Power Button Additional Commands
jgregoire
jgregoire New Member Posts: 2
I'm using an external power button on CN2 to power down the device. I need the system to run the command systemctl stop yourservice when the power button is pressed. I've tried adding a custom ACPI script and function for this command. If I run this ACPI service I've created, it functions as expected and shuts the system down. However, pressing the power button doesn't do anything.
I'm pretty sure the /sbin/shutdown binary is taking precedence.
Can anyone provide any help as to what can be done in this situation? I would just like the power button to run a script or command on button press.
OS: Ubuntu 18.04
Kernel: 5.4.0
  • Pratik_Kushwaha
    Hi @jgregoire ,
    We are looking into this and will get back to you around next week with updates. Thanks.
    Regards,
    Pratik
  • ashwanimathur
    ashwanimathur New Member Posts: 2
    +1 .. looking for response to same issue
  • camillus
    camillus AAEON Posts: 188 mod
    Hi @jgregoire ,
    On which device are you trying this?
    Kindly follow the example guide on the man page of acpid here
    I have tested stopping ssh service and looking at the syslog using (/usr/bin/tail -f /var/log/syslog) during shutdown I see it does it. Following the example, I added a sleep function on the script and varied the time and I see the system waits before shutdown so it detects the script. Also after shut down I can Power On using the Power button and it Powers On.
    Can you share how you are testing yours?
