USB failure
Had two upboards USB fail on one side. In both cases we believe it is this component but my eyes are not good enough to identify it. I am sure I can fix the boards by replacing this.
  • camillus
    camillus Posts: 188 mod
    Hi @3cells ,
    Can you kindly give a clear description of what you mean by it fails, did it not work when you got it?
    Best regards
  • 3cells
    3cells Posts: 22 ✭✭
    USB worked fine when we got the board. They are all configured and tested before being deployed. They failed in use. We have about 50 and have been using them for the last 3 years. These two failed recently. Not sure why they failed.
  • camillus
    edited August 2021
    Hi @3cells ,
    Kindly proceed with RMA for further testing and repairs, if you purchased directly from UP Shop you can do that from here, else you have to raise the RMA via your reseller.
  • 3cells
    3cells Posts: 22 ✭✭
    Thanks, I will check purchase dates on units to see if still under warranty. As units still function and all we have lost is a pair of USB it would be useful to know the identity of the part so we can replace ourselves.
