GPIO on UP Squared - its terrible!
I need to use GPIO on UP Squared with Ubuntu 22 server - reed many sources and try any days without success(((
I have problem with pin for LED:
-gpioset gpiochip4 27=0 or 1 - turn on led onle for amount 0.5sec
-doesn't matter led connect to 3.3 or gnd.
-try some modes "push-pull|open-drain"
-try without led only with oscilloscope for little current - only one pulse
How to turn on GPIO for a long time or for pulse with my duration?
Documentation is very bad - no one workable instuctions!
1 https://github.com/up-board/up-community/wiki/Ubuntu_20.04
Have no docs for Ubuntu 22, dont need to change core, because driver pincrtl is present in default
2 No any information for HAT GPIO parameters in BIOS!
Is there a need to change them?
I set up in BIOS Output mode, but in gpioinfo it still as Input!
3 https://github.com/up-board/up-community/wiki/40Pin-Header
No information that driver pincrtl in in core.
https://github.com/up-board/up-community/wiki/How-to-use-the-peripherals-on-40-Pin-Header
No samples for use pincrtl.
Sample with Bash "echo 26 > /sys/class/gpio/export" - dont work!
"/sys/class/gpio# ls" - dont include simple GPIO, only chips
"export gpiochip0 gpiochip779 gpiochip822 gpiochip869 gpiochip946 unexport"
4 https://github.com/up-board/up-community/wiki/Pinout
Pionouts are bad - for example pin 13:
- in table pin13-up pinout gpio4-linux gpio 27
- in BIOS pin13-gpio5
- What is correct?
Also I have problem with return back ports to functional mode - pins 3,5 dont return to i2c after reboot.
In docs i see "Warning: The current pinctrl driver implementation does not allow to restore a pin in function mode (e.g. UART) once it has been already switched to GPIO mode until the operating system is rebooted" - but it dont work.
How I can return to i2c mode? -
I made some experiments and saw that i2c dont work after install package gpiod !
But after remove package i2c still dint work(((
What tools can i use with gpio and i2c simultaneously ?
Tagged
- 105 Announcements & News
- 185 Welcome Developers!
- 48 Tech Updates
- 693 UP Products
- 11 UP 7000
- 10 UP Xtreme i12
- 11 UP Squared Pro 7000
- 19 UP Squared V2
- 59 UP 4000
- 35 UP Squared 6000
- 60 UP Squared Pro
- 143 UP Xtreme
- 837 UP Squared
- 222 UP Core
