DC-in Power voltage range
Hi! What is a worked range of power DC-in voltage? I could not find this in documentation.
Hi @Mikhail_U ,
Please find the details in the power consumption test report attached, Page 14.
You can also find the rest of the tests and certifications for UP board here, https://downloads.up-community.org/download/up-test-and-certification/Regards,
Pratik -
Thank you! But I didn't find the voltage range on DC_in when Up Board can work!
Is it really possible to run the Up Board from 3.3V?
The specifications here https://up-board.org/up/specifications/ indicate the power requirements as:
"5V DC-in @ 4A 5.5/2.1mm jack" -
@Pratik_Kushwaha said:
Hi @Mikhail_U ,Up Boards voltage range is 3.3V to 5V for DC-IN
Regards,
PratikDoesn't work less then 5.0V.
4.9 - not worked.
From 5.0 to 5.2 - Up Board booting on and, then, goes to shutdown.
Power supply - Mastech HY3005.
5.5 V - worked fine.
Wire from power supply - 2.5 sq. mm, 0,6 m. -
Hi @Mikhail_U ,
The power supply that needs to be used with UP Board is this one, https://up-shop.org/up-squared-power-supply-5vat6a.html.
Please use the correct power supply in order to avoid shorting the unit.
Regarding the voltage range, our team is checking the details again and will get back to you asap.
Regards,
Pratik -
My power line has 12V to 30V. Your power supply doesn't work for me.
Did you manage to find the power supply voltage range?
Or do the developers know nothing about the product? Or are AAEON not developers? -
Hi @Mikhail_U ,
UP Board power range is 5V with +/-5%, but the current must be 3A or more.
If the PSU you are using drops the voltage below 5V under load, then UP board wouldn't work.
Please try using a PSU which can regulate and maintain a fixed input voltage and current.
Regards,
Pratik K -
Many thanks!
Please, add this info to datasheet for future users!
Tagged
- 105 Announcements & News
- 185 Welcome Developers!
- 48 Tech Updates
- 693 UP Products
- 11 UP 7000
- 10 UP Xtreme i12
- 11 UP Squared Pro 7000
- 19 UP Squared V2
- 59 UP 4000
- 35 UP Squared 6000
- 60 UP Squared Pro
- 143 UP Xtreme
- 837 UP Squared
- 222 UP Core
