ihakka
Audio not working on 10 IoT Core and 10 IoT Enterprise. Even if I install drivers in DP...255.zip audio doesn't work, the device is not found and sound icon on taskbar has red sign on it. What drivers need to be installed and where to download them? I also installed the Graphics drivers again even though I had never versions already installed. I also noticed I2C, GPIO etc. drivers seem not to work.
UP Board however works perfectly out of the box, sound and all on IoT core. Haven't tried with Enterprise.
  • Wilbert
    Wilbert ✭✭✭
    Hi Sir,
    There are notes on the User menu.
    Please enter the BIOS, change the HD Audio DSP function to Disable under the South bridge, and then enter to Windows 10, you should be able to see that the Audio can be used normally.
    Wilbert Lee.
