UP Board lower heat sink
3cells
Posts: 22 ✭✭
Is the lower heat sink available to buy?
Hi @3cells
It is not, as the lower heatsink is part of the standard one coming with the UP Board.
So if you buy an UP board that comes with the heat sink with the built-in fan preinstalled, is the lower heatsink not included?
Exactly, you can see that from: https://up-shop.org/up-peripherals/111-active-cooler-fan-for-the-up-board.html
