upxtreme spi_dev0.1 speed problem
JackeySchofield
New Member Posts: 5 ✭
upxtreme spi dev0.0 supports 12Mhz, but spidev0.1 only supports below 4Mhz.
The installed version of upxtreme ubuntu is 18.04 and the kernel is 5.4.0.1
Hi Jackey,
Can you provide your test method?
Clean OS? Or something updated?
How did you determine the frequency? Have you confirm with oscilloscope or logic analyzer?Or connect to device?
Normally, the SPI frequency depends on the Clock. The difference between spi dev0.0 and spi dev0.1 is the Chip select pin.I have tried to replicate this issue here, but all I see here are normal output, and the frequency will not be different due to different chip select pin.
Tagged
- 105 Announcements & News
- 186 Welcome Developers!
- 50 Tech Updates
- 693 UP Products
- 11 UP 7000
- 10 UP Xtreme i12
- 11 UP Squared Pro 7000
- 19 UP Squared V2
- 59 UP 4000
- 35 UP Squared 6000
- 60 UP Squared Pro
- 143 UP Xtreme
- 837 UP Squared
- 222 UP Core
