wake from S3
jayman
After entering S3 (sleep), I'm unable to wake my UP Xtreme via USB keyboard or mouse input, only by pressing the power button.
Is that expected behavior or is there some setting (BIOS or OS) that needs to be adjusted for this to work?
  • jayman
    edited October 2020
    I was wondering if anyone had the same experience? I'm running Windows 10 on the UP Xtreme by the way.
  • rogertsai(AAEON)
    @jayman
    Due to the hardware design, the USB power will be turned off in S3 (sleep) state. Therefore, "Wake on USB" is not supported.
  • rogertsai(AAEON)
    @jayman
    You can work around this issue by connecting a "Powered USB Hub" if you really want to use "Wake on USB"
  • jayman
    Thanks Roger! I followed your suggestion and connected a powered USB hub, but no luck. I still can't wake the computer via keyboard or mouse, only by pressing the power button.
  • jayman
    So there's no way to make Wake on USB work, even with a powered hub?
  • rogertsai(AAEON)
    edited March 2021
    @jayman
    In S3 sleep mode, I can wake the UPX board via keyboard/mouse with my powered USB Hub. So, please make sure that your USB hub is already connected to an external power supply and enable "Allow this device to wake the computer" under device manager for your keyboard or mouse.
