Power supply via the 40pin header
Hi folks,
is it possible to power the UP with 5V via the 40pin header?
With the "normal" Up² it was possible to do so.
Thank You.
Best Answer
  • Wilbert
    Wilbert ✭✭✭
    Answer ✓
    Hi Sir,
    In UP Squared V2, it is not possible to directly supply 5V through HAT40 for MB to boot.
    As the CPU performance becomes stronger and stronger, the overall wattage is also higher and higher. Taking into account the actual use, the new model start to introduce 12V input.
    Wilbert Lee.
