RS422
wolftec
wolftec New Member Posts: 4
As anyone been able to use the RS422?
RS232 works great even with RTS but, after setting RS-422 on the bios, i'm onçy able to receive but not transmit.
Using ubuntu, with ver 1.0 bios, and minicom.
  • wolftec
    After further investigation with a logic probe, noting is being sent out for the tx on the transceiver when i select RS-422 and hardware handshake. Also the DTR pin is not set. If i select RS-232 on bios with hardware handshake everything works ok and all signals are ok.
  • Wilbert
    Hi Sir,
    Can you provide your Ubuntu version? Kernel version?
    I will arrange a test to confirm this problem as soon as possible.
    Wilbert Lee
  • wolftec
    Hello Wilbert,
    I've tried both of these:
    Ubuntu 20.04 with the kernel 5.4.0 modification as instruted on the wiki
    Ubuntu 22.04 with kernel 5.15.0
    Thanks for your help
  • Wilbert
    Hi Sir,
    Thank you very much for the details, we have reproduced the issue.
    The problem is currently being clarified, if there is an update, we will notify you as soon as possible.
    Wilbert Lee
  • Wilbert
    Hi Sir,
    Sorry for taking so long to update.
    We expect to fix this issue with an official BIOS release next week.
    Wilbert Lee.
  • Wilbert
    Hi Sir,
    Thanks for your patience and sorry for the late update.
    Attach the updated BIOS, which has been confirmed by AE test first, and can use RS422 mode
    Change the BIOS to RS422 mode, test with Ubuntu 22.04, use the tool Minicom, change the Hardware flow control to No, and it can be used.
    Wilbert Lee.
  • pna
    pna New Member Posts: 7
    Hello @Wilbert
    I see in the BIOS you linked that it is also a change on enabling support for RS485. Which port will support RS485? Is it the port on the HAT-connector or the port on the CN11 (RS-232/422)? Will there be an official release of the BIOS version you linked above?
    Thanks.
  • Wilbert
    Hi Sir,
    At CN11.
    The official version is undergoing an internal validation process, and an update will be released upon completion.
    Wilbert Lee.
