Fan
scottdg
scottdg New Member Posts: 11 ✭
I see the 2 pin wafer for Fan (12V) so I am hoping this will allow a thermal fan can be integrated? Thanks!
If yes, do you sell one?
  • scottdg
    I found the thermal fan for the UP board on this website, but not sure if this will fit the 4000 architecture. Also, I just noticed the CPU is now positioned on the back side, so the cooling system adds near 3 cm of height.
  • scottdg
    Does the UP 4000 come with the heat sink pictured?
  • scottdg
    if it does come with, do you use thermal paste to attach, or is it only bolted on?
