UP2 use dc drive by battery?
edison
New Member Posts: 1 ✭
Hi sir,
I want to intput DC power to drive UP2 by battery.
and try some method below ,but UP2 still can't work.
AC/DC adaptor (12V/29A) >> DC/DC module (5V/4A) >> UP2 = failed
DC power supply (5V/4A) >> UP2 = failed
Battery (12V/3cell) >> DC/DC(5V/4A) module >> UP2 = failed
UP2 has output opening signal on monitor, then it doesn't work at few second .
could anyone help me ?
thank so much.
Edison.
Hi @edison ,
The Tech team is checking internally and will get back to you soon with a reply.
Best regards,
Hi @edison ,
Yes it is possible? Can you please provide the serial number on the board?. Also a photo of the battery you are using, when you power on using the Power Supply Unit that came with the UP2 does it still work?
- 301 All Categories
- 184 Welcome Developers!
- 24 Tech Updates
- 547 UP Products
- 1 UP Xtreme i12
- UP Squared Pro 7000
- 10 UP Squared V2
- 25 UP 4000
- 23 UP Xtreme i11
- 44 UP Squared Pro
- 140 UP Xtreme
- 819 UP Squared
- 221 UP Core
- 43 UP AI Edge
