M.2 port only works on power cycle, not reboot
I am using an Intel 8260 Wireless card on the Up^2 m.2 pci-ex port, running ubuntu server 16.04 with ubilinux kernel.
Problem: On a fresh power up the wifi card is detected no problem, all works as expected. When I run a 'sudo reboot', upon boot, the wifi card is not detected. When I do a full power cycle, everything works as expected. I have replicated this problem on 2x up squared boards. Has anyone else seen this?
Thank you.
Hi @peterh
Unfortunately, the Intel 8260 Wireless card is not supported.
At the moment the AC cards that have been tested on the board are already available on the UP-Shop:
https://up-shop.org/up-peripherals/153-m2-2230-wifi-kit-for-up-squared-metal-chassis.html
https://up-shop.org/up-peripherals/239-m2-2230-wifi-kit-2t2r-for-up-squared-metal-chassis.htmlCheers!
This similar problem was solved by atmouse at: https://forum.up-community.org/discussion/1895/m-2-2230-wifi-bt-in-the-up-square-success-with-intel-7760-ac-failure-with-8265#Comment_6114
It worked for me so it might work for you too.
Tagged
- 63 Announcements & News
- 104 Welcome Developers!
- 22 Tech Updates
- 3.5K UP Products
- 27 UP 7000
- 11 UP Xtreme i12
- 15 UP Squared Pro 7000
- 23 UP Squared V2
- 68 UP 4000
- 58 UP Squared Pro
- 144 UP Xtreme
- 820 UP Squared
- 75 UP Core Plus
- 223 UP Core
- 40 UP AI Edge
