ATX power supply and Wake on Lan
usaginomimi
Posts: 1 ✭
I'm new on the forum. I've previously powered up a squared board with ATX power supply, wiring the ATX supply connector to the +5V/Ground pins of the 40-pins GP bus.
I'd like now power the same way another squared board with ATX, and use wake on lan.
Is there a way to wire squared to ATX connector so that board can set to sleep or wake the power supply, and so that board still be supllied with little current in sleep mode?
Thank you
