Up Core Gateway 'without' onboard WiFi?
Hi
I just got a Up Core Gateway https://up-shop.org/up-systems/282-upc-gws01w4g-memory32g-emmc-boardw-vesa-plate.html it has an antenna and its written specs says it has onboard WiFi however in Ubuntu, it says wifi adaptor not found
What could be the issue here? please help
Hi @zubairahmed
Have you followed the instructions in our wiki to install Ubuntu, the UP Core Kernel and the WiFi drivers?
If not please follow the tutorial available for Ubuntu 16.04 or 18.04:
https://wiki.up-community.org/Ubuntu -
I found it after posting it through another thread, it should have been made more obvious, please include it elsewhere
I'll try that shortly and get back -
Thanks that worked!
