[SOLVED] Problem with bringing LoRa server on UPSquared Edge Computer
Recently, we've bought LoRa Edge computer (https://up-shop.org/up-systems/292-up-squared-lora-edge-computing.html) for an edge computing course at our university. Linux boots fine and everything runs, but all the attempts to get LoRaServer (https://www.loraserver.io/) to accept the messages from the end device fail - no LoRaWAN frames are visible to the server. When digging deeper, I've understood that there is no LoRa gateway software preinstalled as well as no packet-forwarder. I've tried to install the needed software (lora-gateway and packet-forwarder) by compiling it both with default options and options that were provided in SOME manuals on UP products (e.g. in the manual on this particular product there are no instructions); unfortunately, all the attempts failed. The problem is not on the end device side and not on the LoRa server side as the end device worked perfectly with the TTN gateway and was then adapted strictly according to the instructions for LoRa server.
Could someone kindly point me to an up-to-date user guide that contains proven instructions for deployment of the LoRaWAN server and/or gateway on UPsquared edge?
Best regards,
Vladimir
Hi @vpodolskiy
Thanks for your feedback, we will include these instruction in the community shortly.
First it is necessary to follow those steps to install Ubuntu 16.04 and the right kernel:
https://wiki.up-community.org/Ubuntu#Ubuntu_16.04_installation_and_configuration
Please use the Desktop version and also follow the steps 1.1 until 1.2 included only.Once the installation is complete, boot the system and follow these steps to enable the SPI interface used by the LoRa module:
https://wiki.up-community.org/Pinout_UP2#Installing_ACPI_overrides_to_enable_spi_in_userspaceReboot the system.
If you want to connect to a LoRa public or private server and have the device acting as gateway only, you should configure the LoRa concentrator using our github repositories for:
https://github.com/AAEONAEU-SW/lora_gateway/tree/up_squared
https://github.com/AAEONAEU-SW/packet_forwarderThese repositories are a fork with the necessary modification to enable the LoRa concentrator on our system.
Create a folder (e.g. lora) and download both repositories. Inside the folder you should have:
lora_gateway
packet_forwarderPlease make sure the folders have those exact names.
Enter in lora_gateway and run:
make clean && make
Then enter in the packet_forwarder folder and run:
make clean && makeNow inside lora_gateway folder you should execute the command:
sudo ./reset_lgw.sh start
Then from the packet_forwarder you should configure it according to your Network server requirements, then you can run the packet forwarder.
On top of the lora gateway and packet forwarder packages you can install the additional software.To run the packet forwarder after you configured it according to your setup, inside the packet_forwarder/lora_pkt_fwd folder simply run:
sudo ./lora pkt_fwd -
@DCleri said:
Hi @vpodolskiyThanks for your feedback, we will include these instruction in the community shortly.
lora_gateway
make clean && make
sudo ./lora pkt_fwdHi and thanks for the answer!
I've tried this procedure, but still no success.
LoRa packet forwarder outputs “ERROR: failed to start the concentrator”.
Testing with utils from lora_gateway folder (e.g. util_spi_stress) results in error “ERROR: lgw_connect() did not return SUCCESS”.Any suggestions to a potential culprit that I could further test?
the ACPI override for SPI were not installed correctly.
Can you see them from your terminal?
$ ls /dev/spidev*
What is the output of that command?
@DCleri said:
the ACPI override for SPI were not installed correctly.Can you see them from your terminal?
$ ls /dev/spidev*
Thanks for your support! The issue is resolved.
I do not know what exactly helped, but I did the following:
1. updgraded OS with the following reboot
2. executed everything that you describe above with sudo (previously I've used it only for the reset_lgw.sh script).I'd advise to add that to instructions as well.
cheers!
Tagged
- 287 All Categories
- 179 Welcome Developers!
- 18 Tech Updates
- 377 UP Products
- 6 UP Xtreme i11
- 13 UP Squared 6000
- 38 UP Squared Pro
- 126 UP Xtreme
- 796 UP Squared
- 86 UP Core Plus
- 217 UP Core
- 40 UP AI Edge
