Up Xtreme 5G Compatibility
I'm curious about using a 5G module with the Up Xtreme board. I noticed the new upcoming version on Intel's latest chips support an optional 5G module via a M.2 key B slot.
As such, I'm curious about the possibility to add this compatibility to the Up Xtreme board. Some adapters exist that provide the ability to convert a mPCIe slot into the M.2 key B with SIM card slots.
Is there anything else that would inhibit using one of these boards to add 5G functionality to the Up Xtreme board through the mPCIe, either on the board itself or on the Net+ module?
I know that sometimes WWAN cards need interaction with the UEFI and if support for a specific module is not available the UEFI might not even recognize the 5G module or it might not be functional within the operating system.
Is there any inclination to provide this type of compatibility for 5G modules on the Up Xtreme?
  • Pratik_Kushwaha
    Hi @beaker ,
    We are introducing UP Connect Plus with 5G capabilities that can be stacked up with UP Xtreme to offer 5G functionalities.
    You should find it available soon this month on our UP Shop, https://up-shop.org/ .
    UP Connect Plus comes with a 5G Module (M.2 3042/3052 colay), 1x Micro SIM CARD and 3x additional RJ45 Ethernet ports for adding more connectivity options on your UP Xtreme.
    BR,
    Pratik
  • beaker
    beaker New Member Posts: 16 ✭
    @Pratik_Kushwaha said:
    Hi @beaker ,
    BR,
    Pratik
    Thats awesome, will this board work with the Up Core or Up Core Plus board with the docking connector as well or just the Up Xtreme?
  • Pratik_Kushwaha
    Hi @beaker ,
    BR,
    Pratik
    Connect Plus is compatible with UP Core Plus and UP Xtreme boards.
