Connector names
I was a little bit confused about the "B.1 Cabels and Connectors" section and "Mating cable" column in the Up Squared V2 manual.
(Nearly) every connector is a JST standard connector. It would be great to get the JST common name instead of an internal number or empty field.
Would be great if you could update the manual in these points.
  • maas
    maas New Member Posts: 2 ✭
    I.e. CN17 has the "Mating cable" entry "170X000306". The common name would be "JST SH 1.0mm 6 Pin"
    For CN19 there ist no entry.
