Heat sink not as effective as needed
I was wondering if there is a more effective heatsink or design for a heatsink? I am running into overheating issues (due to amount of power used and code that needs to be run).
Is the board open without enclosure?
If so and still too hot due to the high load, you can opt for the active heatsink option we provide: https://up-shop.org/active-cooler-fan-for-the-up-board-and-up-core-board.html
the board is in an enclosure (IP rated), I was just curios to see if anyone had run into this issue before and came up with a solution
@DCleri said:
Is the board open without enclosure?If so and still too hot due to the high load, you can opt for the active heatsink option we provide: https://up-shop.org/active-cooler-fan-for-the-up-board-and-up-core-board.html
That was it, Thank you
Tagged
- 105 Announcements & News
- 185 Welcome Developers!
- 48 Tech Updates
- 693 UP Products
- 11 UP 7000
- 10 UP Xtreme i12
- 11 UP Squared Pro 7000
- 19 UP Squared V2
- 59 UP 4000
- 35 UP Squared 6000
- 60 UP Squared Pro
- 143 UP Xtreme
- 837 UP Squared
- 222 UP Core
