Installing kernel on Ubuntu 20.04?
I am trying to follow the instructions at this link, and it immediately fails at the first command
sudo add-apt-repository ppa:aaeon-cm/5.4-upboard
with an error that '~aaeon-cm' user or team does not exist.
What do I do to fix this?
Also, BTW, the https://releases.ubuntu.com/20.04/ubuntu-20.04.2.0-desktop-amd64.iso does not exist, but I used the 20.04.3 version for my install image.
-Mark
  • Hi @mwomack ,
    Thanks for pointing it out, the link for the iso image was changed by Canonical, I have updated it to 20.04.3 and also replicated the instructions for installing UP kernel 5.4 on an UP Squared PRO device successfully. Can you tell me which device you are trying it on?
  • I got the same on Ubuntu 20.04 and Up Board
    Cannot add PPA: 'ppa:~aaeon-cm/ubuntu/5.4-upboard'.
    ERROR: '~aaeon-cm' user or team does not exist.
  • The same here on an UpSquared6000
    ~$ sudo add-apt-repository ppa:aaeon-cm/5.4-upboard
    The user named '~aaeon-cm' has no PPA named 'ubuntu/5.4-upboard'
  • Hi @TheVoice ,
    Kindly follow the updated guide to add repository.
    @TimP,
    Please follow the guide to install the IOT Image for UP Squared 6000, you do not have to install kernel
