] ? sdhci_timeout_timer+0x7a/0xb0 [sdhci]
[35832.606362] [<ffffffff810e3a20>] ? call_timer_fn+0x30/0x130
[35832.606383] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[35832.606402] [<ffffffff810e5736>] ? run_timer_softirq+0x176/0x2d0
[35832.606421] [<ffffffff81081d1a>] ? __do_softirq+0x11a/0x2c0
[35832.606437] [<ffffffff81082008>] ? irq_exit+0x88/0x90
[35832.606455] [<ffffffff815dbaee>] ? smp_apic_timer_interrupt+0x3e/0x50
[35832.606474] [<ffffffff815d9de2>] ? apic_timer_interrupt+0x82/0x90
[35832.606483] <EOI> [<ffffffff814972ec>] ? cpuidle_enter_state+0x13c/0x2b0
[35832.606511] [<ffffffff814972c7>] ? cpuidle_enter_state+0x117/0x2b0
[35832.606531] [<ffffffff810bf0c6>] ? cpu_startup_entry+0x346/0x3b0
[35832.606547] [<ffffffff810f39ab>] ? tick_check_new_device+0xcb/0xf0
[35832.606563] [<ffffffff81050602>] ? start_secondary+0x152/0x190
[35832.606579] ---[ end trace 35a2ee1a4f956545 ]---
[35832.608771] mmcblk0: error -110 sending stop command, original cmd response 0x0, card status 0x400900
[35832.608850] mmcblk0: error -110 transferring data, sector 30053344, nr 8, cmd response 0x0, card status 0x0
[35832.622686] blk_update_request: I/O error, dev mmcblk0, sector 30053344
[35832.632070] EXT4-fs warning (device mmcblk0p3): ext4_end_bio:329: I/O error -5 writing to inode 932280 (offset 0 size 0 starting block 3756669)
[35832.632082] Buffer I/O error on device mmcblk0p3, logical block 3743868
[38098.803293] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[38108.836088] mmc0: Timeout waiting for hardware interrupt.
[38108.850034]
[ cut here ]
[38108.850079] WARNING: CPU: 0 PID: 0 at /tmp/buildd/linux-ubilinux-4.4.13/drivers/mmc/host/sdhci.c:1017 sdhci_send_command+0x770/0xc30 [sdhci]()
[38108.850089] Modules linked in: tun nfsd auth_rpcgss oid_registry nfs_acl nfs lockd grace fscache sunrpc sg sd_mod sr_mod cdrom intel_rapl intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul nls_utf8 nls_cp437 vfat fat jitterentropy_rng hdmi_audio cdc_acm sha256_ssse3 sha256_generic hmac drbg ansi_cprng iTCO_wdt dwc3 iTCO_vendor_support udc_core spidev evdev aesni_intel aes_x86_64 lrw gf128mul glue_helper ablk_helper cryptd i915 efi_pstore option usb_wwan efivars snd_pcm usb_storage snd_timer snd scsi_mod ftdi_sio usbserial soundcore ti_adc081c drm_kms_helper iosf_mbi drm lpc_ich dwc3_pci shpchp mfd_core 8250_fintek i2c_algo_bit video industrialio battery spi_pxa2xx_platform tpm_crb pwm_lpss_platform pwm_lpss int3400_thermal tpm_tis int3403_thermal tpm acpi_thermal_rel
[38108.850466] int340x_thermal_zone ac acpi_pad button processor i2c_dev fuse parport_pc ppdev lp parport autofs4 ext4 crc16 mbcache jbd2 hid_generic usbhid hid mmc_block crc32c_intel xhci_pci xhci_hcd r8169 mii usbcore usb_common thermal fjes sdhci_acpi sdhci mmc_core
[38108.850625] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G W 4.4.0-ubi3-amd64 #1 Debian 4.4.13-1
[38108.850637] Hardware name: AAEON UP-CHT01/UP-CHT01, BIOS UPC1BM0S 06/04/2016
[38108.850648] 0000000000000086 cb11619bc5cd881a ffffffff81306017 0000000000000000
[38108.850669] ffffffffa0096460 ffffffff8107d143 ffff88005a808540 ffff880036d32930
[38108.850687] 0000000000000001 0000000000000001 ffff88005a808540 ffffffffa0093820
[38108.850706] Call Trace:
[38108.850718] <IRQ> [<ffffffff81306017>] ? dump_stack+0x5c/0x85
[38108.850765] [<ffffffff8107d143>] ? warn_slowpath_common+0x83/0xc0
[38108.850789] [<ffffffffa0093820>] ? sdhci_send_command+0x770/0xc30 [sdhci]
[38108.850812] [<ffffffffa0090b65>] ? sdhci_reset+0x55/0xc0 [sdhci]
[38108.850834] [<ffffffffa0094594>] ? sdhci_finish_data+0xf4/0x340 [sdhci]
[38108.850856] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[38108.850878] [<ffffffffa009485a>] ? sdhci_timeout_timer+0x7a/0xb0 [sdhci]
[38108.850898] [<ffffffff810e3a20>] ? call_timer_fn+0x30/0x130
[38108.850919] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[38108.850939] [<ffffffff810e5736>] ? run_timer_softirq+0x176/0x2d0
[38108.850957] [<ffffffff81081d1a>] ? __do_softirq+0x11a/0x2c0
[38108.850974] [<ffffffff81082008>] ? irq_exit+0x88/0x90
[38108.850992] [<ffffffff815dbaee>] ? smp_apic_timer_interrupt+0x3e/0x50
[38108.851011] [<ffffffff815d9de2>] ? apic_timer_interrupt+0x82/0x90
[38108.851020] <EOI> [<ffffffff814972ec>] ? cpuidle_enter_state+0x13c/0x2b0
[38108.851054] [<ffffffff810bf0c6>] ? cpu_startup_entry+0x346/0x3b0
[38108.851076] [<ffffffff81b3af9a>] ? start_kernel+0x487/0x4a8
[38108.851096] [<ffffffff81b3a120>] ? early_idt_handler_array+0x120/0x120
[38108.851111] [<ffffffff81b3a611>] ? x86_64_start_kernel+0x156/0x17b
[38108.851123] ---[ end trace 35a2ee1a4f956546 ]---
[38108.853647] mmcblk0: error -110 sending stop command, original cmd response 0x0, card status 0x400900
[38108.853724] mmcblk0: error -110 transferring data, sector 6108344, nr 8, cmd response 0x0, card status 0x0
[38108.867856] blk_update_request: I/O error, dev mmcblk0, sector 6108344
[38108.877534] EXT4-fs warning (device mmcblk0p3): ext4_end_bio:329: I/O error -5 writing to inode 928424 (offset 0 size 0 starting block 763544)
[38108.877552] Buffer I/O error on device mmcblk0p3, logical block 750743
[40819.485380] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[50362.305532] systemd-default-display-manager-generator[11117]: /etc/X11/default-display-manager points at lightdm while the default systemd unit is . Reconfiguring lightdm as default.
[50362.875392] systemd-default-display-manager-generator[11146]: /etc/X11/default-display-manager points at lightdm while the default systemd unit is . Reconfiguring lightdm as default.
[50363.020490] systemd-default-display-manager-generator[11181]: /etc/X11/default-display-manager points at lightdm while the default systemd unit is . Reconfiguring lightdm as default.
[50363.238375] systemd-default-display-manager-generator[11204]: /etc/X11/default-display-manager points at lightdm while the default systemd unit is . Reconfiguring lightdm as default.
[58818.065422] systemd-default-display-manager-generator[1730]: /etc/X11/default-display-manager points at lightdm while the default systemd unit is . Reconfiguring lightdm as default.
[58820.849796] systemd-default-display-manager-generator[2481]: /etc/X11/default-display-manager points at lightdm while the default systemd unit is . Reconfiguring lightdm as default.
[58821.094508] systemd-default-display-manager-generator[2503]: /etc/X11/default-display-manager points at lightdm while the default systemd unit is . Reconfiguring lightdm as default.
[58821.244111] systemd-default-display-manager-generator[2536]: /etc/X11/default-display-manager points at lightdm while the default systemd unit is . Reconfiguring lightdm as default.
[58821.637366] systemd-default-display-manager-generator[2572]: /etc/X11/default-display-manager points at lightdm while the default systemd unit is . Reconfiguring lightdm as default.
[62633.626426] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[66330.802935] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[66331.807028] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[66341.827771] mmc0: Timeout waiting for hardware interrupt.
[66341.839300]
[ cut here ]
[66341.839323] WARNING: CPU: 0 PID: 0 at /tmp/buildd/linux-ubilinux-4.4.13/drivers/mmc/host/sdhci.c:1017 sdhci_send_command+0x770/0xc30 [sdhci]()
[66341.839329] Modules linked in: tun nfsd auth_rpcgss oid_registry nfs_acl nfs lockd grace fscache sunrpc sg sd_mod sr_mod cdrom intel_rapl intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul nls_utf8 nls_cp437 vfat fat jitterentropy_rng hdmi_audio cdc_acm sha256_ssse3 sha256_generic hmac drbg ansi_cprng iTCO_wdt dwc3 iTCO_vendor_support udc_core spidev evdev aesni_intel aes_x86_64 lrw gf128mul glue_helper ablk_helper cryptd i915 efi_pstore option usb_wwan efivars snd_pcm usb_storage snd_timer snd scsi_mod ftdi_sio usbserial soundcore ti_adc081c drm_kms_helper iosf_mbi drm lpc_ich dwc3_pci shpchp mfd_core 8250_fintek i2c_algo_bit video industrialio battery spi_pxa2xx_platform tpm_crb pwm_lpss_platform pwm_lpss int3400_thermal tpm_tis int3403_thermal tpm acpi_thermal_rel
[66341.839572] int340x_thermal_zone ac acpi_pad button processor i2c_dev fuse parport_pc ppdev lp parport autofs4 ext4 crc16 mbcache jbd2 hid_generic usbhid hid mmc_block crc32c_intel xhci_pci xhci_hcd r8169 mii usbcore usb_common thermal fjes sdhci_acpi sdhci mmc_core
[66341.839677] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G W 4.4.0-ubi3-amd64 #1 Debian 4.4.13-1
[66341.839683] Hardware name: AAEON UP-CHT01/UP-CHT01, BIOS UPC1BM0S 06/04/2016
[66341.839689] 0000000000000086 cb11619bc5cd881a ffffffff81306017 0000000000000000
[66341.839700] ffffffffa0096460 ffffffff8107d143 ffff88005a808540 ffff880036d32ad8
[66341.839709] 0000000000000002 0000000000000001 ffff88005a808540 ffffffffa0093820
[66341.839719] Call Trace:
[66341.839726] <IRQ> [<ffffffff81306017>] ? dump_stack+0x5c/0x85
[66341.839753] [<ffffffff8107d143>] ? warn_slowpath_common+0x83/0xc0
[66341.839765] [<ffffffffa0093820>] ? sdhci_send_command+0x770/0xc30 [sdhci]
[66341.839776] [<ffffffffa0090b65>] ? sdhci_reset+0x55/0xc0 [sdhci]
[66341.839787] [<ffffffffa0094594>] ? sdhci_finish_data+0xf4/0x340 [sdhci]
[66341.839798] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[66341.839809] [<ffffffffa009485a>] ? sdhci_timeout_timer+0x7a/0xb0 [sdhci]
[66341.839820] [<ffffffff810e3a20>] ? call_timer_fn+0x30/0x130
[66341.839831] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[66341.839841] [<ffffffff810e5736>] ? run_timer_softirq+0x176/0x2d0
[66341.839851] [<ffffffff81081d1a>] ? __do_softirq+0x11a/0x2c0
[66341.839859] [<ffffffff81082008>] ? irq_exit+0x88/0x90
[66341.839870] [<ffffffff815dbaee>] ? smp_apic_timer_interrupt+0x3e/0x50
[66341.839879] [<ffffffff815d9de2>] ? apic_timer_interrupt+0x82/0x90
[66341.839883] <EOI> [<ffffffff814972ec>] ? cpuidle_enter_state+0x13c/0x2b0
[66341.839903] [<ffffffff810bf0c6>] ? cpu_startup_entry+0x346/0x3b0
[66341.839915] [<ffffffff81b3af9a>] ? start_kernel+0x487/0x4a8
[66341.839924] [<ffffffff81b3a120>] ? early_idt_handler_array+0x120/0x120
[66341.839932] [<ffffffff81b3a611>] ? x86_64_start_kernel+0x156/0x17b
[66341.839939] ---[ end trace 35a2ee1a4f956547 ]---
[66341.842306] mmcblk0: error -110 sending stop command, original cmd response 0x0, card status 0x400900
[66341.842379] mmcblk0: error -110 transferring data, sector 6084608, nr 64, cmd response 0x0, card status 0x0
[66341.856187] blk_update_request: I/O error, dev mmcblk0, sector 6084608
[66341.870181] blk_update_request: I/O error, dev mmcblk0, sector 6084616
[66341.880126] blk_update_request: I/O error, dev mmcblk0, sector 6084624
[66341.889671] blk_update_request: I/O error, dev mmcblk0, sector 6084632
[66341.899092] blk_update_request: I/O error, dev mmcblk0, sector 6084640
[66341.908515] blk_update_request: I/O error, dev mmcblk0, sector 6084648
[66341.917940] blk_update_request: I/O error, dev mmcblk0, sector 6084656
[66341.927370] blk_update_request: I/O error, dev mmcblk0, sector 6084664
[66341.936800] EXT4-fs warning (device mmcblk0p3): ext4_end_bio:329: I/O error -5 writing to inode 928423 (offset 0 size 0 starting block 760584)
[66341.936815] Buffer I/O error on device mmcblk0p3, logical block 747776
[66341.946303] Buffer I/O error on device mmcblk0p3, logical block 747777
[66341.955730] Buffer I/O error on device mmcblk0p3, logical block 747778
[66341.965072] Buffer I/O error on device mmcblk0p3, logical block 747779
[66341.974327] Buffer I/O error on device mmcblk0p3, logical block 747780
[66341.983536] Buffer I/O error on device mmcblk0p3, logical block 747781
[66341.992683] Buffer I/O error on device mmcblk0p3, logical block 747782
[66342.001743] Buffer I/O error on device mmcblk0p3, logical block 747783
[66373.746291] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[66375.798418] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[66384.011066] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[66385.011167] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[66395.047910] mmc0: Timeout waiting for hardware interrupt.
[66395.058928]
[ cut here ]
[66395.058954] WARNING: CPU: 0 PID: 0 at /tmp/buildd/linux-ubilinux-4.4.13/drivers/mmc/host/sdhci.c:1017 sdhci_send_command+0x770/0xc30 [sdhci]()
[66395.058959] Modules linked in: tun nfsd auth_rpcgss oid_registry nfs_acl nfs lockd grace fscache sunrpc sg sd_mod sr_mod cdrom intel_rapl intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul nls_utf8 nls_cp437 vfat fat jitterentropy_rng hdmi_audio cdc_acm sha256_ssse3 sha256_generic hmac drbg ansi_cprng iTCO_wdt dwc3 iTCO_vendor_support udc_core spidev evdev aesni_intel aes_x86_64 lrw gf128mul glue_helper ablk_helper cryptd i915 efi_pstore option usb_wwan efivars snd_pcm usb_storage snd_timer snd scsi_mod ftdi_sio usbserial soundcore ti_adc081c drm_kms_helper iosf_mbi drm lpc_ich dwc3_pci shpchp mfd_core 8250_fintek i2c_algo_bit video industrialio battery spi_pxa2xx_platform tpm_crb pwm_lpss_platform pwm_lpss int3400_thermal tpm_tis int3403_thermal tpm acpi_thermal_rel
[66395.059204] int340x_thermal_zone ac acpi_pad button processor i2c_dev fuse parport_pc ppdev lp parport autofs4 ext4 crc16 mbcache jbd2 hid_generic usbhid hid mmc_block crc32c_intel xhci_pci xhci_hcd r8169 mii usbcore usb_common thermal fjes sdhci_acpi sdhci mmc_core
[66395.059311] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G W 4.4.0-ubi3-amd64 #1 Debian 4.4.13-1
[66395.059317] Hardware name: AAEON UP-CHT01/UP-CHT01, BIOS UPC1BM0S 06/04/2016
[66395.059324] 0000000000000086 cb11619bc5cd881a ffffffff81306017 0000000000000000
[66395.059334] ffffffffa0096460 ffffffff8107d143 ffff88005a808540 ffff880036d32930
[66395.059343] 0000000000000003 0000000000000001 ffff88005a808540 ffffffffa0093820
[66395.059352] Call Trace:
[66395.059359] <IRQ> [<ffffffff81306017>] ? dump_stack+0x5c/0x85
[66395.059384] [<ffffffff8107d143>] ? warn_slowpath_common+0x83/0xc0
[66395.059397] [<ffffffffa0093820>] ? sdhci_send_command+0x770/0xc30 [sdhci]
[66395.059408] [<ffffffffa0090b65>] ? sdhci_reset+0x55/0xc0 [sdhci]
[66395.059419] [<ffffffffa0094594>] ? sdhci_finish_data+0xf4/0x340 [sdhci]
[66395.059430] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[66395.059441] [<ffffffffa009485a>] ? sdhci_timeout_timer+0x7a/0xb0 [sdhci]
[66395.059452] [<ffffffff810e3a20>] ? call_timer_fn+0x30/0x130
[66395.059463] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[66395.059473] [<ffffffff810e5736>] ? run_timer_softirq+0x176/0x2d0
[66395.059483] [<ffffffff81081d1a>] ? __do_softirq+0x11a/0x2c0
[66395.059491] [<ffffffff81082008>] ? irq_exit+0x88/0x90
[66395.059502] [<ffffffff815dbaee>] ? smp_apic_timer_interrupt+0x3e/0x50
[66395.059511] [<ffffffff815d9de2>] ? apic_timer_interrupt+0x82/0x90
[66395.059516] <EOI> [<ffffffff814972ec>] ? cpuidle_enter_state+0x13c/0x2b0
[66395.059536] [<ffffffff810bf0c6>] ? cpu_startup_entry+0x346/0x3b0
[66395.059548] [<ffffffff81b3af9a>] ? start_kernel+0x487/0x4a8
[66395.059558] [<ffffffff81b3a120>] ? early_idt_handler_array+0x120/0x120
[66395.059565] [<ffffffff81b3a611>] ? x86_64_start_kernel+0x156/0x17b
[66395.059572] ---[ end trace 35a2ee1a4f956548 ]---
[66395.062170] mmcblk0: error -110 sending stop command, original cmd response 0x0, card status 0x400900
[66395.062208] mmcblk0: error -110 transferring data, sector 6084608, nr 160, cmd response 0x0, card status 0x0
[66395.075080] blk_update_request: I/O error, dev mmcblk0, sector 6084608
[66395.084281] blk_update_request: I/O error, dev mmcblk0, sector 6084616
[66395.093471] blk_update_request: I/O error, dev mmcblk0, sector 6084624
[66395.102666] blk_update_request: I/O error, dev mmcblk0, sector 6084632
[66395.111867] blk_update_request: I/O error, dev mmcblk0, sector 6084640
[66395.121068] blk_update_request: I/O error, dev mmcblk0, sector 6084648
[66395.121070] blk_update_request: I/O error, dev mmcblk0, sector 6084656
[66395.121072] blk_update_request: I/O error, dev mmcblk0, sector 6084664
[66395.121074] blk_update_request: I/O error, dev mmcblk0, sector 6084672
[66395.121076] blk_update_request: I/O error, dev mmcblk0, sector 6084680
[66395.121085] EXT4-fs warning (device mmcblk0p3): ext4_end_bio:329: I/O error -5 writing to inode 928423 (offset 0 size 0 starting block 760596)
[66395.121103] Buffer I/O error on device mmcblk0p3, logical block 747776
[66395.121114] Buffer I/O error on device mmcblk0p3, logical block 747777
[66395.121117] Buffer I/O error on device mmcblk0p3, logical block 747778
[66395.121120] Buffer I/O error on device mmcblk0p3, logical block 747779
[66395.121122] Buffer I/O error on device mmcblk0p3, logical block 747780
[66395.121125] Buffer I/O error on device mmcblk0p3, logical block 747781
[66395.121127] Buffer I/O error on device mmcblk0p3, logical block 747782
[66395.121129] Buffer I/O error on device mmcblk0p3, logical block 747783
[66395.121131] Buffer I/O error on device mmcblk0p3, logical block 747784
[66395.121133] Buffer I/O error on device mmcblk0p3, logical block 747785
[77031.092309] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[79179.956662] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[88961.135510] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[96938.944793] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[97965.677187] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[97970.681584] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[98176.101454] systemd-default-display-manager-generator[27801]: /etc/X11/default-display-manager points at lightdm while the default systemd unit is . Reconfiguring lightdm as default.
[98177.939855] systemd-default-display-manager-generator[28438]: /etc/X11/default-display-manager points at lightdm while the default systemd unit is . Reconfiguring lightdm as default.
[98178.056153] systemd-default-display-manager-generator[28455]: /etc/X11/default-display-manager points at lightdm while the default systemd unit is . Reconfiguring lightdm as default.
[98178.412761] systemd-default-display-manager-generator[28480]: /etc/X11/default-display-manager points at lightdm while the default systemd unit is . Reconfiguring lightdm as default.
[98178.628223] systemd-default-display-manager-generator[28510]: /etc/X11/default-display-manager points at lightdm while the default systemd unit is . Reconfiguring lightdm as default.
[98364.228357] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[99002.614317] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[99894.664082] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[106504.225325] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[112796.743985] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[114938.666837] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[114940.130966] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[118492.066124] r8169 0000:01:00.0 eth0: link down
[118494.519768] r8169 0000:01:00.0 eth0: link down
[118494.519851] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[118494.783790] r8169 0000:01:00.0 eth0: link down
[118494.783873] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[118500.879398] r8169 0000:01:00.0 eth0: link up
[118500.879420] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[118505.500587] r8169 0000:01:00.0 eth0: link down
[118505.500623] r8169 0000:01:00.0 eth0: link down
[118505.500679] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[118505.692755] r8169 0000:01:00.0 eth0: link down
[118505.692832] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[118508.760638] r8169 0000:01:00.0 eth0: link up
[118508.760662] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[118518.092130] r8169 0000:01:00.0 eth0: link down
[118520.667217] r8169 0000:01:00.0 eth0: link up
[118528.194392] r8169 0000:01:00.0 eth0: link down
[118528.194403] r8169 0000:01:00.0 eth0: link down
[118528.194487] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[118530.797132] r8169 0000:01:00.0 eth0: link up
[118530.797157] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[122147.217447] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[132605.625983] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[145839.666930] nr_pdflush_threads exported in /proc is scheduled for removal
[148692.015863] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[148807.592860] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[152398.612482] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[156598.873181] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[156744.108551] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[158862.946639] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[159885.706986] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[165008.557693] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[174609.063078] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[175077.115742] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[176513.252247] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[176523.261026] mmc0: Timeout waiting for hardware interrupt.
[176523.270642]
[ cut here ]
[176523.270656] WARNING: CPU: 3 PID: 0 at /tmp/buildd/linux-ubilinux-4.4.13/drivers/mmc/host/sdhci.c:1017 sdhci_send_command+0x770/0xc30 [sdhci]()
[176523.270659] Modules linked in: binfmt_misc tun nfsd auth_rpcgss oid_registry nfs_acl nfs lockd grace fscache sunrpc sg sd_mod sr_mod cdrom intel_rapl intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul nls_utf8 nls_cp437 vfat fat jitterentropy_rng hdmi_audio cdc_acm sha256_ssse3 sha256_generic hmac drbg ansi_cprng iTCO_wdt dwc3 iTCO_vendor_support udc_core spidev evdev aesni_intel aes_x86_64 lrw gf128mul glue_helper ablk_helper cryptd i915 efi_pstore option usb_wwan efivars snd_pcm usb_storage snd_timer snd scsi_mod ftdi_sio usbserial soundcore ti_adc081c drm_kms_helper iosf_mbi drm lpc_ich dwc3_pci shpchp mfd_core 8250_fintek i2c_algo_bit video industrialio battery spi_pxa2xx_platform tpm_crb pwm_lpss_platform pwm_lpss int3400_thermal tpm_tis int3403_thermal tpm acpi_thermal_rel
[176523.270750] int340x_thermal_zone ac acpi_pad button processor i2c_dev fuse parport_pc ppdev lp parport autofs4 ext4 crc16 mbcache jbd2 hid_generic usbhid hid mmc_block crc32c_intel xhci_pci xhci_hcd r8169 mii usbcore usb_common thermal fjes sdhci_acpi sdhci mmc_core
[176523.270787] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G W 4.4.0-ubi3-amd64 #1 Debian 4.4.13-1
[176523.270790] Hardware name: AAEON UP-CHT01/UP-CHT01, BIOS UPC1BM0S 06/04/2016
[176523.270794] 0000000000000086 4868efd746ab5c51 ffffffff81306017 0000000000000000
[176523.270799] ffffffffa0096460 ffffffff8107d143 ffff88005a808540 ffff880036d32ad8
[176523.270804] 0000000000000001 0000000000000001 ffff88005a808540 ffffffffa0093820
[176523.270810] Call Trace:
[176523.270813] <IRQ> [<ffffffff81306017>] ? dump_stack+0x5c/0x85
[176523.270828] [<ffffffff8107d143>] ? warn_slowpath_common+0x83/0xc0
[176523.270835] [<ffffffffa0093820>] ? sdhci_send_command+0x770/0xc30 [sdhci]
[176523.270842] [<ffffffffa0090b65>] ? sdhci_reset+0x55/0xc0 [sdhci]
[176523.270848] [<ffffffffa0094594>] ? sdhci_finish_data+0xf4/0x340 [sdhci]
[176523.270854] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[176523.270861] [<ffffffffa009485a>] ? sdhci_timeout_timer+0x7a/0xb0 [sdhci]
[176523.270867] [<ffffffff810e3a20>] ? call_timer_fn+0x30/0x130
[176523.270873] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[176523.270878] [<ffffffff810e5736>] ? run_timer_softirq+0x176/0x2d0
[176523.270883] [<ffffffff81081d1a>] ? __do_softirq+0x11a/0x2c0
[176523.270887] [<ffffffff81082008>] ? irq_exit+0x88/0x90
[176523.270893] [<ffffffff815dbaee>] ? smp_apic_timer_interrupt+0x3e/0x50
[176523.270899] [<ffffffff815d9de2>] ? apic_timer_interrupt+0x82/0x90
[176523.270901] <EOI> [<ffffffff814972ec>] ? cpuidle_enter_state+0x13c/0x2b0
[176523.270910] [<ffffffff814972c7>] ? cpuidle_enter_state+0x117/0x2b0
[176523.270916] [<ffffffff810bf0c6>] ? cpu_startup_entry+0x346/0x3b0
[176523.270921] [<ffffffff810f39ab>] ? tick_check_new_device+0xcb/0xf0
[176523.270926] [<ffffffff81050602>] ? start_secondary+0x152/0x190
[176523.270930] ---[ end trace 35a2ee1a4f956549 ]---
[176523.273053] mmcblk0: error -110 sending stop command, original cmd response 0x0, card status 0x400900
[176523.273110] mmcblk0: error -110 transferring data, sector 6126896, nr 8, cmd response 0x0, card status 0x0
[176523.289452] blk_update_request: 10 callbacks suppressed
[176523.289468] blk_update_request: I/O error, dev mmcblk0, sector 6126896
[176523.301365] EXT4-fs warning (device mmcblk0p3): ext4_end_bio:329: I/O error -5 writing to inode 928425 (offset 0 size 0 starting block 765863)
[176523.301376] buffer_io_error: 10 callbacks suppressed
[176523.301382] Buffer I/O error on device mmcblk0p3, logical block 753062
[177506.854124] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[183347.630099] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[183350.630337] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[183351.634373] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[183361.651136] mmc0: Timeout waiting for hardware interrupt.
[183361.664406]
[ cut here ]
[183361.664450] WARNING: CPU: 0 PID: 0 at /tmp/buildd/linux-ubilinux-4.4.13/drivers/mmc/host/sdhci.c:1017 sdhci_send_command+0x770/0xc30 [sdhci]()
[183361.664460] Modules linked in: binfmt_misc tun nfsd auth_rpcgss oid_registry nfs_acl nfs lockd grace fscache sunrpc sg sd_mod sr_mod cdrom intel_rapl intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul nls_utf8 nls_cp437 vfat fat jitterentropy_rng hdmi_audio cdc_acm sha256_ssse3 sha256_generic hmac drbg ansi_cprng iTCO_wdt dwc3 iTCO_vendor_support udc_core spidev evdev aesni_intel aes_x86_64 lrw gf128mul glue_helper ablk_helper cryptd i915 efi_pstore option usb_wwan efivars snd_pcm usb_storage snd_timer snd scsi_mod ftdi_sio usbserial soundcore ti_adc081c drm_kms_helper iosf_mbi drm lpc_ich dwc3_pci shpchp mfd_core 8250_fintek i2c_algo_bit video industrialio battery spi_pxa2xx_platform tpm_crb pwm_lpss_platform pwm_lpss int3400_thermal tpm_tis int3403_thermal tpm acpi_thermal_rel
[183361.664836] int340x_thermal_zone ac acpi_pad button processor i2c_dev fuse parport_pc ppdev lp parport autofs4 ext4 crc16 mbcache jbd2 hid_generic usbhid hid mmc_block crc32c_intel xhci_pci xhci_hcd r8169 mii usbcore usb_common thermal fjes sdhci_acpi sdhci mmc_core
[183361.664981] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G W 4.4.0-ubi3-amd64 #1 Debian 4.4.13-1
[183361.664992] Hardware name: AAEON UP-CHT01/UP-CHT01, BIOS UPC1BM0S 06/04/2016
[183361.665003] 0000000000000086 cb11619bc5cd881a ffffffff81306017 0000000000000000
[183361.665023] ffffffffa0096460 ffffffff8107d143 ffff88005a808540 ffff880036d32ad8
[183361.665041] 0000000000000002 0000000000000001 ffff88005a808540 ffffffffa0093820
[183361.665060] Call Trace:
[183361.665073] <IRQ> [<ffffffff81306017>] ? dump_stack+0x5c/0x85
[183361.665117] [<ffffffff8107d143>] ? warn_slowpath_common+0x83/0xc0
[183361.665142] [<ffffffffa0093820>] ? sdhci_send_command+0x770/0xc30 [sdhci]
[183361.665165] [<ffffffffa0090b65>] ? sdhci_reset+0x55/0xc0 [sdhci]
[183361.665187] [<ffffffffa0094594>] ? sdhci_finish_data+0xf4/0x340 [sdhci]
[183361.665209] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[183361.665231] [<ffffffffa009485a>] ? sdhci_timeout_timer+0x7a/0xb0 [sdhci]
[183361.665251] [<ffffffff810e3a20>] ? call_timer_fn+0x30/0x130
[183361.665272] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[183361.665292] [<ffffffff810e5736>] ? run_timer_softirq+0x176/0x2d0
[183361.665310] [<ffffffff81081d1a>] ? __do_softirq+0x11a/0x2c0
[183361.665326] [<ffffffff81082008>] ? irq_exit+0x88/0x90
[183361.665345] [<ffffffff815dbaee>] ? smp_apic_timer_interrupt+0x3e/0x50
[183361.665364] [<ffffffff815d9de2>] ? apic_timer_interrupt+0x82/0x90
[183361.665373] <EOI> [<ffffffff814972ec>] ? cpuidle_enter_state+0x13c/0x2b0
[183361.665407] [<ffffffff810bf0c6>] ? cpu_startup_entry+0x346/0x3b0
[183361.665428] [<ffffffff81b3af9a>] ? start_kernel+0x487/0x4a8
[183361.665447] [<ffffffff81b3a120>] ? early_idt_handler_array+0x120/0x120
[183361.665462] [<ffffffff81b3a611>] ? x86_64_start_kernel+0x156/0x17b
[183361.665475] ---[ end trace 35a2ee1a4f95654a ]---
[183361.667747] mmcblk0: error -110 sending stop command, original cmd response 0x0, card status 0x400900
[183361.667797] mmcblk0: error -110 transferring data, sector 6084608, nr 96, cmd response 0x0, card status 0x0
[183361.681529] blk_update_request: I/O error, dev mmcblk0, sector 6084608
[183361.691613] blk_update_request: I/O error, dev mmcblk0, sector 6084616
[183361.700652] blk_update_request: I/O error, dev mmcblk0, sector 6084624
[183361.709446] blk_update_request: I/O error, dev mmcblk0, sector 6084632
[183361.718155] blk_update_request: I/O error, dev mmcblk0, sector 6084640
[183361.726864] blk_update_request: I/O error, dev mmcblk0, sector 6084648
[183361.735576] blk_update_request: I/O error, dev mmcblk0, sector 6084656
[183361.744287] blk_update_request: I/O error, dev mmcblk0, sector 6084664
[183361.753003] blk_update_request: I/O error, dev mmcblk0, sector 6084672
[183361.761716] EXT4-fs warning (device mmcblk0p3): ext4_end_bio:329: I/O error -5 writing to inode 928423 (offset 0 size 0 starting block 760588)
[183361.761723] Buffer I/O error on device mmcblk0p3, logical block 747776
[183361.770494] Buffer I/O error on device mmcblk0p3, logical block 747777
[183361.779267] Buffer I/O error on device mmcblk0p3, logical block 747778
[183361.787977] Buffer I/O error on device mmcblk0p3, logical block 747779
[183361.796685] Buffer I/O error on device mmcblk0p3, logical block 747780
[183361.805393] Buffer I/O error on device mmcblk0p3, logical block 747781
[183361.814108] Buffer I/O error on device mmcblk0p3, logical block 747782
[183361.822821] Buffer I/O error on device mmcblk0p3, logical block 747783
[183361.831532] Buffer I/O error on device mmcblk0p3, logical block 747784
[183609.634523] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[183901.693317] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[183911.710109] mmc0: Timeout waiting for hardware interrupt.
[183911.722918]
[ cut here ]
[183911.722965] WARNING: CPU: 0 PID: 0 at /tmp/buildd/linux-ubilinux-4.4.13/drivers/mmc/host/sdhci.c:1017 sdhci_send_command+0x770/0xc30 [sdhci]()
[183911.722975] Modules linked in: binfmt_misc tun nfsd auth_rpcgss oid_registry nfs_acl nfs lockd grace fscache sunrpc sg sd_mod sr_mod cdrom intel_rapl intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul nls_utf8 nls_cp437 vfat fat jitterentropy_rng hdmi_audio cdc_acm sha256_ssse3 sha256_generic hmac drbg ansi_cprng iTCO_wdt dwc3 iTCO_vendor_support udc_core spidev evdev aesni_intel aes_x86_64 lrw gf128mul glue_helper ablk_helper cryptd i915 efi_pstore option usb_wwan efivars snd_pcm usb_storage snd_timer snd scsi_mod ftdi_sio usbserial soundcore ti_adc081c drm_kms_helper iosf_mbi drm lpc_ich dwc3_pci shpchp mfd_core 8250_fintek i2c_algo_bit video industrialio battery spi_pxa2xx_platform tpm_crb pwm_lpss_platform pwm_lpss int3400_thermal tpm_tis int3403_thermal tpm acpi_thermal_rel
[183911.723356] int340x_thermal_zone ac acpi_pad button processor i2c_dev fuse parport_pc ppdev lp parport autofs4 ext4 crc16 mbcache jbd2 hid_generic usbhid hid mmc_block crc32c_intel xhci_pci xhci_hcd r8169 mii usbcore usb_common thermal fjes sdhci_acpi sdhci mmc_core
[183911.723514] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G W 4.4.0-ubi3-amd64 #1 Debian 4.4.13-1
[183911.723525] Hardware name: AAEON UP-CHT01/UP-CHT01, BIOS UPC1BM0S 06/04/2016
[183911.723537] 0000000000000086 cb11619bc5cd881a ffffffff81306017 0000000000000000
[183911.723559] ffffffffa0096460 ffffffff8107d143 ffff88005a808540 ffff880036d32ad8
[183911.723577] 0000000000000005 0000000000000001 ffff88005a808540 ffffffffa0093820
[183911.723596] Call Trace:
[183911.723609] <IRQ> [<ffffffff81306017>] ? dump_stack+0x5c/0x85
[183911.723653] [<ffffffff8107d143>] ? warn_slowpath_common+0x83/0xc0
[183911.723677] [<ffffffffa0093820>] ? sdhci_send_command+0x770/0xc30 [sdhci]
[183911.723700] [<ffffffffa0090b65>] ? sdhci_reset+0x55/0xc0 [sdhci]
[183911.723722] [<ffffffffa0094594>] ? sdhci_finish_data+0xf4/0x340 [sdhci]
[183911.723743] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[183911.723765] [<ffffffffa009485a>] ? sdhci_timeout_timer+0x7a/0xb0 [sdhci]
[183911.723786] [<ffffffff810e3a20>] ? call_timer_fn+0x30/0x130
[183911.723807] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[183911.723827] [<ffffffff810e5736>] ? run_timer_softirq+0x176/0x2d0
[183911.723845] [<ffffffff81081d1a>] ? __do_softirq+0x11a/0x2c0
[183911.723861] [<ffffffff81082008>] ? irq_exit+0x88/0x90
[183911.723880] [<ffffffff815dbaee>] ? smp_apic_timer_interrupt+0x3e/0x50
[183911.723899] [<ffffffff815d9de2>] ? apic_timer_interrupt+0x82/0x90
[183911.723907] <EOI> [<ffffffff814972ec>] ? cpuidle_enter_state+0x13c/0x2b0
[183911.723942] [<ffffffff810bf0c6>] ? cpu_startup_entry+0x346/0x3b0
[183911.723964] [<ffffffff81b3af9a>] ? start_kernel+0x487/0x4a8
[183911.723983] [<ffffffff81b3a120>] ? early_idt_handler_array+0x120/0x120
[183911.723999] [<ffffffff81b3a611>] ? x86_64_start_kernel+0x156/0x17b
[183911.724011] ---[ end trace 35a2ee1a4f95654b ]---
[183911.726785] mmcblk0: error -110 sending stop command, original cmd response 0x0, card status 0x400900
[183911.726834] mmcblk0: error -110 transferring data, sector 6084608, nr 448, cmd response 0x0, card status 0x0
[183911.740496] blk_update_request: 3 callbacks suppressed
[183911.740504] blk_update_request: I/O error, dev mmcblk0, sector 6084608
[183911.749589] blk_update_request: I/O error, dev mmcblk0, sector 6084616
[183911.758448] blk_update_request: I/O error, dev mmcblk0, sector 6084624
[183911.767188] blk_update_request: I/O error, dev mmcblk0, sector 6084632
[183911.775916] blk_update_request: I/O error, dev mmcblk0, sector 6084640
[183911.784637] blk_update_request: I/O error, dev mmcblk0, sector 6084648
[183911.793378] blk_update_request: I/O error, dev mmcblk0, sector 6084656
[183911.802115] blk_update_request: I/O error, dev mmcblk0, sector 6084664
[183911.810840] blk_update_request: I/O error, dev mmcblk0, sector 6084672
[183911.819591] blk_update_request: I/O error, dev mmcblk0, sector 6084680
[183911.828367] EXT4-fs warning (device mmcblk0p3): ext4_end_bio:329: I/O error -5 writing to inode 928423 (offset 0 size 0 starting block 760632)
[183911.828374] buffer_io_error: 3 callbacks suppressed
[183911.828378] Buffer I/O error on device mmcblk0p3, logical block 747776
[183911.837186] Buffer I/O error on device mmcblk0p3, logical block 747777
[183911.845938] Buffer I/O error on device mmcblk0p3, logical block 747778
[183911.854693] Buffer I/O error on device mmcblk0p3, logical block 747779
[183911.863452] Buffer I/O error on device mmcblk0p3, logical block 747780
[183911.872213] Buffer I/O error on device
I've installed my up-board for a week, using the very last available release of Ubilinux from the Up website.
The system is up-to-date.
For 2 days, I encounter filesystem issues, leading to / beeing mounted as read only.
I cannot find the root cause.
Here are the logs from dmesg :
[code]
[ 3468.354858] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[ 4317.009160] perf interrupt took too long (2516 > 2500), lowering kernel.perf_event_max_sample_rate to 50000
[ 7224.234018] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[ 7498.431114] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[ 8722.950111] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[ 8732.966896] mmc0: Timeout waiting for hardware interrupt.
[ 8732.974947]
[ cut here ]
[ 8732.974985] WARNING: CPU: 0 PID: 0 at /tmp/buildd/linux-ubilinux-4.4.13/drivers/mmc/host/sdhci.c:1017 sdhci_send_command+0x770/0xc30 [sdhci]()
[ 8732.974994] Modules linked in: nfsd auth_rpcgss oid_registry nfs_acl nfs lockd grace fscache sunrpc sg sd_mod sr_mod cdrom intel_rapl intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul nls_utf8 nls_cp437 vfat fat jitterentropy_rng hdmi_audio cdc_acm sha256_ssse3 sha256_generic hmac drbg ansi_cprng iTCO_wdt dwc3 iTCO_vendor_support udc_core spidev evdev aesni_intel aes_x86_64 lrw gf128mul glue_helper ablk_helper cryptd i915 efi_pstore option usb_wwan efivars snd_pcm usb_storage snd_timer snd scsi_mod ftdi_sio usbserial soundcore ti_adc081c drm_kms_helper iosf_mbi drm lpc_ich dwc3_pci shpchp mfd_core 8250_fintek i2c_algo_bit video industrialio battery spi_pxa2xx_platform tpm_crb pwm_lpss_platform pwm_lpss int3400_thermal tpm_tis int3403_thermal tpm acpi_thermal_rel int340x_thermal_zone
[ 8732.975263] ac acpi_pad button processor i2c_dev fuse parport_pc ppdev lp parport autofs4 ext4 crc16 mbcache jbd2 hid_generic usbhid hid mmc_block crc32c_intel xhci_pci xhci_hcd r8169 mii usbcore usb_common thermal fjes sdhci_acpi sdhci mmc_core
[ 8732.975372] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.4.0-ubi3-amd64 #1 Debian 4.4.13-1
[ 8732.975382] Hardware name: AAEON UP-CHT01/UP-CHT01, BIOS UPC1BM0S 06/04/2016
[ 8732.975393] 0000000000000086 cb11619bc5cd881a ffffffff81306017 0000000000000000
[ 8732.975413] ffffffffa0096460 ffffffff8107d143 ffff88005a808540 ffff880036d32ad8
[ 8732.975431] 000000000000003d 0000000000000001 ffff88005a808540 ffffffffa0093820
[ 8732.975448] Call Trace:
[ 8732.975458] <IRQ> [<ffffffff81306017>] ? dump_stack+0x5c/0x85
[ 8732.975499] [<ffffffff8107d143>] ? warn_slowpath_common+0x83/0xc0
[ 8732.975524] [<ffffffffa0093820>] ? sdhci_send_command+0x770/0xc30 [sdhci]
[ 8732.975547] [<ffffffffa0090b65>] ? sdhci_reset+0x55/0xc0 [sdhci]
[ 8732.975568] [<ffffffffa0094594>] ? sdhci_finish_data+0xf4/0x340 [sdhci]
[ 8732.975590] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[ 8732.975612] [<ffffffffa009485a>] ? sdhci_timeout_timer+0x7a/0xb0 [sdhci]
[ 8732.975630] [<ffffffff810e3a20>] ? call_timer_fn+0x30/0x130
[ 8732.975652] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[ 8732.975668] [<ffffffff810e5736>] ? run_timer_softirq+0x176/0x2d0
[ 8732.975686] [<ffffffff81081d1a>] ? __do_softirq+0x11a/0x2c0
[ 8732.975702] [<ffffffff81082008>] ? irq_exit+0x88/0x90
[ 8732.975719] [<ffffffff815dbaee>] ? smp_apic_timer_interrupt+0x3e/0x50
[ 8732.975737] [<ffffffff815d9de2>] ? apic_timer_interrupt+0x82/0x90
[ 8732.975745] <EOI> [<ffffffff814972ec>] ? cpuidle_enter_state+0x13c/0x2b0
[ 8732.975776] [<ffffffff810bf0c6>] ? cpu_startup_entry+0x346/0x3b0
[ 8732.975797] [<ffffffff81b3af9a>] ? start_kernel+0x487/0x4a8
[ 8732.975814] [<ffffffff81b3a120>] ? early_idt_handler_array+0x120/0x120
[ 8732.975829] [<ffffffff81b3a611>] ? x86_64_start_kernel+0x156/0x17b
[ 8732.975840] ---[ end trace 35a2ee1a4f956540 ]---
[ 8732.978353] mmcblk0: error -110 sending stop command, original cmd response 0x0, card status 0x400900
[ 8732.978439] mmcblk0: error -110 transferring data, sector 6084608, nr 1024, cmd response 0x0, card status 0x0
[ 8732.989713] blk_update_request: I/O error, dev mmcblk0, sector 6084608
[ 8732.997089] blk_update_request: I/O error, dev mmcblk0, sector 6084616
[ 8733.004448] blk_update_request: I/O error, dev mmcblk0, sector 6084624
[ 8733.011788] blk_update_request: I/O error, dev mmcblk0, sector 6084632
[ 8733.019128] blk_update_request: I/O error, dev mmcblk0, sector 6084640
[ 8733.026463] blk_update_request: I/O error, dev mmcblk0, sector 6084648
[ 8733.033801] blk_update_request: I/O error, dev mmcblk0, sector 6084656
[ 8733.041144] blk_update_request: I/O error, dev mmcblk0, sector 6084664
[ 8733.048482] blk_update_request: I/O error, dev mmcblk0, sector 6084672
[ 8733.055818] blk_update_request: I/O error, dev mmcblk0, sector 6084680
[ 8733.071549] EXT4-fs warning (device mmcblk0p3): ext4_end_bio:329: I/O error -5 writing to inode 928423 (offset 0 size 0 starting block 760832)
[ 8733.071561] Buffer I/O error on device mmcblk0p3, logical block 747776
[ 8733.078917] Buffer I/O error on device mmcblk0p3, logical block 747777
[ 8733.086244] Buffer I/O error on device mmcblk0p3, logical block 747778
[ 8733.093582] Buffer I/O error on device mmcblk0p3, logical block 747779
[ 8733.100907] Buffer I/O error on device mmcblk0p3, logical block 747780
[ 8733.108241] Buffer I/O error on device mmcblk0p3, logical block 747781
[ 8733.115559] Buffer I/O error on device mmcblk0p3, logical block 747782
[ 8733.122898] Buffer I/O error on device mmcblk0p3, logical block 747783
[ 8733.130224] Buffer I/O error on device mmcblk0p3, logical block 747784
[ 8733.137551] Buffer I/O error on device mmcblk0p3, logical block 747785
[10536.536969] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[10546.549679] mmc0: Timeout waiting for hardware interrupt.
[10546.557973]
[ cut here ]
[10546.558019] WARNING: CPU: 0 PID: 0 at /tmp/buildd/linux-ubilinux-4.4.13/drivers/mmc/host/sdhci.c:1017 sdhci_send_command+0x770/0xc30 [sdhci]()
[10546.558029] Modules linked in: nfsd auth_rpcgss oid_registry nfs_acl nfs lockd grace fscache sunrpc sg sd_mod sr_mod cdrom intel_rapl intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul nls_utf8 nls_cp437 vfat fat jitterentropy_rng hdmi_audio cdc_acm sha256_ssse3 sha256_generic hmac drbg ansi_cprng iTCO_wdt dwc3 iTCO_vendor_support udc_core spidev evdev aesni_intel aes_x86_64 lrw gf128mul glue_helper ablk_helper cryptd i915 efi_pstore option usb_wwan efivars snd_pcm usb_storage snd_timer snd scsi_mod ftdi_sio usbserial soundcore ti_adc081c drm_kms_helper iosf_mbi drm lpc_ich dwc3_pci shpchp mfd_core 8250_fintek i2c_algo_bit video industrialio battery spi_pxa2xx_platform tpm_crb pwm_lpss_platform pwm_lpss int3400_thermal tpm_tis int3403_thermal tpm acpi_thermal_rel int340x_thermal_zone
[10546.558407] ac acpi_pad button processor i2c_dev fuse parport_pc ppdev lp parport autofs4 ext4 crc16 mbcache jbd2 hid_generic usbhid hid mmc_block crc32c_intel xhci_pci xhci_hcd r8169 mii usbcore usb_common thermal fjes sdhci_acpi sdhci mmc_core
[10546.558562] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G W 4.4.0-ubi3-amd64 #1 Debian 4.4.13-1
[10546.558573] Hardware name: AAEON UP-CHT01/UP-CHT01, BIOS UPC1BM0S 06/04/2016
[10546.558585] 0000000000000086 cb11619bc5cd881a ffffffff81306017 0000000000000000
[10546.558607] ffffffffa0096460 ffffffff8107d143 ffff88005a808540 ffff880036d32ad8
[10546.558625] 000000000000003d 0000000000000001 ffff88005a808540 ffffffffa0093820
[10546.558644] Call Trace:
[10546.558655] <IRQ> [<ffffffff81306017>] ? dump_stack+0x5c/0x85
[10546.558700] [<ffffffff8107d143>] ? warn_slowpath_common+0x83/0xc0
[10546.558725] [<ffffffffa0093820>] ? sdhci_send_command+0x770/0xc30 [sdhci]
[10546.558747] [<ffffffffa0090b65>] ? sdhci_reset+0x55/0xc0 [sdhci]
[10546.558769] [<ffffffffa0094594>] ? sdhci_finish_data+0xf4/0x340 [sdhci]
[10546.558791] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[10546.558813] [<ffffffffa009485a>] ? sdhci_timeout_timer+0x7a/0xb0 [sdhci]
[10546.558833] [<ffffffff810e3a20>] ? call_timer_fn+0x30/0x130
[10546.558854] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[10546.558874] [<ffffffff810e5736>] ? run_timer_softirq+0x176/0x2d0
[10546.558892] [<ffffffff81081d1a>] ? __do_softirq+0x11a/0x2c0
[10546.558908] [<ffffffff81082008>] ? irq_exit+0x88/0x90
[10546.558927] [<ffffffff815dbaee>] ? smp_apic_timer_interrupt+0x3e/0x50
[10546.558946] [<ffffffff815d9de2>] ? apic_timer_interrupt+0x82/0x90
[10546.558955] <EOI> [<ffffffff814972ec>] ? cpuidle_enter_state+0x13c/0x2b0
[10546.558990] [<ffffffff810bf0c6>] ? cpu_startup_entry+0x346/0x3b0
[10546.559012] [<ffffffff81b3af9a>] ? start_kernel+0x487/0x4a8
[10546.559030] [<ffffffff81b3a120>] ? early_idt_handler_array+0x120/0x120
[10546.559045] [<ffffffff81b3a611>] ? x86_64_start_kernel+0x156/0x17b
[10546.559058] ---[ end trace 35a2ee1a4f956541 ]---
[10546.561488] mmcblk0: error -110 sending stop command, original cmd response 0x0, card status 0x400900
[10546.561589] mmcblk0: error -110 transferring data, sector 6084608, nr 1024, cmd response 0x0, card status 0x0
[10546.573012] blk_update_request: 118 callbacks suppressed
[10546.573020] blk_update_request: I/O error, dev mmcblk0, sector 6084608
[10546.580491] blk_update_request: I/O error, dev mmcblk0, sector 6084616
[10546.587961] blk_update_request: I/O error, dev mmcblk0, sector 6084624
[10546.595417] blk_update_request: I/O error, dev mmcblk0, sector 6084632
[10546.602808] blk_update_request: I/O error, dev mmcblk0, sector 6084640
[10546.610199] blk_update_request: I/O error, dev mmcblk0, sector 6084648
[10546.617589] blk_update_request: I/O error, dev mmcblk0, sector 6084656
[10546.624977] blk_update_request: I/O error, dev mmcblk0, sector 6084664
[10546.632373] blk_update_request: I/O error, dev mmcblk0, sector 6084672
[10546.639766] blk_update_request: I/O error, dev mmcblk0, sector 6084680
[10546.650972] EXT4-fs warning (device mmcblk0p3): ext4_end_bio:329: I/O error -5 writing to inode 928423 (offset 0 size 0 starting block 760732)
[10546.650992] buffer_io_error: 246 callbacks suppressed
[10546.651008] Buffer I/O error on device mmcblk0p3, logical block 747776
[10546.658582] Buffer I/O error on device mmcblk0p3, logical block 747777
[10546.665973] Buffer I/O error on device mmcblk0p3, logical block 747778
[10546.673362] Buffer I/O error on device mmcblk0p3, logical block 747779
[10546.680755] Buffer I/O error on device mmcblk0p3, logical block 747780
[10546.688147] Buffer I/O error on device mmcblk0p3, logical block 747781
[10546.695536] Buffer I/O error on device mmcblk0p3, logical block 747782
[10546.702926] Buffer I/O error on device mmcblk0p3, logical block 747783
[10546.710315] Buffer I/O error on device mmcblk0p3, logical block 747784
[10546.717706] Buffer I/O error on device mmcblk0p3, logical block 747785
[11081.584787] perf interrupt took too long (5014 > 5000), lowering kernel.perf_event_max_sample_rate to 25000
[11097.216489] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[11158.065247] tun: Universal TUN/TAP device driver, 1.6
[11158.065266] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[13333.364185] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[19257.268132] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[19995.357814] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[20005.370527] mmc0: Timeout waiting for hardware interrupt.
[20005.378635]
[ cut here ]
[20005.378653] WARNING: CPU: 1 PID: 0 at /tmp/buildd/linux-ubilinux-4.4.13/drivers/mmc/host/sdhci.c:1017 sdhci_send_command+0x770/0xc30 [sdhci]()
[20005.378656] Modules linked in: tun nfsd auth_rpcgss oid_registry nfs_acl nfs lockd grace fscache sunrpc sg sd_mod sr_mod cdrom intel_rapl intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul nls_utf8 nls_cp437 vfat fat jitterentropy_rng hdmi_audio cdc_acm sha256_ssse3 sha256_generic hmac drbg ansi_cprng iTCO_wdt dwc3 iTCO_vendor_support udc_core spidev evdev aesni_intel aes_x86_64 lrw gf128mul glue_helper ablk_helper cryptd i915 efi_pstore option usb_wwan efivars snd_pcm usb_storage snd_timer snd scsi_mod ftdi_sio usbserial soundcore ti_adc081c drm_kms_helper iosf_mbi drm lpc_ich dwc3_pci shpchp mfd_core 8250_fintek i2c_algo_bit video industrialio battery spi_pxa2xx_platform tpm_crb pwm_lpss_platform pwm_lpss int3400_thermal tpm_tis int3403_thermal tpm acpi_thermal_rel
[20005.378746] int340x_thermal_zone ac acpi_pad button processor i2c_dev fuse parport_pc ppdev lp parport autofs4 ext4 crc16 mbcache jbd2 hid_generic usbhid hid mmc_block crc32c_intel xhci_pci xhci_hcd r8169 mii usbcore usb_common thermal fjes sdhci_acpi sdhci mmc_core
[20005.378784] CPU: 1 PID: 0 Comm: swapper/1 Tainted: G W 4.4.0-ubi3-amd64 #1 Debian 4.4.13-1
[20005.378787] Hardware name: AAEON UP-CHT01/UP-CHT01, BIOS UPC1BM0S 06/04/2016
[20005.378791] 0000000000000086 cfc76b7e00b2bb9b ffffffff81306017 0000000000000000
[20005.378797] ffffffffa0096460 ffffffff8107d143 ffff88005a808540 ffff880036d32ad8
[20005.378802] 0000000000000001 0000000000000001 ffff88005a808540 ffffffffa0093820
[20005.378807] Call Trace:
[20005.378811] <IRQ> [<ffffffff81306017>] ? dump_stack+0x5c/0x85
[20005.378826] [<ffffffff8107d143>] ? warn_slowpath_common+0x83/0xc0
[20005.378833] [<ffffffffa0093820>] ? sdhci_send_command+0x770/0xc30 [sdhci]
[20005.378839] [<ffffffffa0090b65>] ? sdhci_reset+0x55/0xc0 [sdhci]
[20005.378846] [<ffffffffa0094594>] ? sdhci_finish_data+0xf4/0x340 [sdhci]
[20005.378852] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[20005.378858] [<ffffffffa009485a>] ? sdhci_timeout_timer+0x7a/0xb0 [sdhci]
[20005.378864] [<ffffffff810e3a20>] ? call_timer_fn+0x30/0x130
[20005.378870] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[20005.378875] [<ffffffff810e5736>] ? run_timer_softirq+0x176/0x2d0
[20005.378880] [<ffffffff81081d1a>] ? __do_softirq+0x11a/0x2c0
[20005.378885] [<ffffffff81082008>] ? irq_exit+0x88/0x90
[20005.378891] [<ffffffff815dbaee>] ? smp_apic_timer_interrupt+0x3e/0x50
[20005.378896] [<ffffffff815d9de2>] ? apic_timer_interrupt+0x82/0x90
[20005.378899] <EOI> [<ffffffff814972ec>] ? cpuidle_enter_state+0x13c/0x2b0
[20005.378908] [<ffffffff814972c7>] ? cpuidle_enter_state+0x117/0x2b0
[20005.378914] [<ffffffff810bf0c6>] ? cpu_startup_entry+0x346/0x3b0
[20005.378918] [<ffffffff810f39ab>] ? tick_check_new_device+0xcb/0xf0
[20005.378924] [<ffffffff81050602>] ? start_secondary+0x152/0x190
[20005.378928] ---[ end trace 35a2ee1a4f956542 ]---
[20005.382068] mmcblk0: error -110 sending stop command, original cmd response 0x0, card status 0x400900
[20005.382105] mmcblk0: error -110 transferring data, sector 34228416, nr 8, cmd response 0x0, card status 0x0
[20005.393181] blk_update_request: 118 callbacks suppressed
[20005.393201] blk_update_request: I/O error, dev mmcblk0, sector 34228416
[20005.400723] EXT4-fs warning (device mmcblk0p3): ext4_end_bio:329: I/O error -5 writing to inode 787964 (offset 0 size 0 starting block 4278553)
[20005.400730] buffer_io_error: 146 callbacks suppressed
[20005.400735] Buffer I/O error on device mmcblk0p3, logical block 4265752
[28529.362318] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[28530.362408] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[28540.371155] mmc0: Timeout waiting for hardware interrupt.
[28540.379435]
[ cut here ]
[28540.379479] WARNING: CPU: 1 PID: 0 at /tmp/buildd/linux-ubilinux-4.4.13/drivers/mmc/host/sdhci.c:1017 sdhci_send_command+0x770/0xc30 [sdhci]()
[28540.379489] Modules linked in: tun nfsd auth_rpcgss oid_registry nfs_acl nfs lockd grace fscache sunrpc sg sd_mod sr_mod cdrom intel_rapl intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul nls_utf8 nls_cp437 vfat fat jitterentropy_rng hdmi_audio cdc_acm sha256_ssse3 sha256_generic hmac drbg ansi_cprng iTCO_wdt dwc3 iTCO_vendor_support udc_core spidev evdev aesni_intel aes_x86_64 lrw gf128mul glue_helper ablk_helper cryptd i915 efi_pstore option usb_wwan efivars snd_pcm usb_storage snd_timer snd scsi_mod ftdi_sio usbserial soundcore ti_adc081c drm_kms_helper iosf_mbi drm lpc_ich dwc3_pci shpchp mfd_core 8250_fintek i2c_algo_bit video industrialio battery spi_pxa2xx_platform tpm_crb pwm_lpss_platform pwm_lpss int3400_thermal tpm_tis int3403_thermal tpm acpi_thermal_rel
[28540.379867] int340x_thermal_zone ac acpi_pad button processor i2c_dev fuse parport_pc ppdev lp parport autofs4 ext4 crc16 mbcache jbd2 hid_generic usbhid hid mmc_block crc32c_intel xhci_pci xhci_hcd r8169 mii usbcore usb_common thermal fjes sdhci_acpi sdhci mmc_core
[28540.380026] CPU: 1 PID: 0 Comm: swapper/1 Tainted: G W 4.4.0-ubi3-amd64 #1 Debian 4.4.13-1
[28540.380037] Hardware name: AAEON UP-CHT01/UP-CHT01, BIOS UPC1BM0S 06/04/2016
[28540.380048] 0000000000000086 cfc76b7e00b2bb9b ffffffff81306017 0000000000000000
[28540.380069] ffffffffa0096460 ffffffff8107d143 ffff88005a808540 ffff880036d32930
[28540.380087] 0000000000000004 0000000000000001 ffff88005a808540 ffffffffa0093820
[28540.380106] Call Trace:
[28540.380117] <IRQ> [<ffffffff81306017>] ? dump_stack+0x5c/0x85
[28540.380163] [<ffffffff8107d143>] ? warn_slowpath_common+0x83/0xc0
[28540.380189] [<ffffffffa0093820>] ? sdhci_send_command+0x770/0xc30 [sdhci]
[28540.380211] [<ffffffffa0090b65>] ? sdhci_reset+0x55/0xc0 [sdhci]
[28540.380234] [<ffffffffa0094594>] ? sdhci_finish_data+0xf4/0x340 [sdhci]
[28540.380255] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[28540.380277] [<ffffffffa009485a>] ? sdhci_timeout_timer+0x7a/0xb0 [sdhci]
[28540.380297] [<ffffffff810e3a20>] ? call_timer_fn+0x30/0x130
[28540.380319] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[28540.380339] [<ffffffff810e5736>] ? run_timer_softirq+0x176/0x2d0
[28540.380357] [<ffffffff81081d1a>] ? __do_softirq+0x11a/0x2c0
[28540.380373] [<ffffffff81082008>] ? irq_exit+0x88/0x90
[28540.380392] [<ffffffff815dbaee>] ? smp_apic_timer_interrupt+0x3e/0x50
[28540.380411] [<ffffffff815d9de2>] ? apic_timer_interrupt+0x82/0x90
[28540.380419] <EOI> [<ffffffff814972ec>] ? cpuidle_enter_state+0x13c/0x2b0
[28540.380449] [<ffffffff814972c7>] ? cpuidle_enter_state+0x117/0x2b0
[28540.380468] [<ffffffff810bf0c6>] ? cpu_startup_entry+0x346/0x3b0
[28540.380485] [<ffffffff810f39ab>] ? tick_check_new_device+0xcb/0xf0
[28540.380502] [<ffffffff81050602>] ? start_secondary+0x152/0x190
[28540.380517] ---[ end trace 35a2ee1a4f956543 ]---
[28540.382700] mmcblk0: error -110 sending stop command, original cmd response 0x0, card status 0x400900
[28540.382769] mmcblk0: error -110 transferring data, sector 6084608, nr 320, cmd response 0x0, card status 0x0
[28540.394267] blk_update_request: I/O error, dev mmcblk0, sector 6084608
[28540.401784] blk_update_request: I/O error, dev mmcblk0, sector 6084616
[28540.409253] blk_update_request: I/O error, dev mmcblk0, sector 6084624
[28540.416702] blk_update_request: I/O error, dev mmcblk0, sector 6084632
[28540.424102] blk_update_request: I/O error, dev mmcblk0, sector 6084640
[28540.431496] blk_update_request: I/O error, dev mmcblk0, sector 6084648
[28540.438885] blk_update_request: I/O error, dev mmcblk0, sector 6084656
[28540.446271] blk_update_request: I/O error, dev mmcblk0, sector 6084664
[28540.453660] blk_update_request: I/O error, dev mmcblk0, sector 6084672
[28540.461070] EXT4-fs warning (device mmcblk0p3): ext4_end_bio:329: I/O error -5 writing to inode 928423 (offset 0 size 0 starting block 760616)
[28540.461078] Buffer I/O error on device mmcblk0p3, logical block 747776
[28540.468473] Buffer I/O error on device mmcblk0p3, logical block 747777
[28540.475862] Buffer I/O error on device mmcblk0p3, logical block 747778
[28540.483254] Buffer I/O error on device mmcblk0p3, logical block 747779
[28540.490642] Buffer I/O error on device mmcblk0p3, logical block 747780
[28540.498043] Buffer I/O error on device mmcblk0p3, logical block 747781
[28540.505443] Buffer I/O error on device mmcblk0p3, logical block 747782
[28540.512848] Buffer I/O error on device mmcblk0p3, logical block 747783
[28540.520236] Buffer I/O error on device mmcblk0p3, logical block 747784
[31222.229442] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[31232.262190] mmc0: Timeout waiting for hardware interrupt.
[31232.270387]
[ cut here ]
[31232.270427] WARNING: CPU: 0 PID: 0 at /tmp/buildd/linux-ubilinux-4.4.13/drivers/mmc/host/sdhci.c:1017 sdhci_send_command+0x770/0xc30 [sdhci]()
[31232.270432] Modules linked in: tun nfsd auth_rpcgss oid_registry nfs_acl nfs lockd grace fscache sunrpc sg sd_mod sr_mod cdrom intel_rapl intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul nls_utf8 nls_cp437 vfat fat jitterentropy_rng hdmi_audio cdc_acm sha256_ssse3 sha256_generic hmac drbg ansi_cprng iTCO_wdt dwc3 iTCO_vendor_support udc_core spidev evdev aesni_intel aes_x86_64 lrw gf128mul glue_helper ablk_helper cryptd i915 efi_pstore option usb_wwan efivars snd_pcm usb_storage snd_timer snd scsi_mod ftdi_sio usbserial soundcore ti_adc081c drm_kms_helper iosf_mbi drm lpc_ich dwc3_pci shpchp mfd_core 8250_fintek i2c_algo_bit video industrialio battery spi_pxa2xx_platform tpm_crb pwm_lpss_platform pwm_lpss int3400_thermal tpm_tis int3403_thermal tpm acpi_thermal_rel
[31232.270750] int340x_thermal_zone ac acpi_pad button processor i2c_dev fuse parport_pc ppdev lp parport autofs4 ext4 crc16 mbcache jbd2 hid_generic usbhid hid mmc_block crc32c_intel xhci_pci xhci_hcd r8169 mii usbcore usb_common thermal fjes sdhci_acpi sdhci mmc_core
[31232.270908] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G W 4.4.0-ubi3-amd64 #1 Debian 4.4.13-1
[31232.270920] Hardware name: AAEON UP-CHT01/UP-CHT01, BIOS UPC1BM0S 06/04/2016
[31232.270931] 0000000000000086 cb11619bc5cd881a ffffffff81306017 0000000000000000
[31232.270952] ffffffffa0096460 ffffffff8107d143 ffff88005a808540 ffff880036d32ad8
[31232.270970] 0000000000000001 0000000000000001 ffff88005a808540 ffffffffa0093820
[31232.270987] Call Trace:
[31232.271000] <IRQ> [<ffffffff81306017>] ? dump_stack+0x5c/0x85
[31232.271046] [<ffffffff8107d143>] ? warn_slowpath_common+0x83/0xc0
[31232.271070] [<ffffffffa0093820>] ? sdhci_send_command+0x770/0xc30 [sdhci]
[31232.271093] [<ffffffffa0090b65>] ? sdhci_reset+0x55/0xc0 [sdhci]
[31232.271115] [<ffffffffa0094594>] ? sdhci_finish_data+0xf4/0x340 [sdhci]
[31232.271137] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[31232.271158] [<ffffffffa009485a>] ? sdhci_timeout_timer+0x7a/0xb0 [sdhci]
[31232.271178] [<ffffffff810e3a20>] ? call_timer_fn+0x30/0x130
[31232.271199] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[31232.271218] [<ffffffff810e5736>] ? run_timer_softirq+0x176/0x2d0
[31232.271237] [<ffffffff81081d1a>] ? __do_softirq+0x11a/0x2c0
[31232.271253] [<ffffffff81082008>] ? irq_exit+0x88/0x90
[31232.271271] [<ffffffff815dbaee>] ? smp_apic_timer_interrupt+0x3e/0x50
[31232.271291] [<ffffffff815d9de2>] ? apic_timer_interrupt+0x82/0x90
[31232.271299] <EOI> [<ffffffff814972ec>] ? cpuidle_enter_state+0x13c/0x2b0
[31232.271335] [<ffffffff810bf0c6>] ? cpu_startup_entry+0x346/0x3b0
[31232.271357] [<ffffffff81b3af9a>] ? start_kernel+0x487/0x4a8
[31232.271375] [<ffffffff81b3a120>] ? early_idt_handler_array+0x120/0x120
[31232.271390] [<ffffffff81b3a611>] ? x86_64_start_kernel+0x156/0x17b
[31232.271403] ---[ end trace 35a2ee1a4f956544 ]---
[31232.274089] mmcblk0: error -110 sending stop command, original cmd response 0x0, card status 0x400900
[31232.274146] mmcblk0: error -110 transferring data, sector 6126952, nr 8, cmd response 0x0, card status 0x0
[31232.287376] blk_update_request: 31 callbacks suppressed
[31232.287381] blk_update_request: I/O error, dev mmcblk0, sector 6126952
[31232.296147] EXT4-fs warning (device mmcblk0p3): ext4_end_bio:329: I/O error -5 writing to inode 928425 (offset 0 size 0 starting block 765870)
[31232.296164] buffer_io_error: 31 callbacks suppressed
[31232.296168] Buffer I/O error on device mmcblk0p3, logical block 753069
[32570.323363] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[35822.583918] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[35832.592499] mmc0: Timeout waiting for hardware interrupt.
[35832.605505]
[ cut here ]
[35832.605550] WARNING: CPU: 3 PID: 0 at /tmp/buildd/linux-ubilinux-4.4.13/drivers/mmc/host/sdhci.c:1017 sdhci_send_command+0x770/0xc30 [sdhci]()
[35832.605560] Modules linked in: tun nfsd auth_rpcgss oid_registry nfs_acl nfs lockd grace fscache sunrpc sg sd_mod sr_mod cdrom intel_rapl intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul nls_utf8 nls_cp437 vfat fat jitterentropy_rng hdmi_audio cdc_acm sha256_ssse3 sha256_generic hmac drbg ansi_cprng iTCO_wdt dwc3 iTCO_vendor_support udc_core spidev evdev aesni_intel aes_x86_64 lrw gf128mul glue_helper ablk_helper cryptd i915 efi_pstore option usb_wwan efivars snd_pcm usb_storage snd_timer snd scsi_mod ftdi_sio usbserial soundcore ti_adc081c drm_kms_helper iosf_mbi drm lpc_ich dwc3_pci shpchp mfd_core 8250_fintek i2c_algo_bit video industrialio battery spi_pxa2xx_platform tpm_crb pwm_lpss_platform pwm_lpss int3400_thermal tpm_tis int3403_thermal tpm acpi_thermal_rel
[35832.605934] int340x_thermal_zone ac acpi_pad button processor i2c_dev fuse parport_pc ppdev lp parport autofs4 ext4 crc16 mbcache jbd2 hid_generic usbhid hid mmc_block crc32c_intel xhci_pci xhci_hcd r8169 mii usbcore usb_common thermal fjes sdhci_acpi sdhci mmc_core
[35832.606093] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G W 4.4.0-ubi3-amd64 #1 Debian 4.4.13-1
[35832.606104] Hardware name: AAEON UP-CHT01/UP-CHT01, BIOS UPC1BM0S 06/04/2016
[35832.606115] 0000000000000086 4868efd746ab5c51 ffffffff81306017 0000000000000000
[35832.606137] ffffffffa0096460 ffffffff8107d143 ffff88005a808540 ffff880036d32930
[35832.606155] 0000000000000001 0000000000000001 ffff88005a808540 ffffffffa0093820
[35832.606172] Call Trace:
[35832.606184] <IRQ> [<ffffffff81306017>] ? dump_stack+0x5c/0x85
[35832.606229] [<ffffffff8107d143>] ? warn_slowpath_common+0x83/0xc0
[35832.606254] [<ffffffffa0093820>] ? sdhci_send_command+0x770/0xc30 [sdhci]
[35832.606276] [<ffffffffa0090b65>] ? sdhci_reset+0x55/0xc0 [sdhci]
[35832.606298] [<ffffffffa0094594>] ? sdhci_finish_data+0xf4/0x340 [sdhci]
[35832.606320] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[35832.606342] [<ffffffffa009485a>] ? sdhci_timeout_timer+0x7a/0xb0 [sdhci]
[35832.606362] [<ffffffff810e3a20>] ? call_timer_fn+0x30/0x130
[35832.606383] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[35832.606402] [<ffffffff810e5736>] ? run_timer_softirq+0x176/0x2d0
[35832.606421] [<ffffffff81081d1a>] ? __do_softirq+0x11a/0x2c0
[35832.606437] [<ffffffff81082008>] ? irq_exit+0x88/0x90
[35832.606455] [<ffffffff815dbaee>] ? smp_apic_timer_interrupt+0x3e/0x50
[35832.606474] [<ffffffff815d9de2>] ? apic_timer_interrupt+0x82/0x90
[35832.606483] <EOI> [<ffffffff814972ec>] ? cpuidle_enter_state+0x13c/0x2b0
[35832.606511] [<ffffffff814972c7>] ? cpuidle_enter_state+0x117/0x2b0
[35832.606531] [<ffffffff810bf0c6>] ? cpu_startup_entry+0x346/0x3b0
[35832.606547] [<ffffffff810f39ab>] ? tick_check_new_device+0xcb/0xf0
[35832.606563] [<ffffffff81050602>] ? start_secondary+0x152/0x190
[35832.606579] ---[ end trace 35a2ee1a4f956545 ]---
[35832.608771] mmcblk0: error -110 sending stop command, original cmd response 0x0, card status 0x400900
[35832.608850] mmcblk0: error -110 transferring data, sector 30053344, nr 8, cmd response 0x0, card status 0x0
[35832.622686] blk_update_request: I/O error, dev mmcblk0, sector 30053344
[35832.632070] EXT4-fs warning (device mmcblk0p3): ext4_end_bio:329: I/O error -5 writing to inode 932280 (offset 0 size 0 starting block 3756669)
[35832.632082] Buffer I/O error on device mmcblk0p3, logical block 3743868
[38098.803293] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[38108.836088] mmc0: Timeout waiting for hardware interrupt.
[38108.850034]
[ cut here ]
[38108.850079] WARNING: CPU: 0 PID: 0 at /tmp/buildd/linux-ubilinux-4.4.13/drivers/mmc/host/sdhci.c:1017 sdhci_send_command+0x770/0xc30 [sdhci]()
[38108.850089] Modules linked in: tun nfsd auth_rpcgss oid_registry nfs_acl nfs lockd grace fscache sunrpc sg sd_mod sr_mod cdrom intel_rapl intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul nls_utf8 nls_cp437 vfat fat jitterentropy_rng hdmi_audio cdc_acm sha256_ssse3 sha256_generic hmac drbg ansi_cprng iTCO_wdt dwc3 iTCO_vendor_support udc_core spidev evdev aesni_intel aes_x86_64 lrw gf128mul glue_helper ablk_helper cryptd i915 efi_pstore option usb_wwan efivars snd_pcm usb_storage snd_timer snd scsi_mod ftdi_sio usbserial soundcore ti_adc081c drm_kms_helper iosf_mbi drm lpc_ich dwc3_pci shpchp mfd_core 8250_fintek i2c_algo_bit video industrialio battery spi_pxa2xx_platform tpm_crb pwm_lpss_platform pwm_lpss int3400_thermal tpm_tis int3403_thermal tpm acpi_thermal_rel
[38108.850466] int340x_thermal_zone ac acpi_pad button processor i2c_dev fuse parport_pc ppdev lp parport autofs4 ext4 crc16 mbcache jbd2 hid_generic usbhid hid mmc_block crc32c_intel xhci_pci xhci_hcd r8169 mii usbcore usb_common thermal fjes sdhci_acpi sdhci mmc_core
[38108.850625] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G W 4.4.0-ubi3-amd64 #1 Debian 4.4.13-1
[38108.850637] Hardware name: AAEON UP-CHT01/UP-CHT01, BIOS UPC1BM0S 06/04/2016
[38108.850648] 0000000000000086 cb11619bc5cd881a ffffffff81306017 0000000000000000
[38108.850669] ffffffffa0096460 ffffffff8107d143 ffff88005a808540 ffff880036d32930
[38108.850687] 0000000000000001 0000000000000001 ffff88005a808540 ffffffffa0093820
[38108.850706] Call Trace:
[38108.850718] <IRQ> [<ffffffff81306017>] ? dump_stack+0x5c/0x85
[38108.850765] [<ffffffff8107d143>] ? warn_slowpath_common+0x83/0xc0
[38108.850789] [<ffffffffa0093820>] ? sdhci_send_command+0x770/0xc30 [sdhci]
[38108.850812] [<ffffffffa0090b65>] ? sdhci_reset+0x55/0xc0 [sdhci]
[38108.850834] [<ffffffffa0094594>] ? sdhci_finish_data+0xf4/0x340 [sdhci]
[38108.850856] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[38108.850878] [<ffffffffa009485a>] ? sdhci_timeout_timer+0x7a/0xb0 [sdhci]
[38108.850898] [<ffffffff810e3a20>] ? call_timer_fn+0x30/0x130
[38108.850919] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[38108.850939] [<ffffffff810e5736>] ? run_timer_softirq+0x176/0x2d0
[38108.850957] [<ffffffff81081d1a>] ? __do_softirq+0x11a/0x2c0
[38108.850974] [<ffffffff81082008>] ? irq_exit+0x88/0x90
[38108.850992] [<ffffffff815dbaee>] ? smp_apic_timer_interrupt+0x3e/0x50
[38108.851011] [<ffffffff815d9de2>] ? apic_timer_interrupt+0x82/0x90
[38108.851020] <EOI> [<ffffffff814972ec>] ? cpuidle_enter_state+0x13c/0x2b0
[38108.851054] [<ffffffff810bf0c6>] ? cpu_startup_entry+0x346/0x3b0
[38108.851076] [<ffffffff81b3af9a>] ? start_kernel+0x487/0x4a8
[38108.851096] [<ffffffff81b3a120>] ? early_idt_handler_array+0x120/0x120
[38108.851111] [<ffffffff81b3a611>] ? x86_64_start_kernel+0x156/0x17b
[38108.851123] ---[ end trace 35a2ee1a4f956546 ]---
[38108.853647] mmcblk0: error -110 sending stop command, original cmd response 0x0, card status 0x400900
[38108.853724] mmcblk0: error -110 transferring data, sector 6108344, nr 8, cmd response 0x0, card status 0x0
[38108.867856] blk_update_request: I/O error, dev mmcblk0, sector 6108344
[38108.877534] EXT4-fs warning (device mmcblk0p3): ext4_end_bio:329: I/O error -5 writing to inode 928424 (offset 0 size 0 starting block 763544)
[38108.877552] Buffer I/O error on device mmcblk0p3, logical block 750743
[40819.485380] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[50362.305532] systemd-default-display-manager-generator[11117]: /etc/X11/default-display-manager points at lightdm while the default systemd unit is . Reconfiguring lightdm as default.
[50362.875392] systemd-default-display-manager-generator[11146]: /etc/X11/default-display-manager points at lightdm while the default systemd unit is . Reconfiguring lightdm as default.
[50363.020490] systemd-default-display-manager-generator[11181]: /etc/X11/default-display-manager points at lightdm while the default systemd unit is . Reconfiguring lightdm as default.
[50363.238375] systemd-default-display-manager-generator[11204]: /etc/X11/default-display-manager points at lightdm while the default systemd unit is . Reconfiguring lightdm as default.
[58818.065422] systemd-default-display-manager-generator[1730]: /etc/X11/default-display-manager points at lightdm while the default systemd unit is . Reconfiguring lightdm as default.
[58820.849796] systemd-default-display-manager-generator[2481]: /etc/X11/default-display-manager points at lightdm while the default systemd unit is . Reconfiguring lightdm as default.
[58821.094508] systemd-default-display-manager-generator[2503]: /etc/X11/default-display-manager points at lightdm while the default systemd unit is . Reconfiguring lightdm as default.
[58821.244111] systemd-default-display-manager-generator[2536]: /etc/X11/default-display-manager points at lightdm while the default systemd unit is . Reconfiguring lightdm as default.
[58821.637366] systemd-default-display-manager-generator[2572]: /etc/X11/default-display-manager points at lightdm while the default systemd unit is . Reconfiguring lightdm as default.
[62633.626426] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[66330.802935] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[66331.807028] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[66341.827771] mmc0: Timeout waiting for hardware interrupt.
[66341.839300]
[ cut here ]
[66341.839323] WARNING: CPU: 0 PID: 0 at /tmp/buildd/linux-ubilinux-4.4.13/drivers/mmc/host/sdhci.c:1017 sdhci_send_command+0x770/0xc30 [sdhci]()
[66341.839329] Modules linked in: tun nfsd auth_rpcgss oid_registry nfs_acl nfs lockd grace fscache sunrpc sg sd_mod sr_mod cdrom intel_rapl intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul nls_utf8 nls_cp437 vfat fat jitterentropy_rng hdmi_audio cdc_acm sha256_ssse3 sha256_generic hmac drbg ansi_cprng iTCO_wdt dwc3 iTCO_vendor_support udc_core spidev evdev aesni_intel aes_x86_64 lrw gf128mul glue_helper ablk_helper cryptd i915 efi_pstore option usb_wwan efivars snd_pcm usb_storage snd_timer snd scsi_mod ftdi_sio usbserial soundcore ti_adc081c drm_kms_helper iosf_mbi drm lpc_ich dwc3_pci shpchp mfd_core 8250_fintek i2c_algo_bit video industrialio battery spi_pxa2xx_platform tpm_crb pwm_lpss_platform pwm_lpss int3400_thermal tpm_tis int3403_thermal tpm acpi_thermal_rel
[66341.839572] int340x_thermal_zone ac acpi_pad button processor i2c_dev fuse parport_pc ppdev lp parport autofs4 ext4 crc16 mbcache jbd2 hid_generic usbhid hid mmc_block crc32c_intel xhci_pci xhci_hcd r8169 mii usbcore usb_common thermal fjes sdhci_acpi sdhci mmc_core
[66341.839677] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G W 4.4.0-ubi3-amd64 #1 Debian 4.4.13-1
[66341.839683] Hardware name: AAEON UP-CHT01/UP-CHT01, BIOS UPC1BM0S 06/04/2016
[66341.839689] 0000000000000086 cb11619bc5cd881a ffffffff81306017 0000000000000000
[66341.839700] ffffffffa0096460 ffffffff8107d143 ffff88005a808540 ffff880036d32ad8
[66341.839709] 0000000000000002 0000000000000001 ffff88005a808540 ffffffffa0093820
[66341.839719] Call Trace:
[66341.839726] <IRQ> [<ffffffff81306017>] ? dump_stack+0x5c/0x85
[66341.839753] [<ffffffff8107d143>] ? warn_slowpath_common+0x83/0xc0
[66341.839765] [<ffffffffa0093820>] ? sdhci_send_command+0x770/0xc30 [sdhci]
[66341.839776] [<ffffffffa0090b65>] ? sdhci_reset+0x55/0xc0 [sdhci]
[66341.839787] [<ffffffffa0094594>] ? sdhci_finish_data+0xf4/0x340 [sdhci]
[66341.839798] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[66341.839809] [<ffffffffa009485a>] ? sdhci_timeout_timer+0x7a/0xb0 [sdhci]
[66341.839820] [<ffffffff810e3a20>] ? call_timer_fn+0x30/0x130
[66341.839831] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[66341.839841] [<ffffffff810e5736>] ? run_timer_softirq+0x176/0x2d0
[66341.839851] [<ffffffff81081d1a>] ? __do_softirq+0x11a/0x2c0
[66341.839859] [<ffffffff81082008>] ? irq_exit+0x88/0x90
[66341.839870] [<ffffffff815dbaee>] ? smp_apic_timer_interrupt+0x3e/0x50
[66341.839879] [<ffffffff815d9de2>] ? apic_timer_interrupt+0x82/0x90
[66341.839883] <EOI> [<ffffffff814972ec>] ? cpuidle_enter_state+0x13c/0x2b0
[66341.839903] [<ffffffff810bf0c6>] ? cpu_startup_entry+0x346/0x3b0
[66341.839915] [<ffffffff81b3af9a>] ? start_kernel+0x487/0x4a8
[66341.839924] [<ffffffff81b3a120>] ? early_idt_handler_array+0x120/0x120
[66341.839932] [<ffffffff81b3a611>] ? x86_64_start_kernel+0x156/0x17b
[66341.839939] ---[ end trace 35a2ee1a4f956547 ]---
[66341.842306] mmcblk0: error -110 sending stop command, original cmd response 0x0, card status 0x400900
[66341.842379] mmcblk0: error -110 transferring data, sector 6084608, nr 64, cmd response 0x0, card status 0x0
[66341.856187] blk_update_request: I/O error, dev mmcblk0, sector 6084608
[66341.870181] blk_update_request: I/O error, dev mmcblk0, sector 6084616
[66341.880126] blk_update_request: I/O error, dev mmcblk0, sector 6084624
[66341.889671] blk_update_request: I/O error, dev mmcblk0, sector 6084632
[66341.899092] blk_update_request: I/O error, dev mmcblk0, sector 6084640
[66341.908515] blk_update_request: I/O error, dev mmcblk0, sector 6084648
[66341.917940] blk_update_request: I/O error, dev mmcblk0, sector 6084656
[66341.927370] blk_update_request: I/O error, dev mmcblk0, sector 6084664
[66341.936800] EXT4-fs warning (device mmcblk0p3): ext4_end_bio:329: I/O error -5 writing to inode 928423 (offset 0 size 0 starting block 760584)
[66341.936815] Buffer I/O error on device mmcblk0p3, logical block 747776
[66341.946303] Buffer I/O error on device mmcblk0p3, logical block 747777
[66341.955730] Buffer I/O error on device mmcblk0p3, logical block 747778
[66341.965072] Buffer I/O error on device mmcblk0p3, logical block 747779
[66341.974327] Buffer I/O error on device mmcblk0p3, logical block 747780
[66341.983536] Buffer I/O error on device mmcblk0p3, logical block 747781
[66341.992683] Buffer I/O error on device mmcblk0p3, logical block 747782
[66342.001743] Buffer I/O error on device mmcblk0p3, logical block 747783
[66373.746291] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[66375.798418] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[66384.011066] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[66385.011167] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[66395.047910] mmc0: Timeout waiting for hardware interrupt.
[66395.058928]
[ cut here ]
[66395.058954] WARNING: CPU: 0 PID: 0 at /tmp/buildd/linux-ubilinux-4.4.13/drivers/mmc/host/sdhci.c:1017 sdhci_send_command+0x770/0xc30 [sdhci]()
[66395.058959] Modules linked in: tun nfsd auth_rpcgss oid_registry nfs_acl nfs lockd grace fscache sunrpc sg sd_mod sr_mod cdrom intel_rapl intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul nls_utf8 nls_cp437 vfat fat jitterentropy_rng hdmi_audio cdc_acm sha256_ssse3 sha256_generic hmac drbg ansi_cprng iTCO_wdt dwc3 iTCO_vendor_support udc_core spidev evdev aesni_intel aes_x86_64 lrw gf128mul glue_helper ablk_helper cryptd i915 efi_pstore option usb_wwan efivars snd_pcm usb_storage snd_timer snd scsi_mod ftdi_sio usbserial soundcore ti_adc081c drm_kms_helper iosf_mbi drm lpc_ich dwc3_pci shpchp mfd_core 8250_fintek i2c_algo_bit video industrialio battery spi_pxa2xx_platform tpm_crb pwm_lpss_platform pwm_lpss int3400_thermal tpm_tis int3403_thermal tpm acpi_thermal_rel
[66395.059204] int340x_thermal_zone ac acpi_pad button processor i2c_dev fuse parport_pc ppdev lp parport autofs4 ext4 crc16 mbcache jbd2 hid_generic usbhid hid mmc_block crc32c_intel xhci_pci xhci_hcd r8169 mii usbcore usb_common thermal fjes sdhci_acpi sdhci mmc_core
[66395.059311] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G W 4.4.0-ubi3-amd64 #1 Debian 4.4.13-1
[66395.059317] Hardware name: AAEON UP-CHT01/UP-CHT01, BIOS UPC1BM0S 06/04/2016
[66395.059324] 0000000000000086 cb11619bc5cd881a ffffffff81306017 0000000000000000
[66395.059334] ffffffffa0096460 ffffffff8107d143 ffff88005a808540 ffff880036d32930
[66395.059343] 0000000000000003 0000000000000001 ffff88005a808540 ffffffffa0093820
[66395.059352] Call Trace:
[66395.059359] <IRQ> [<ffffffff81306017>] ? dump_stack+0x5c/0x85
[66395.059384] [<ffffffff8107d143>] ? warn_slowpath_common+0x83/0xc0
[66395.059397] [<ffffffffa0093820>] ? sdhci_send_command+0x770/0xc30 [sdhci]
[66395.059408] [<ffffffffa0090b65>] ? sdhci_reset+0x55/0xc0 [sdhci]
[66395.059419] [<ffffffffa0094594>] ? sdhci_finish_data+0xf4/0x340 [sdhci]
[66395.059430] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[66395.059441] [<ffffffffa009485a>] ? sdhci_timeout_timer+0x7a/0xb0 [sdhci]
[66395.059452] [<ffffffff810e3a20>] ? call_timer_fn+0x30/0x130
[66395.059463] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[66395.059473] [<ffffffff810e5736>] ? run_timer_softirq+0x176/0x2d0
[66395.059483] [<ffffffff81081d1a>] ? __do_softirq+0x11a/0x2c0
[66395.059491] [<ffffffff81082008>] ? irq_exit+0x88/0x90
[66395.059502] [<ffffffff815dbaee>] ? smp_apic_timer_interrupt+0x3e/0x50
[66395.059511] [<ffffffff815d9de2>] ? apic_timer_interrupt+0x82/0x90
[66395.059516] <EOI> [<ffffffff814972ec>] ? cpuidle_enter_state+0x13c/0x2b0
[66395.059536] [<ffffffff810bf0c6>] ? cpu_startup_entry+0x346/0x3b0
[66395.059548] [<ffffffff81b3af9a>] ? start_kernel+0x487/0x4a8
[66395.059558] [<ffffffff81b3a120>] ? early_idt_handler_array+0x120/0x120
[66395.059565] [<ffffffff81b3a611>] ? x86_64_start_kernel+0x156/0x17b
[66395.059572] ---[ end trace 35a2ee1a4f956548 ]---
[66395.062170] mmcblk0: error -110 sending stop command, original cmd response 0x0, card status 0x400900
[66395.062208] mmcblk0: error -110 transferring data, sector 6084608, nr 160, cmd response 0x0, card status 0x0
[66395.075080] blk_update_request: I/O error, dev mmcblk0, sector 6084608
[66395.084281] blk_update_request: I/O error, dev mmcblk0, sector 6084616
[66395.093471] blk_update_request: I/O error, dev mmcblk0, sector 6084624
[66395.102666] blk_update_request: I/O error, dev mmcblk0, sector 6084632
[66395.111867] blk_update_request: I/O error, dev mmcblk0, sector 6084640
[66395.121068] blk_update_request: I/O error, dev mmcblk0, sector 6084648
[66395.121070] blk_update_request: I/O error, dev mmcblk0, sector 6084656
[66395.121072] blk_update_request: I/O error, dev mmcblk0, sector 6084664
[66395.121074] blk_update_request: I/O error, dev mmcblk0, sector 6084672
[66395.121076] blk_update_request: I/O error, dev mmcblk0, sector 6084680
[66395.121085] EXT4-fs warning (device mmcblk0p3): ext4_end_bio:329: I/O error -5 writing to inode 928423 (offset 0 size 0 starting block 760596)
[66395.121103] Buffer I/O error on device mmcblk0p3, logical block 747776
[66395.121114] Buffer I/O error on device mmcblk0p3, logical block 747777
[66395.121117] Buffer I/O error on device mmcblk0p3, logical block 747778
[66395.121120] Buffer I/O error on device mmcblk0p3, logical block 747779
[66395.121122] Buffer I/O error on device mmcblk0p3, logical block 747780
[66395.121125] Buffer I/O error on device mmcblk0p3, logical block 747781
[66395.121127] Buffer I/O error on device mmcblk0p3, logical block 747782
[66395.121129] Buffer I/O error on device mmcblk0p3, logical block 747783
[66395.121131] Buffer I/O error on device mmcblk0p3, logical block 747784
[66395.121133] Buffer I/O error on device mmcblk0p3, logical block 747785
[77031.092309] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[79179.956662] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[88961.135510] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[96938.944793] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[97965.677187] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[97970.681584] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[98176.101454] systemd-default-display-manager-generator[27801]: /etc/X11/default-display-manager points at lightdm while the default systemd unit is . Reconfiguring lightdm as default.
[98177.939855] systemd-default-display-manager-generator[28438]: /etc/X11/default-display-manager points at lightdm while the default systemd unit is . Reconfiguring lightdm as default.
[98178.056153] systemd-default-display-manager-generator[28455]: /etc/X11/default-display-manager points at lightdm while the default systemd unit is . Reconfiguring lightdm as default.
[98178.412761] systemd-default-display-manager-generator[28480]: /etc/X11/default-display-manager points at lightdm while the default systemd unit is . Reconfiguring lightdm as default.
[98178.628223] systemd-default-display-manager-generator[28510]: /etc/X11/default-display-manager points at lightdm while the default systemd unit is . Reconfiguring lightdm as default.
[98364.228357] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[99002.614317] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[99894.664082] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[106504.225325] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[112796.743985] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[114938.666837] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[114940.130966] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[118492.066124] r8169 0000:01:00.0 eth0: link down
[118494.519768] r8169 0000:01:00.0 eth0: link down
[118494.519851] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[118494.783790] r8169 0000:01:00.0 eth0: link down
[118494.783873] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[118500.879398] r8169 0000:01:00.0 eth0: link up
[118500.879420] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[118505.500587] r8169 0000:01:00.0 eth0: link down
[118505.500623] r8169 0000:01:00.0 eth0: link down
[118505.500679] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[118505.692755] r8169 0000:01:00.0 eth0: link down
[118505.692832] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[118508.760638] r8169 0000:01:00.0 eth0: link up
[118508.760662] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[118518.092130] r8169 0000:01:00.0 eth0: link down
[118520.667217] r8169 0000:01:00.0 eth0: link up
[118528.194392] r8169 0000:01:00.0 eth0: link down
[118528.194403] r8169 0000:01:00.0 eth0: link down
[118528.194487] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[118530.797132] r8169 0000:01:00.0 eth0: link up
[118530.797157] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[122147.217447] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[132605.625983] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[145839.666930] nr_pdflush_threads exported in /proc is scheduled for removal
[148692.015863] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[148807.592860] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[152398.612482] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[156598.873181] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[156744.108551] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[158862.946639] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[159885.706986] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[165008.557693] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[174609.063078] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[175077.115742] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[176513.252247] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[176523.261026] mmc0: Timeout waiting for hardware interrupt.
[176523.270642]
[ cut here ]
[176523.270656] WARNING: CPU: 3 PID: 0 at /tmp/buildd/linux-ubilinux-4.4.13/drivers/mmc/host/sdhci.c:1017 sdhci_send_command+0x770/0xc30 [sdhci]()
[176523.270659] Modules linked in: binfmt_misc tun nfsd auth_rpcgss oid_registry nfs_acl nfs lockd grace fscache sunrpc sg sd_mod sr_mod cdrom intel_rapl intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul nls_utf8 nls_cp437 vfat fat jitterentropy_rng hdmi_audio cdc_acm sha256_ssse3 sha256_generic hmac drbg ansi_cprng iTCO_wdt dwc3 iTCO_vendor_support udc_core spidev evdev aesni_intel aes_x86_64 lrw gf128mul glue_helper ablk_helper cryptd i915 efi_pstore option usb_wwan efivars snd_pcm usb_storage snd_timer snd scsi_mod ftdi_sio usbserial soundcore ti_adc081c drm_kms_helper iosf_mbi drm lpc_ich dwc3_pci shpchp mfd_core 8250_fintek i2c_algo_bit video industrialio battery spi_pxa2xx_platform tpm_crb pwm_lpss_platform pwm_lpss int3400_thermal tpm_tis int3403_thermal tpm acpi_thermal_rel
[176523.270750] int340x_thermal_zone ac acpi_pad button processor i2c_dev fuse parport_pc ppdev lp parport autofs4 ext4 crc16 mbcache jbd2 hid_generic usbhid hid mmc_block crc32c_intel xhci_pci xhci_hcd r8169 mii usbcore usb_common thermal fjes sdhci_acpi sdhci mmc_core
[176523.270787] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G W 4.4.0-ubi3-amd64 #1 Debian 4.4.13-1
[176523.270790] Hardware name: AAEON UP-CHT01/UP-CHT01, BIOS UPC1BM0S 06/04/2016
[176523.270794] 0000000000000086 4868efd746ab5c51 ffffffff81306017 0000000000000000
[176523.270799] ffffffffa0096460 ffffffff8107d143 ffff88005a808540 ffff880036d32ad8
[176523.270804] 0000000000000001 0000000000000001 ffff88005a808540 ffffffffa0093820
[176523.270810] Call Trace:
[176523.270813] <IRQ> [<ffffffff81306017>] ? dump_stack+0x5c/0x85
[176523.270828] [<ffffffff8107d143>] ? warn_slowpath_common+0x83/0xc0
[176523.270835] [<ffffffffa0093820>] ? sdhci_send_command+0x770/0xc30 [sdhci]
[176523.270842] [<ffffffffa0090b65>] ? sdhci_reset+0x55/0xc0 [sdhci]
[176523.270848] [<ffffffffa0094594>] ? sdhci_finish_data+0xf4/0x340 [sdhci]
[176523.270854] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[176523.270861] [<ffffffffa009485a>] ? sdhci_timeout_timer+0x7a/0xb0 [sdhci]
[176523.270867] [<ffffffff810e3a20>] ? call_timer_fn+0x30/0x130
[176523.270873] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[176523.270878] [<ffffffff810e5736>] ? run_timer_softirq+0x176/0x2d0
[176523.270883] [<ffffffff81081d1a>] ? __do_softirq+0x11a/0x2c0
[176523.270887] [<ffffffff81082008>] ? irq_exit+0x88/0x90
[176523.270893] [<ffffffff815dbaee>] ? smp_apic_timer_interrupt+0x3e/0x50
[176523.270899] [<ffffffff815d9de2>] ? apic_timer_interrupt+0x82/0x90
[176523.270901] <EOI> [<ffffffff814972ec>] ? cpuidle_enter_state+0x13c/0x2b0
[176523.270910] [<ffffffff814972c7>] ? cpuidle_enter_state+0x117/0x2b0
[176523.270916] [<ffffffff810bf0c6>] ? cpu_startup_entry+0x346/0x3b0
[176523.270921] [<ffffffff810f39ab>] ? tick_check_new_device+0xcb/0xf0
[176523.270926] [<ffffffff81050602>] ? start_secondary+0x152/0x190
[176523.270930] ---[ end trace 35a2ee1a4f956549 ]---
[176523.273053] mmcblk0: error -110 sending stop command, original cmd response 0x0, card status 0x400900
[176523.273110] mmcblk0: error -110 transferring data, sector 6126896, nr 8, cmd response 0x0, card status 0x0
[176523.289452] blk_update_request: 10 callbacks suppressed
[176523.289468] blk_update_request: I/O error, dev mmcblk0, sector 6126896
[176523.301365] EXT4-fs warning (device mmcblk0p3): ext4_end_bio:329: I/O error -5 writing to inode 928425 (offset 0 size 0 starting block 765863)
[176523.301376] buffer_io_error: 10 callbacks suppressed
[176523.301382] Buffer I/O error on device mmcblk0p3, logical block 753062
[177506.854124] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[183347.630099] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[183350.630337] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[183351.634373] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[183361.651136] mmc0: Timeout waiting for hardware interrupt.
[183361.664406]
[ cut here ]
[183361.664450] WARNING: CPU: 0 PID: 0 at /tmp/buildd/linux-ubilinux-4.4.13/drivers/mmc/host/sdhci.c:1017 sdhci_send_command+0x770/0xc30 [sdhci]()
[183361.664460] Modules linked in: binfmt_misc tun nfsd auth_rpcgss oid_registry nfs_acl nfs lockd grace fscache sunrpc sg sd_mod sr_mod cdrom intel_rapl intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul nls_utf8 nls_cp437 vfat fat jitterentropy_rng hdmi_audio cdc_acm sha256_ssse3 sha256_generic hmac drbg ansi_cprng iTCO_wdt dwc3 iTCO_vendor_support udc_core spidev evdev aesni_intel aes_x86_64 lrw gf128mul glue_helper ablk_helper cryptd i915 efi_pstore option usb_wwan efivars snd_pcm usb_storage snd_timer snd scsi_mod ftdi_sio usbserial soundcore ti_adc081c drm_kms_helper iosf_mbi drm lpc_ich dwc3_pci shpchp mfd_core 8250_fintek i2c_algo_bit video industrialio battery spi_pxa2xx_platform tpm_crb pwm_lpss_platform pwm_lpss int3400_thermal tpm_tis int3403_thermal tpm acpi_thermal_rel
[183361.664836] int340x_thermal_zone ac acpi_pad button processor i2c_dev fuse parport_pc ppdev lp parport autofs4 ext4 crc16 mbcache jbd2 hid_generic usbhid hid mmc_block crc32c_intel xhci_pci xhci_hcd r8169 mii usbcore usb_common thermal fjes sdhci_acpi sdhci mmc_core
[183361.664981] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G W 4.4.0-ubi3-amd64 #1 Debian 4.4.13-1
[183361.664992] Hardware name: AAEON UP-CHT01/UP-CHT01, BIOS UPC1BM0S 06/04/2016
[183361.665003] 0000000000000086 cb11619bc5cd881a ffffffff81306017 0000000000000000
[183361.665023] ffffffffa0096460 ffffffff8107d143 ffff88005a808540 ffff880036d32ad8
[183361.665041] 0000000000000002 0000000000000001 ffff88005a808540 ffffffffa0093820
[183361.665060] Call Trace:
[183361.665073] <IRQ> [<ffffffff81306017>] ? dump_stack+0x5c/0x85
[183361.665117] [<ffffffff8107d143>] ? warn_slowpath_common+0x83/0xc0
[183361.665142] [<ffffffffa0093820>] ? sdhci_send_command+0x770/0xc30 [sdhci]
[183361.665165] [<ffffffffa0090b65>] ? sdhci_reset+0x55/0xc0 [sdhci]
[183361.665187] [<ffffffffa0094594>] ? sdhci_finish_data+0xf4/0x340 [sdhci]
[183361.665209] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[183361.665231] [<ffffffffa009485a>] ? sdhci_timeout_timer+0x7a/0xb0 [sdhci]
[183361.665251] [<ffffffff810e3a20>] ? call_timer_fn+0x30/0x130
[183361.665272] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[183361.665292] [<ffffffff810e5736>] ? run_timer_softirq+0x176/0x2d0
[183361.665310] [<ffffffff81081d1a>] ? __do_softirq+0x11a/0x2c0
[183361.665326] [<ffffffff81082008>] ? irq_exit+0x88/0x90
[183361.665345] [<ffffffff815dbaee>] ? smp_apic_timer_interrupt+0x3e/0x50
[183361.665364] [<ffffffff815d9de2>] ? apic_timer_interrupt+0x82/0x90
[183361.665373] <EOI> [<ffffffff814972ec>] ? cpuidle_enter_state+0x13c/0x2b0
[183361.665407] [<ffffffff810bf0c6>] ? cpu_startup_entry+0x346/0x3b0
[183361.665428] [<ffffffff81b3af9a>] ? start_kernel+0x487/0x4a8
[183361.665447] [<ffffffff81b3a120>] ? early_idt_handler_array+0x120/0x120
[183361.665462] [<ffffffff81b3a611>] ? x86_64_start_kernel+0x156/0x17b
[183361.665475] ---[ end trace 35a2ee1a4f95654a ]---
[183361.667747] mmcblk0: error -110 sending stop command, original cmd response 0x0, card status 0x400900
[183361.667797] mmcblk0: error -110 transferring data, sector 6084608, nr 96, cmd response 0x0, card status 0x0
[183361.681529] blk_update_request: I/O error, dev mmcblk0, sector 6084608
[183361.691613] blk_update_request: I/O error, dev mmcblk0, sector 6084616
[183361.700652] blk_update_request: I/O error, dev mmcblk0, sector 6084624
[183361.709446] blk_update_request: I/O error, dev mmcblk0, sector 6084632
[183361.718155] blk_update_request: I/O error, dev mmcblk0, sector 6084640
[183361.726864] blk_update_request: I/O error, dev mmcblk0, sector 6084648
[183361.735576] blk_update_request: I/O error, dev mmcblk0, sector 6084656
[183361.744287] blk_update_request: I/O error, dev mmcblk0, sector 6084664
[183361.753003] blk_update_request: I/O error, dev mmcblk0, sector 6084672
[183361.761716] EXT4-fs warning (device mmcblk0p3): ext4_end_bio:329: I/O error -5 writing to inode 928423 (offset 0 size 0 starting block 760588)
[183361.761723] Buffer I/O error on device mmcblk0p3, logical block 747776
[183361.770494] Buffer I/O error on device mmcblk0p3, logical block 747777
[183361.779267] Buffer I/O error on device mmcblk0p3, logical block 747778
[183361.787977] Buffer I/O error on device mmcblk0p3, logical block 747779
[183361.796685] Buffer I/O error on device mmcblk0p3, logical block 747780
[183361.805393] Buffer I/O error on device mmcblk0p3, logical block 747781
[183361.814108] Buffer I/O error on device mmcblk0p3, logical block 747782
[183361.822821] Buffer I/O error on device mmcblk0p3, logical block 747783
[183361.831532] Buffer I/O error on device mmcblk0p3, logical block 747784
[183609.634523] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[183901.693317] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[183911.710109] mmc0: Timeout waiting for hardware interrupt.
[183911.722918]
[ cut here ]
[183911.722965] WARNING: CPU: 0 PID: 0 at /tmp/buildd/linux-ubilinux-4.4.13/drivers/mmc/host/sdhci.c:1017 sdhci_send_command+0x770/0xc30 [sdhci]()
[183911.722975] Modules linked in: binfmt_misc tun nfsd auth_rpcgss oid_registry nfs_acl nfs lockd grace fscache sunrpc sg sd_mod sr_mod cdrom intel_rapl intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul nls_utf8 nls_cp437 vfat fat jitterentropy_rng hdmi_audio cdc_acm sha256_ssse3 sha256_generic hmac drbg ansi_cprng iTCO_wdt dwc3 iTCO_vendor_support udc_core spidev evdev aesni_intel aes_x86_64 lrw gf128mul glue_helper ablk_helper cryptd i915 efi_pstore option usb_wwan efivars snd_pcm usb_storage snd_timer snd scsi_mod ftdi_sio usbserial soundcore ti_adc081c drm_kms_helper iosf_mbi drm lpc_ich dwc3_pci shpchp mfd_core 8250_fintek i2c_algo_bit video industrialio battery spi_pxa2xx_platform tpm_crb pwm_lpss_platform pwm_lpss int3400_thermal tpm_tis int3403_thermal tpm acpi_thermal_rel
[183911.723356] int340x_thermal_zone ac acpi_pad button processor i2c_dev fuse parport_pc ppdev lp parport autofs4 ext4 crc16 mbcache jbd2 hid_generic usbhid hid mmc_block crc32c_intel xhci_pci xhci_hcd r8169 mii usbcore usb_common thermal fjes sdhci_acpi sdhci mmc_core
[183911.723514] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G W 4.4.0-ubi3-amd64 #1 Debian 4.4.13-1
[183911.723525] Hardware name: AAEON UP-CHT01/UP-CHT01, BIOS UPC1BM0S 06/04/2016
[183911.723537] 0000000000000086 cb11619bc5cd881a ffffffff81306017 0000000000000000
[183911.723559] ffffffffa0096460 ffffffff8107d143 ffff88005a808540 ffff880036d32ad8
[183911.723577] 0000000000000005 0000000000000001 ffff88005a808540 ffffffffa0093820
[183911.723596] Call Trace:
[183911.723609] <IRQ> [<ffffffff81306017>] ? dump_stack+0x5c/0x85
[183911.723653] [<ffffffff8107d143>] ? warn_slowpath_common+0x83/0xc0
[183911.723677] [<ffffffffa0093820>] ? sdhci_send_command+0x770/0xc30 [sdhci]
[183911.723700] [<ffffffffa0090b65>] ? sdhci_reset+0x55/0xc0 [sdhci]
[183911.723722] [<ffffffffa0094594>] ? sdhci_finish_data+0xf4/0x340 [sdhci]
[183911.723743] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[183911.723765] [<ffffffffa009485a>] ? sdhci_timeout_timer+0x7a/0xb0 [sdhci]
[183911.723786] [<ffffffff810e3a20>] ? call_timer_fn+0x30/0x130
[183911.723807] [<ffffffffa00947e0>] ? sdhci_finish_data+0x340/0x340 [sdhci]
[183911.723827] [<ffffffff810e5736>] ? run_timer_softirq+0x176/0x2d0
[183911.723845] [<ffffffff81081d1a>] ? __do_softirq+0x11a/0x2c0
[183911.723861] [<ffffffff81082008>] ? irq_exit+0x88/0x90
[183911.723880] [<ffffffff815dbaee>] ? smp_apic_timer_interrupt+0x3e/0x50
[183911.723899] [<ffffffff815d9de2>] ? apic_timer_interrupt+0x82/0x90
[183911.723907] <EOI> [<ffffffff814972ec>] ? cpuidle_enter_state+0x13c/0x2b0
[183911.723942] [<ffffffff810bf0c6>] ? cpu_startup_entry+0x346/0x3b0
[183911.723964] [<ffffffff81b3af9a>] ? start_kernel+0x487/0x4a8
[183911.723983] [<ffffffff81b3a120>] ? early_idt_handler_array+0x120/0x120
[183911.723999] [<ffffffff81b3a611>] ? x86_64_start_kernel+0x156/0x17b
[183911.724011] ---[ end trace 35a2ee1a4f95654b ]---
[183911.726785] mmcblk0: error -110 sending stop command, original cmd response 0x0, card status 0x400900
[183911.726834] mmcblk0: error -110 transferring data, sector 6084608, nr 448, cmd response 0x0, card status 0x0
[183911.740496] blk_update_request: 3 callbacks suppressed
[183911.740504] blk_update_request: I/O error, dev mmcblk0, sector 6084608
[183911.749589] blk_update_request: I/O error, dev mmcblk0, sector 6084616
[183911.758448] blk_update_request: I/O error, dev mmcblk0, sector 6084624
[183911.767188] blk_update_request: I/O error, dev mmcblk0, sector 6084632
[183911.775916] blk_update_request: I/O error, dev mmcblk0, sector 6084640
[183911.784637] blk_update_request: I/O error, dev mmcblk0, sector 6084648
[183911.793378] blk_update_request: I/O error, dev mmcblk0, sector 6084656
[183911.802115] blk_update_request: I/O error, dev mmcblk0, sector 6084664
[183911.810840] blk_update_request: I/O error, dev mmcblk0, sector 6084672
[183911.819591] blk_update_request: I/O error, dev mmcblk0, sector 6084680
[183911.828367] EXT4-fs warning (device mmcblk0p3): ext4_end_bio:329: I/O error -5 writing to inode 928423 (offset 0 size 0 starting block 760632)
[183911.828374] buffer_io_error: 3 callbacks suppressed
[183911.828378] Buffer I/O error on device mmcblk0p3, logical block 747776
[183911.837186] Buffer I/O error on device mmcblk0p3, logical block 747777
[183911.845938] Buffer I/O error on device mmcblk0p3, logical block 747778
[183911.854693] Buffer I/O error on device mmcblk0p3, logical block 747779
[183911.863452] Buffer I/O error on device mmcblk0p3, logical block 747780
[183911.872213] Buffer I/O error on device
Hi Mike,
Could you provide us more details on your board?
- Board type (e.g. 2GB Ram 16GB eMMC)
- BIOS Version (you can run from the terminal: cat /sys/devices/virtual/dmi/id/bios_version )
- Operating system (ubilinux 3.0)
- kernel version (you can run from the terminal: uname -r )
- cables and devices used for the tests (e.g. power supply, usb keyboard, etc.)
thanks! -
Sure
Board type is a 2GB RAM+32GB eMMC.
BIOS version is UPC1BM0S
OS is Ubilinux 3.0
Kernel is 4.4.0-ubi3-amd64
The power supply is a 5V / 4A adapter. I've tested it's ability to deliver the 4A for a long time and it has proven to be very capable, with a very stable voltage. It powers up the board only. A self-powered USB hub is used to connect several peripherals:
- An USB GSM key
- An USB ZWave key
- An USB RFXCom adapter
Thanks!
M -
FYI, I removed every single USB peripheral and the issue still happens after some time (less than 2 hours after reboot).
M -
FYI.
I've tried with a laboratory power supply, without any peripheral and as soon as I start stressing the storage (using postmark-1.1.0 test from the Phoronix suite), it crashes. It even happens with a basic PHP/MySQL appplication.
Should I consider my board as dead?
M -
I have also encountered this on a 2GB RAM/32GB eMMC board. After a few days, while connected to internet via UsbModem and writting data to a MySql database, the sql connection suddenly started raising errors. Other programs failed to start and a reboot brought the hole system down.
Hi mirceaciu,
It is a known issue with the eMMC, which has been fixed by our latest kernels for ubilinux, ubuntu and Yocto.
For more information, check out the news from our blog: https://up-community.org/blog/59-up-board-4-4-linux-kernel-for-ubilinux-ubuntu-yocto -
just made the updates. Thank you for the effort, I'll hit you up if other problems arise
Iv' got the same isue on 14.04 is there an update fpr 4.2 kernel or can i upgrade to 4.4 on 14.04. We need 14.04 by our server's software.
Thanks -
Ok i'va solved it. I'll just make and got the newst kernel.
sudo apt install linux-upboard-lts-xenial -
Thisis a known issue.
The official ubilinux and Ubuntu kernels for UP include a fix for this.
If you are not using these kernels, please d include this patch set (or at least patch #2 in the set):
https://www.spinics.net/lists/linux-mmc/msg40829.html
Note that this patch set has also been back-ported to linux-stable trees for v4.4, v4.8 and v4.9.
