HW acceleration on an UpBoard
robogil
robogil New Member Posts: 3 ✭
am trying to get ffmpeg HW acceleration on an UpBoard . It uses an Atom x5 z8350 processor and Intel HD 400 GPU
I have also followed this tutorial in order to compile ffmpeg with libmfx enabled.
then ran:
$ ffmpeg -encoders | grep qsv
ffmpeg version 4.1.3 Copyright (c) 2000-2019 the FFmpeg developers
built with gcc 5.4.0 (Ubuntu 5.4.0-6ubuntu1~16.04.11) 20160609
configuration: --enable-libmfx
libavutil 56. 22.100 / 56. 22.100
libavcodec 58. 35.100 / 58. 35.100
libavformat 58. 20.100 / 58. 20.100
libavdevice 58. 5.100 / 58. 5.100
libavfilter 7. 40.101 / 7. 40.101
libswscale 5. 3.100 / 5. 3.100
libswresample 3. 3.100 / 3. 3.100
V..... h264_qsv H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 (Intel Quick Sync Video acceleration) (codec h264)
V..... hevc_qsv HEVC (Intel Quick Sync Video acceleration) (codec hevc)
V..... mjpeg_qsv MJPEG (Intel Quick Sync Video acceleration) (codec mjpeg)
V..... mpeg2_qsv MPEG-2 video (Intel Quick Sync Video acceleration) (codec mpeg2video)
However, when trying to encode I video I am getting:
$ ffmpeg -i in.mp4 -c:v h264_qsv -global_quality 10 -look_ahead 1 out.mp4
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'in.mp4':
Metadata:
major_brand : mp42
minor_version : 0
compatible_brands: isommp42
creation_time : 2019-06-04T19:06:40.000000Z
Duration: 00:04:03.07, start: 0.000000, bitrate: 408 kb/s
Stream #0:0(und): Video: h264 (Constrained Baseline) (avc1 / 0x31637661), yuv420p(tv, bt709), 640x360 [SAR 1:1 DAR 16:9], 310 kb/s, 25 fps, 25 tbr, 12800 tbn, 50 tbc (default)
Metadata:
handler_name : ISO Media file produced by Google Inc. Created on: 06/04/2019.
Stream #0:1(und): Audio: aac (LC) (mp4a / 0x6134706D), 44100 Hz, stereo, fltp, 95 kb/s (default)
Metadata:
File 'out.mp4' already exists. Overwrite ? [y/N] y
Stream mapping:
Stream #0:0 -> #0:0 (h264 (native) -> h264 (h264_qsv))
Stream #0:1 -> #0:1 (aac (native) -> aac (native))
Press [q] to stop, [?] for help
[h264_qsv @ 0x3b30a00] Error initializing an internal MFX session: unsupported (-3)
Error initializing output stream 0:0 -- Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height
Conversion failed!
What am I missing?
Thank you very much!
