bluetooth choppy sound ubuntu 20.04 and 18.04
Ubuntu 20.04 , Up Core Plus, I have followed all instrucctions from wiki pages (Up kernell and Wifi/BT firmware), but the sound is chopped all the time in the bluetooth devices. Using HDMI, sound output is ok.
I have tried PulseAudio latency offset, many pairings with differents bluetooth devices and all possible configurations, but always the same: it connects but the sound is choppy. The A2DP configuration is possible, but the HSP/HFP is not available. Please, any help will be wellcome. Thanks
you should check the systemd service for the bluetooth and update the speed from 115200 to 3000000.
Specifically.
Stop and disable the service:
systemctl stop firmware-ampak-ap6355.service
systemctl disable firmware-ampak-ap6355.serviceGo to /etc/systemd/system and edit the file: firmware-ampak-ap6355.service
And change the line:ExecStart=/usr/bin/hciattach -n -t 10 /dev/ttyS6 bcm43xx 115200
to
ExecStart=/usr/bin/hciattach -n -t 10 /dev/ttyS6 bcm43xx 3000000
save, and reenable the service
systemctl enable firmware-ampak-ap6355.service
then restartlet us know if it works for you
Thanks very much for your quick answer. Followed your instructions and... sound is ok now.
Tagged
- 284 All Categories
- 179 Welcome Developers!
- 18 Tech Updates
- 355 UP Products
- 5 UP Xtreme i11
- 8 UP Squared 6000
- 38 UP Squared Pro
- 125 UP Xtreme
- 790 UP Squared
- 83 UP Core Plus
- 215 UP Core
- 40 UP AI Edge
