Intel Realsense
Eike
Posts: 2 ✭
Hi all,
using a custom USB-3.0 cable (1:1 wiring), I can't get Realsense R200 to work with the up-board.
My questions:
What is the required wiring? Is anything else to be activated using USB 3.0. lsusb only shows the hub (bus002).
Is R200 not supported with ubilinux?
Thank you.
regards Eike
My questions:
Thank you.
regards Eike
Fixed
VIDIOC_DQBUF error 19, No such device
by doing the wiring correctly: For RealSense either a active hub is required or (as I did) rewire the 5V power to a separate 5V supply.
References: RealSense Issue #71
