Automatically rebooting in BIOS menu
RiversideRI
RiversideRI New Member Posts: 3
I recently updated the BIOS in my UpSquared board to v5.0, and when I'm in the BIOS menu it will automatically reboot after about 30 seconds. When booting into the OS it works fine, this only occurs when I am in the BIOS menu. It is very consistent, happening every time I am in the menu.
  • rogertsai(AAEON)
    @RiversideRI
    You can try to disable "iTCO" in the Boot options as below picture
    But this is really weird in logic, because the system restart will only be activated if the system is getting hanged after startup (freeze on splash screen)
  • garyw
    @RiversideRI
    Looks like watchdog reboot your unit but I didn't duplicate in our side, could you try to disable iTCO in BIOS to check reboot is caused by watchdog, thanks.
  • DV01D
    DV01D New Member Posts: 13
    I have confirmed this behavior after upgrading my up2 board to v50 BIOS in order to ensure I had watchdog support.
  • rchauvin
    rchauvin New Member Posts: 14
    I'm facing the same issue. The only solution is to disable iTCO?
