Display with 1920x720 resolution
i want to buy a screen with 1920x720 resolution and run on it my Qt dashboard application using UpBoard and Linux(perhabs ubuntu) via HDMI port. Does UpBoard support this resolution? Originally, I wanted to use RaspberryPi for this purpose, but I found information that Raspberry does not support this resolution.
Screen link:
https://pl.aliexpress.com/item/33058176296.html?spm=a2g0o.productlist.0.0.45657a70IU6uD7&algo_pvid=73787d25-4f2c-4219-83dc-d39d1108e519&algo_expid=73787d25-4f2c-4219-83dc-d39d1108e519-7&btsid=fdf3c99d-91e8-408f-bc19-b807bc5c26d2&ws_ab_test=searchweb0_0,searchweb201602_7,searchweb201603_52
Best regards, Pawel
  • ard
    ard Posts: 2
    1920x720 is not a HDMI standard resolution so it may not be compatible over HDMI port. You'll probably need LVDS interface.
