Supported versions of Windows 10
Boesling
Boesling New Member Posts: 9 ✭
Hi all,
is Windows 10 IOT Enterprise 2019 LTSC still supported? I try to install it, but it failed because of the downloadable drivers.
Thank You.
Best Answers
  • Wilbert
    Answer ✓
    Hi Sir,
    Can you help to confirm your Windows version? I need details.
    You mentioned 2019LTSC in the question, Tagged wrote 2021 LTSC, I am confirming this issue.
    I tested Windows 10 Enterprise LTSC, Ver.10.0.17763, and there is no problem with installing the OS and drivers.
    Wilbert Lee
  • Boesling
    Answer ✓
    Thank you for your help. It was my fault by using the wrong image version.
  • Wilbert
    Hi Sir,
    Please provide the BIOS version and which options you have modified in the BIOS.
    Or restore the default, does the reinstall have the same problem?
    Wilbert Lee
