Display Connection
Good Day,
I would like to ask, is it possible to connect this display to the UP Core Plus motherboard (Standalone)?
http://www.panelook.com/AMS495QA04_Samsung_5_OLED_overview_20210.html
Interface Type is: MIPI (2 data lanes), 40 pins Connector
Or can I use some small adapter for this? For those who ask why. I'm planning to "upgrade" PS Vita with a new motherboard. But I have to use a different display since display from Vita isn't compatible. Controls wouldn't be that hard to connect, the sound would be additional but it wouldn't be also that hard.
Thanks for the help! ![]()
@ErikHG10 If you see the block diagram from UP Core Plus, you will notice we only have eDP and DP for video output. The MIPI on board is for MIPI camera, not for MIPI display. So I am afraid you can not use that display. You may consider to go for HAT type display, like here. Or 7" / 10" display at UP SHOP with eDP interface.
@Aling Okay, Thank your for info
