USB Powered Hard Disks?
m
m New Member Posts: 15 ✭
Is the Up Board able to power 2.5 hard disks via USB? Is there a difference in power between the different ports? Thank you for your answers!
  • Aling
    Hi fb,
    The answer varies by different USB hard drive. Some of them can work without extra power, some can not. I suggest you may need to test it.
