My UP Squared Board issue
Ranjit
Ranjit New Member Posts: 1 ✭
I have plug power, booting USB, ethernet cable, keyboard, and mouse then also I am not able to get anything on the screen. Moreover, the light in the bord is not turning on. I think the bord is having some issue and if so then bord is in warranty what steps should I take to replace it?
    what power supply are you using to power the board?
    To issue an RMA for the warranty, you should contact the shop where you bought it.
    If you bought from the up-shop follow the RMA procedure from your account profile
