[SOLVED] Openvino Installation on Realsense Robotics Kit fails for AI Core X Myriad Step
I received my robotics kit without a preinstalled ubuntu image. The installation doc given with the AI Core X product (https://up-shop.org/featured/261-up-ai-core-x.html) does not work, because the 2018 R5 download of the Openvino Toolkit is no longer available.
All Openvino Toolkit installations from 2019 fail within the sidestep: http://docs.openvinotoolkit.org/latest/_docs_install_guides_installing_openvino_linux_ivad_vpu.html
when running sudo ./setup.sh make fails and no drivers get compiled.
What am I to do ?
NB:
I tried to create this in Starter Kits->Intel Realsense Robotics Development Kit category but that wsa not selectable.
I have installed the latest 2019 released again.
running ./demo_squeezenet_download_convert_run.sh -d MYRIAD
produces:...
Run Inference Engine classification sampleRun ./classification_sample_async -d MYRIAD -i /opt/intel/openvino/deployment_tools/demo/car.png -m /home/thomas/openvino_models/ir/FP16//classification/squeezenet/1.1/caffe/squeezenet1.1.xml
[ INFO ] InferenceEngine:
API version ............ 2.0
Build .................. custom_releases/2019/R2_f5827d4773ebbe727c9acac5f007f7d94dd4be4e
Description ....... API
[ INFO ] Files were added: 1
[ INFO ] /opt/intel/openvino/deployment_tools/demo/car.png
[ INFO ] Creating Inference Engine
MYRIAD
myriadPlugin version ......... 2.0
Build ........... 27579[ INFO ] Loading network files
[ INFO ] Preparing input blobs
[ WARNING ] Image is resized from (787, 259) to (227, 227)
[ INFO ] Batch size is 1
[ INFO ] Loading model to the device
[ ERROR ] Can not init Myriad device: NC_ERROR
Error on or near line 238; exiting with status 1lsusb finds Bus 004 Device 002: ID 03e7:f63b
running ./demo_squeezenet_download_convert_run.sh is ok.
My AI Core X is now working. I installed Intel Openvino Distribution 2019 R2.01 and also did the steps for the "Steps for Intel® Movidius™ Neural Compute Stick and Intel® Neural Compute Stick 2".
After that, all demos worked with the -d MYRIAD option.
I thought that the AI Core X module could not be a usb device because of the mpcie Connector, so I never followed the steps in the above section. This could be clarified in the documentation.
I did not try to use the HDDL option / installation.Thanks again for the support !
