Ubilinux does not add repository "sudo add-apt-repository ppa:ubilinux/up"
Lubo
Lubo New Member Posts: 26 ✭✭
I would like ask for help with this.
I have ubilinux instaled from :
https://downloads.up-community.org/download/ubilinux-installer-4-0/
without issue.
But then , I would like upgrade kernel to 4.15. from ppa. However, I am not able to run :
There is error message showed :
[email protected]:~$ sudo add-apt-repository ppa:ubilinux/upTraceback (most recent call last):
File "/usr/bin/add-apt-repository", line 95, in
sp = SoftwareProperties(options=options)
File "/usr/lib/python3/dist-packages/softwareproperties/SoftwareProperties.py", line 109, in init
self.reload_sourceslist()
File "/usr/lib/python3/dist-packages/softwareproperties/SoftwareProperties.py", line 599, in reload_sourceslist
self.distro.get_sources(self.sourceslist)
File "/usr/lib/python3/dist-packages/aptsources/distro.py", line 93, in get_sources
(self.id, self.codename))
aptsources.distro.NoDistroTemplateException: Error: could not find a distribution template for ubilinux/dolcetto
What should I do in order to have sucesfully added repository ?
    ubilinux distribution is a debian based distribution which is not supported anymore.
    The ubilinux PPA is for Ubuntu only and it provides Ubuntu modified kernels for UP on Ubuntu 16.04 and 18.04.
    Please follow the installation instructions from our wiki: https://wiki.up-community.org/Ubuntu
  • Lubo
    Thank you for your comment. I followed instalation instructions and upgraded my UPBoard to Ubuntu 16.04 . But now I have another issue there. I am using mraa library and uart serial communication with my custom HAT . ( 40 pin header -pins 8,10 (UART1) )
    I already sucesfully run command : sudo usermod -a -G dialout ${USER}
    however, in my program (c code)
    mraa_init_uart(0)
    does not work anymore. It worked in ubilinux perfectly.
    Can you help mi this too, please ?
    Tahnk in advance.
  • kajpaj
    kajpaj New Member Posts: 1
    Hey folks, I am a super newbie, just as an FYI.
    I am trying to install the Ubuntu kernel with "sudo add-apt-repository ppa:ubilinux/up" and it tells me '~ubilinux' user or team does not exist.
    Please advise.
