UP 4000 / Why is the audio not recognised correctly in the device manager?
New Member Posts: 1
I have downloaded and installed the driver package DP00000255. However, not all devices are recognised. It is annoying that the sound does not work because of this.
Has anyone installed the Windows correctly?
Many greetings
Roy
  • New Member Posts: 5
    I have the same issue with Windows 10 IoT Enterprise. Also IoT core audio does not work. However, Up Board worked well and UP Core. Where to find correct drivers. Have you found a solution yet?
Welcome!
