Intel Board booting error
im encountering a file system error during the boot process, the device keeps on booting to the initramfs command prompt as shown in the attached screenshot. im unable to access the devices due to this error as devices are already deployed at the client location.
Please provide me the guidance to rectify this issue remotely
Hi
Did you receive any feedback on your issue?
I have the same issue as you with several UP² boards...
Thank you for your reply
That issue can be cause by many factors: an update gone wrong, a sudden power loss or other electrical problem and it is common in many embedded system which are not properly configured for production environment.
Even if you install a UPS system to stabilise the current and shutdown the system in case of power loss, may help but not solve all the real world situations/corner cases.
Usually a robust system includes a variety of configurations/optimizations to avoid certain issues as the one described above for example:
I am afraid you would need to get back your hardware and implement a more robust configuration for your system.
We can offer you professional services to help you implement a robust and
yes, you are correct, im facing this error at a sudden drop in supply,
are there any guidelines to make a device robust? can you guide me to optimize this error as of now devices are placed at the client location and I have just remote access to the OS level. is there any possibility that I can skip this error for online devices.
I got a reply from support as: need to repair manually by entering the "fsck -y /dev/mmblk0p2" command.
@gbeckers how often you are getting this error ?? and at what situations you're able to see this error?
I'm getting this error repeatedly if there is a sudden power drop.
Hello @dbhairi
Any system without battery that suffer power drop/loss will eventually experience the same problem. If you cannot guarantee continuous power or include a UPS battery to your system, you would need to make your system robust for such scenarios (as suggested above).
There are ready solutions that provides the necessary configurations and software to make your embedded solution robust and reliable like Balena (which already supports our UP products): https://www.balena.io/
We can also help with our Software services to provide consultancy or implement a robust and reliable solution based on YoctoProject. You can send a request for quotation from our Shop: https://up-shop.org/
