RS-422 Full Duplex not working in Rx
On our Up Xtreme, we want to use the two COM connectors in RS-422 mode.
After configuring the BIOS and following the pinout found in the Quick Installation Guide:
COM port pinout
We have managed to send some RS-422 Full Duplex frames using the TX- and TX+ pins but when receiving frames on RX- and RX+ there is only garbage received.
We have checked the signals with a scope, they are clean an the scope is able to correctly decode them in both directions.
@DCleri could you please confirm the pinout and that the RS-422 is functional in both directions with current BIOS?
Could we have the pinout of the DB9 connector on the chassis to confirm the correct wiring please.
Thanks.
  • rreignier
    rreignier New Member Posts: 67 ✭✭
    Hi @rreignier
    Thanks for the reminder, we are checking internally with the hardware and bios teams to provide you an answer asap
  • rreignier
    Hi @DCleri
    Thanks a lot for working on this.
    Looking forward to hearing from you.
  • rreignier
    Hi
    Did you have a moment to try the RS-422 in both directions on UpXtreme @DCleri?
    Thank you.
    Hi @rreignier
    No we haven't any update on this yet.
    I will keep you posted as soon as I have any update.
    Thanks for checking
  • rreignier
    Hi!
    Is the RS-422 on UpSquared Pro as broken as on the Xtreme?
    Because before buying the UpSquared Pro I do not want to be as disappointed as for the Xtreme.
  • rogertsai(AAEON)
    @rreignier
    I tested and didn't see any issues with RS-422. So, please provide more information about your application environment for our further verify. Also please double check the information below
    • BIOS Ver is R1.8 (UPW1AM18)
    • "Use this Device" to Enabled and Set RS-422 mode for serial port 1 and 2 in BIOS. (Advanced\SIO Configuration\Serial Port X\Mode)
    • Make sure that your COM port device is detected and no conflicts, no yellow exclamation mark issue in device manager
    • To RS-422 test if the Up Xtreme COM port is functioning correctly, you can do a simple loopback test to check whether the link between the two com port works normally. For example, COM1 TX- to COM2 RX-, COM1 TX+ to COM2 RX+, COM1 RX- to COM2 TX-, COM1 RX+ to COM2 TX+
